11-20-2008, 14:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Hert of North KA 25 Age: 42
Member: 115516 Status: Offline Thanks Meter: 113 | Bluetooth C003 need flash file Bluetooth C003 when insert sim restart . after format set is dead plz help COM6 selected module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:8FA2:8DEC high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5AC625A3.[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN_893 E952D].rpl ==================== New firmware detected (2.64) : E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 5AC625A3 identification#1 protocol ver: 04 ver. sw1: E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN ver. sw2: E553_Y7ARTF3.V22.01.1, D26AC176 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\c003\eeprom[E553_Y7ARTF3_E553_GPRS_MT6226_S01.V22_01_1.BIN]_20081119-220515.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_5AC625A3_E553_Y7ARTF3_E553_GPRS_MT6226_S 01.V22_01_1.BIN_893E952D_20081119-220536.B0X.bin Finished, time used: 265 sec Remove/Install battery now ! Hear is reded flash http://rapidshare.com/files/16562679...7.B0M.bin.html thanks |
01-09-2009, 15:39 | #7 (permalink) |
Member: 115516 Status: Offline Thanks Meter: 113 | it is readed this fle from working handset .I flashed still same problem http://rapidshare.com/files/181404229/C003.rar.html |
Bluetooth A5 | omtanwer1 | Chinese Models & Cloned Phones | 1 | 04-03-2010 11:26 |
Bluetooth nony S208 Flash File Help me | .:ISMAIL_BD:. | SpiderMan | 0 | 03-29-2010 15:34 |
Bluetooth Software Which Allows You to Browse Someone Else's Bluetooth Phone | gaz_0001 | Nokia Multimedia | 12 | 04-13-2008 19:17 |
Microsoft Bluetooth Stack + Bluetooth Headset = NO WAY???? | CEO | Bluetooth-Software | 2 | 06-08-2005 20:56 |
USB bluetooth device-Generic bluetooth Radio | aisin | Bluetooth-Software | 1 | 04-26-2005 09:55 |
