09-09-2008, 15:20 | #1 (permalink) |
Temporary banned !! Join Date: Sep 2004
Member: 83645 Status: Offline Thanks Meter: 111 | A8+ Need help - Pinout Needed Info: Model: A8+ dual sim CPU : MT6226 Connector: 1 x 18 Thats all the information I can give.... TIA |
09-09-2008, 18:07 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
09-19-2008, 12:29 | #6 (permalink) |
Member: 83645 Status: Offline Thanks Meter: 111 | Update to my thread: I managed to find out the rx/tx pins and found out that it is a new firmware. Files has been sent to [email protected]. My question is, is it find if I just go ahead in touch screen calibration even if firmware is new? Hoping for your immediate response.... Thanks! br, |
09-20-2008, 08:12 | #9 (permalink) |
Member: 83645 Status: Offline Thanks Meter: 111 | Results........................................... .......... Code: ==== log: [9/20/2008 11:47:10 AM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F4C1:464A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b06 Version: G60M_HW detecting structure #2... 0 done 44 byte(s) read imei: 35719801218446 connection Ok detecting structure #5 (mode-1)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error: detection failed (20 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 94 sec Remove/Install battery now ! ==== log: [9/20/2008 12:25:35 PM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F4C1:464A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b06 Version: G60M_HW detecting structure #2... 0 done 44 byte(s) read imei: 35719801218446 connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 18 sec Remove/Install battery now ! ==== log: [9/20/2008 12:48:03 PM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! ==== log: [9/20/2008 12:48:32 PM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F4C1:464A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b06 Version: G60M_HW detecting structure #2... 0 done 44 byte(s) read imei: 35719801218446 connection Ok detecting structure #5 (mode-3)... done 158 byte(s) read writing data... verification... verification Ok Finished, time used: 16 sec Remove/Install battery now ! Use only for mode-3 ! Use only for mode-3 ! ==== log: [9/20/2008 12:58:33 PM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 27 sec Remove/Install battery now ! ==== log: [9/20/2008 12:59:49 PM] ==== COM22 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F4C1:464A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b06 Version: G60M_HW detecting structure #2... 0 done 44 byte(s) read imei: 35719801218446 connection Ok detecting structure #5 (mode-4)... 1 2 3 done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 14 sec Remove/Install battery now ! Any suggestions? I haven't format the phone yet... Br, |
09-20-2008, 12:58 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! after all tries phone still ask for touchscreen calibration? if yes- send full flash to [email protected] write subject "touchscreen calibration failed" |
09-22-2008, 07:34 | #11 (permalink) | |
Member: 83645 Status: Offline Thanks Meter: 111 | Quote:
Yes, after all tries, same problem. Ive sent the full flash back-up to the given email address. Hope to hear from you soon. TIA | |
09-29-2008, 22:58 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i was now processing file for new Chinese Miracle and found that file sended by you "SIMC26_06B_PCB01_GPRS_MT6226_S01.G60MTL_G60MV01_0 1B06.bin" was supported and must be done with "touchscreen calibration", mode-2 please check |
need help pinout for my 6300 china | not2link | Infinity-Box | 10 | 02-27-2009 17:17 |
Pinouts E1110 + B110 need help !!Pinouts E1110 + B110 need help !! | AN SI VO DANH | Samsung Hardware Repair | 0 | 12-19-2008 02:25 |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
need help , i need t630 russian flash | Krafk | Sony Ericsson | 0 | 04-20-2005 20:11 |
I Need Help Pinout Xg 1 500 | chitawira | Alcatel & TCL Old Models | 0 | 10-16-2003 07:08 |
