03-09-2009, 18:26 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | after formate this phone now is dead Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:85E6:3406 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.088E81D3.[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN_0570D15 5].rpl identification#1 detection finished device-id: 088E81D3 identification#1 protocol ver: 04 ver. sw1: E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN ver. sw2: E558_ZK2ARTF.01.1, AA2E8FFA ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN]... warning: wrong data size at 0x00A23800, retry... read error recovered warning: wrong cs at 0x00B62800, retry... read error recovered file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN]_20090309-155101.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Fail file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_088E81D3_E558_ZK2ARTF_E558_GPRS_MT6226_S 01.01_1.BIN_0570D155_20090309-155112.B0X.bin Finished, time used: 411 sec Remove/Install battery now ! |
03-09-2009, 18:30 | #2 (permalink) |
Member: 102467 Status: Offline Thanks Meter: 24 | other log of ded phone COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:85E6:3406 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ............ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Eeprom/ffs flash: EC257E25082501:FFFFFF00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 79 sec Remove/Install battery now ! |
03-09-2009, 21:01 | #3 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
after unlock my w180 now is dead | hans salim | Rocker Dongle (By Legija) | 2 | 09-05-2008 14:41 |
dead after format this phone.. | alf007 | VE-KING | 5 | 08-16-2008 11:30 |
sagem 226 after unlock now is dead | MOBIFEMI | FuriousGold | 7 | 04-09-2008 20:46 |
6280 after few trys now is dead | ayubalikhan | BB5BOX | 13 | 12-20-2007 22:44 |
L6 after full flash now is dead? | makkah mobile | Smart-Clip | 15 | 11-07-2007 10:50 |
