Old 09-09-2008, 15:20   #1 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
A8+ Need help - Pinout Needed
Please, I need RX/TX for this model coz I dont have a pinfinder. I need to calibrate the touch screen of this model.
Info:
Model: A8+ dual sim
CPU : MT6226
Connector: 1 x 18
Thats all the information I can give.... TIA
Old 09-09-2008, 18:07   #2 (permalink)
Member: 130995
Thanks Meter: 35,230
Dear Friend,
There are different "Chinese" phones with the same name but absolutely different hardware exist on market.
Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware, so it's impossible to
give any advice about phone pinout only by phone name.
So we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en
Old 09-10-2008, 04:47   #3 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
I made some pics.....
Old 09-10-2008, 09:23   #4 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
Support Team..... please can anyone have an idea for the Rx/Tx pin? I just needed it very badly... TIA
Old 09-10-2008, 23:38   #5 (permalink)
Member: 130995
Hello,
Did you checked links in my previous message ?
It was some instructions there.
Old 09-19-2008, 12:29   #6 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
Update to my thread:
I managed to find out the rx/tx pins and found out that it is a new firmware. Files has been sent to [email protected]. My question is, is it find if I just go ahead in touch screen calibration even if firmware is new?
Hoping for your immediate response.... Thanks!
br,
Old 09-19-2008, 21:17   #7 (permalink)
Member: 148515
Thanks Meter: 19,544
hello!
thank you for sended file!
you can try all methods for touchscreen calibration even if firmware detected as a new
Old 09-20-2008, 03:54   #8 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
hello!
Thanks for the immediate reply. I'll try and post results later...
Old 09-20-2008, 08:12   #9 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
Results........................................... ..........
==== log: [9/20/2008 11:47:10 AM] ====
COM22 [VCP0] selected
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:F4C1:464A
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: G60MTL_G60Mv01.01b06
Version: G60M_HW
detecting structure #2...
 0 done
44 byte(s) read
imei: 35719801218446
connection Ok
detecting structure #5 (mode-1)...
 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19error:
detection failed (20 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 94 sec
Remove/Install battery now !
==== log: [9/20/2008 12:25:35 PM] ====
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: G60M_HW
 0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-2)...
 done
160 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 18 sec
==== log: [9/20/2008 12:48:03 PM] ====
19200 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
Finished, time used: 17 sec
==== log: [9/20/2008 12:48:32 PM] ====
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: G60M_HW
 0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-3)...
 done
158 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 16 sec
Use only for mode-3 !
==== log: [9/20/2008 12:58:33 PM] ====
error: can't activate test moide
Finished, time used: 27 sec
==== log: [9/20/2008 12:59:49 PM] ====
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: G60M_HW
 0 done
44 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
 1 2 3 done
160 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 14 sec
Any suggestions? I haven't format the phone yet...
Br,
Old 09-20-2008, 12:58   #10 (permalink)
Member: 148515
hello!
after all tries phone still ask for touchscreen calibration?
if yes- send full flash to [email protected]
write subject "touchscreen calibration failed"
Old 09-22-2008, 07:34   #11 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
hello!
Yes, after all tries, same problem.
Ive sent the full flash back-up to the given email address. Hope to hear from you soon. TIA
Old 09-22-2008, 21:00   #12 (permalink)
Member: 148515
hello!
email is recieved, please wait next CM update
Old 09-24-2008, 10:50   #13 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
hello!
Thank you very much for your actions... I 'll wait for the update.....
Old 09-29-2008, 22:58   #14 (permalink)
Member: 148515
hello!
i was now processing file for new Chinese Miracle and found that file sended by you
"SIMC26_06B_PCB01_GPRS_MT6226_S01.G60MTL_G60MV01_0 1B06.bin"
was supported and must be done with "touchscreen calibration", mode-2
please check
Old 10-01-2008, 16:36   #15 (permalink)
Temporary banned !!
Member: 83645
Thanks Meter: 111
I'll try to calibrate in mode-2 and post result later... Thanks Infinity Team for your never-ending support. Appreciate it very much.... GODSPEED!
need help pinout for my 6300 china not2link Infinity-Box 10 02-27-2009 17:17
Pinouts E1110 + B110 need help !!Pinouts E1110 + B110 need help !! AN SI VO DANH Samsung Hardware Repair 0 12-19-2008 02:25
Need help I need pinout for this chinese phone cayton_l Infinity-Box 9 12-03-2008 19:22
need help , i need t630 russian flash Krafk Sony Ericsson 0 04-20-2005 20:11
I Need Help Pinout Xg 1 500 chitawira Alcatel & TCL Old Models 0 10-16-2003 07:08
Page generated in 0.23688 seconds with 10 queries
