Old 12-09-2010, 06:33   #1 (permalink)
ZubairArain's Avatar
Member: 751908
Thanks Meter: 186
Which Flash file for this MT6225 phone??
PHONE NOT POWERED ON.
MT6225 CHIP TEXT
MT6225A
0816-ABTL
KTFU4572
FORMAT FFS LOG..
COM3 [VCP0] selected
module v3.25
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1703:0001
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18A59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 34 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to ZubairArain For This Useful Post:
Old 12-10-2010, 11:22   #2 (permalink)
Member: 751908
Thanks Meter: 186
InfinityHelp where r U
Old 12-10-2010, 14:23   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
as you can see- firmware part is damaged and version can not be read out.
disassemble phone and check on PCB for short version code.
post it here, we will try to find suitable flash file
Old 12-11-2010, 10:21   #4 (permalink)
Member: 751908
Thanks Meter: 186
Written on PCB is text below.
REV0001 080729
Wants suitable flash file.
Old 12-11-2010, 18:53   #5 (permalink)
Member: 148515
hello!
if this is nokia 6500 i would advise to try following file:
flashfiles/ChineseMiracle/_MT6225/BB11_PCB01_GPRS_MT6225_S00.BB11_ANX_L9EN_407_08072 9_LGDP4524_GC0306_WI75_CTF_BT_FM__Nokia-6500c_16m_En_Ru_Fr_Es_Id_Th_Vn_Pt_Ar.B0M.bin
Old 12-12-2010, 06:10   #6 (permalink)
Member: 751908
Thanks Meter: 186
Flashed your said file but mobile not powered on.
Actully this is XKSSTEL and under LCD there is chit written "XKSSTEL_V1.4_0905.bin". Can't understand which model number this is.
Also flashed these two files but same.
1. UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X12_3503_V3 _0_0326_2__XKSSTEL-X11_16m_En_Ru_Fr_Id_Th_Vn_Hi.B0M
2. UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.S3_9225_V2_ 0_0114__XKSSTEL-S4-FM_16m_En_Fr_Es_Pt_Id_Vn_Tr_Ru_Persian_Th.B0M
Old 12-12-2010, 21:23   #7 (permalink)
Member: 148515
hello!
any model name on IMEI label?
Old 12-13-2010, 06:18   #8 (permalink)
Member: 751908
Thanks Meter: 186
There is no IMEI or Model lable on phone. Is there any chance to get file ?
Old 12-13-2010, 13:15   #9 (permalink)
Member: 148515
hello!
you already tried all available on support.
unfortunately,nothing more can be advised
try to find same working phone or flash file in any format
i will convert it for you
Page generated in 0.19745 seconds with 9 queries
