Panasonic Panasonic-News... |
10-20-2003, 23:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | gd87 wrong unlock-dead-help please:((( i have a gd87 that was unlock wrong way,now the mobile is dead, the battery has already been removed, when i try to flash with windmodo i get error that"failed to open comport" n the time starts ,on other side of mobile the green light is on and on display :FLASH LOADER GD87 VERSION1.4,PARAMETERS: IS WRITTEN i know i have to reprogram in labtools, can any1 plz guide me how to do so? what to remove what flash to use etc thanks alot bye |
10-21-2003, 16:05 | #2 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Croatia and occasionally MARS
Member: 7828 Status: Offline Thanks Meter: 3 | Very easy !!! that is, if you have right equipment and know how to operate HOT Air Station !! FLASH IC is NEC !! and is easily recognized, it is BGA IC , so if you take correct steps as many people have already said, no need to re-ball Flash IC, it can be soldered back to phone with existing balls !!, just use abundant amount of FLUX ! regards Commselect Inc. www.commselect.net |
10-22-2003, 00:03 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | i flashed some gd87 ,,,, but on 1/5 of flashing battery died scary isn't it ? i took aout battery ... connected to +5V for 15 minutes put it back .... started flashing from WinModo and pressed power on phone flashing process started ... and finished OK i unlocked it and my friend is now using it. SO .... new panasonics CANNOT BE KILLED while flashing with WinModo .... unless you are an IDIOT. bye. Alex.
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
10-22-2003, 08:59 | #5 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Quote:
WBR Syed | |
10-22-2003, 10:14 | #6 (permalink) |
No Life Poster Join Date: Mar 2003 Location: pakistan Age: 45
Member: 23939 Status: Offline Thanks Meter: 14 | just set buad rate this is for muhammed. when winmodo give message com1 open. u have to set ur baud rate at 115200. i think this will solve ur problem. |
10-22-2003, 15:33 | #7 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | Yes if u get something written on the phone display then phone is not yet dead !!!!!!!!!!!!!!! check file and baudrate on the Winmodo !! WBR Syed |
k750i after unlock dead HELP!!!! | flachagsm | Sony Ericsson Hardware Repair | 6 | 10-28-2006 10:37 |
v690 unlock dead help | danex_2000 | Infinity-Box | 5 | 10-23-2006 17:17 |
s400i wrong unlocking plz help | arwanis | Trident/AGERE Platform | 4 | 09-22-2006 10:46 |
ct 3558 wrong unlock.DEAD.HELP ME | zonetrichur | Philips | 1 | 05-10-2006 12:25 |
T190 Dead After Wrong Unlock...need Help | mujie | Motorola ODM | 2 | 12-23-2002 07:33 |
