RE-7500 Reworking System & iSolder the Infrared Reworking System - Product By Jovy Systems. & iSolder the intelligent soldering machine |
03-29-2011, 08:21 | #31 (permalink) | |
Crazy Poster Join Date: Dec 2010
Member: 1481034 Status: Offline Sonork: Halim_Xu Thanks Meter: 3 | Quote:
first i've to thank you to giving me informations about bga pad repair, i wanna tell you that i've done my v3000 bga pad well, the losed dummy pad i just ignored as mr.Pentu suggested, so it's really a dummy one,,.and gave me a lot of worried..but now it's working / alive, really thanks for you all, may *** bless you... | |
03-30-2011, 14:43 | #32 (permalink) |
Member: 1481034 Status: Offline Sonork: Halim_Xu Thanks Meter: 3 | Hi Mr.Pentu, after finish reballed v3000 compaq, do i need to upgrade the bios? seems many other threads suggest to upgrde it, is it important? and is it fine to use copper pad for bga chip?thanks |
03-31-2011, 11:47 | #33 (permalink) | |
Crazy Poster Join Date: Mar 2007
Member: 473301 Status: Offline Thanks Meter: 11 | Quote:
while removing while reballing while re-soldering the chip any chip which goes through will lose some percentage of performance. always replace the bga chip with new one and no head ache of the laptops returning for rework again and again. | |
The Following User Says Thank You to pentu For This Useful Post: |
03-31-2011, 22:19 | #34 (permalink) |
Major Poster Join Date: Apr 2010 Location: Scarborough, United Kingdon. Age: 55
Member: 1285693 Status: Offline Thanks Meter: 5 | Hi Halim, I have always used copper and artic silver MX2 thermal compound when reworking a chip. Pentu is right that its definately best to replace the chip if you can, but this isnt always an option. Copper does reduce the running temps and adds a little more pressure to the chip if you get ones the right thickness, silicone pads allow more movement as the chip heats and cools. If using copper put some kapton tape over the components on top of the chip. Also copper shims are hard to fit under some heatsinks, HP TX2000 is a good example. |
The Following User Says Thank You to Kujoy For This Useful Post: |
03-31-2011, 22:30 | #35 (permalink) |
Member: 1285693 Status: Offline Thanks Meter: 5 | When reworking a chip you need to keep the thermal stresses to a minimum. I always warm the chip before sticking a soldering on it for example and be very careful to make sure the chip is dry. When cleaning the old solder off use plenty of quality flux that will take the temp of the soldering iron without burning and add lead solder to bring the melting point of the lead free down. I tend to use a blade tip at about 300 deg C, i know others that use 325 deg C without any problems but you have to work quickly. Hope that helps. |
04-09-2011, 10:25 | #36 (permalink) | |
Copper really reduce the heat as we can feel that the ****ed out wind from inside laptop is not really hot as before..anyway some say the copper can cause fail for use in laptop,,pls see in this link Doubleclickittofixit.com Laptop Motherboard Reflow Repair Service tq | |
04-24-2011, 03:28 | #37 (permalink) | |
Junior Member Join Date: Apr 2011
Member: 1562036 Status: Offline Thanks Meter: 0 | Quote:
For my work I use the ACHI IR-PRO SC, Aoyue 968 and T-8280 machines. If anyone has had success repairing lifted pads on Xbox 360s or PS3s, please post pictures and more info on how you did it. I will be trying the method described here. Thank you! | |
11-14-2012, 23:56 | #38 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1839547 Status: Offline Thanks Meter: 0 | One place where I found a good "how to video" on pad repair is : PCB Pad Repair Video | BEST, Inc. - YouTube Bob |
02-13-2017, 10:08 | #39 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2683809 Status: Offline Thanks Meter: 0 | BGA pad I have and Intel rg82855om nirthbridge ,and when i desoldered it i lifted 3 pads, Oone of them is a vss so i dont care it ,but the two other is a hi4 and hi8 wich means Hub Interface for Cmos IO or simply Hub Interface ,is it vital or not? I very thankful if anyone can help me |
03-22-2017, 12:32 | #42 (permalink) |
Junior Member Join Date: Jan 2017 Location: Illinois, USA
Member: 2676834 Status: Offline Thanks Meter: 2 | If BGA pads or traces have been damaged due to improper part removal techniques or mechanical "digging" into the circuit board, Various certified companies can repair these damaged circuit patterns to as a "good as new" condition. If a critical area array device needs to have its pads and or traces repaired prior to reballing then these can also be repaired usingh proper tools. |
The Following User Says Thank You to soldertraining For This Useful Post: |
Nokia "Contact Service" Repairer | Dirk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-04-2011 05:45 |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
Contact Service Repairer 1.2 by Bartek | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-23-2011 09:00 |
5110 Contact Service Repairer via MBUS/FBUS | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-15-2010 04:17 |
New!! Nokia Flash Checksum And Contact Service Repair | HookerGsM | Main Sales Section | 0 | 01-02-2001 10:12 |
