12-09-2010, 06:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Which Flash file for this MT6225 phone?? MT6225 CHIP TEXT MT6225A 0816-ABTL KTFU4572 FORMAT FFS LOG.. COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1703:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18A59F00000000 Finalization Done Finished, time used: 34 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ZubairArain For This Useful Post: |
12-10-2010, 14:23 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as you can see- firmware part is damaged and version can not be read out. disassemble phone and check on PCB for short version code. post it here, we will try to find suitable flash file |
12-11-2010, 18:53 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if this is nokia 6500 i would advise to try following file: flashfiles/ChineseMiracle/_MT6225/BB11_PCB01_GPRS_MT6225_S00.BB11_ANX_L9EN_407_08072 9_LGDP4524_GC0306_WI75_CTF_BT_FM__Nokia-6500c_16m_En_Ru_Fr_Es_Id_Th_Vn_Pt_Ar.B0M.bin |
12-12-2010, 06:10 | #6 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Flashed your said file but mobile not powered on. Actully this is XKSSTEL and under LCD there is chit written "XKSSTEL_V1.4_0905.bin". Can't understand which model number this is. Also flashed these two files but same. 1. UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X12_3503_V3 _0_0326_2__XKSSTEL-X11_16m_En_Ru_Fr_Id_Th_Vn_Hi.B0M 2. UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.S3_9225_V2_ 0_0114__XKSSTEL-S4-FM_16m_En_Fr_Es_Pt_Id_Vn_Tr_Ru_Persian_Th.B0M |
12-13-2010, 13:15 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you already tried all available on support. unfortunately,nothing more can be advised try to find same working phone or flash file in any format i will convert it for you |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
