12-31-2008, 13:41 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not wrks try to make "complete" format (if this option exist) 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
12-31-2008, 23:31 | #3 (permalink) |
Registered User Join Date: Aug 2004 Age: 58
Member: 76331 Status: Offline Thanks Meter: 5 | but sir ... i was do like you explain ... but always like this picture away ... i dont have tools like pinfinder yet ... its still can use ... by the way i also change tx rx but still same ... http://www.forum-indoflasher.com/vbb...1&d=1230760940 http://www.forum-indoflasher.com/vbb...2&d=1230762389 sorry i'm upload from another link cause i cant upload on this forum ... |
[Need Help] How to change IMEI N95-1 | destronid | Infinity-Box | 8 | 12-11-2010 19:01 |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
How to fomat fg box | luyanda | FuriousGold | 1 | 08-05-2009 06:04 |
