Old 01-18-2009, 02:51   #1 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry Loading failed, probably damaged data file
i facing problem with InfinitySetupMain_v2.15a, InfinityUpdate_ChineseMiracle_v2.74, MModule v2.60
readed log
COM10 [VCP1] selected
module v2.74
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:BF03:0008
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:08000000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 080000000800000018F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V034.BIN
ver. sw 2: S4_TOSHIBA_EFIAPVRHMIT_V034, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs/eeprom size detection
error: can't detect ffs/eeprom address/size
error: chip layout not detected
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Finished, time used: 27 sec
Remove/Install battery now !
Loading file v.01...
i select flash file BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V035__Sigmatel-S3_16m_En_Ru_Fr_Hu_It_Ml_Id_Vn_Tr_Farsi_Ar.bin getting me error Loading failed, probably damaged data file
phone flash file BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.S4_TOSHIBA_EF IAPVRHMIT_V034.BIN
pls. upload this flash file
why getting me this error Loading failed, probably damaged data file
thanks
Old 01-18-2009, 12:38   #2 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
no ans. from infinity tem
Old 01-18-2009, 18:45   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
check if you fully downloaded flash file. Compare sizes
Old 01-18-2009, 21:39   #4 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
yes i download first 16mb file
anyway i download 8 mb flash file & flash phone work fine but how to flash with 16 mb flash file pls. tell me
Old 01-18-2009, 22:52   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
16m file in support area was damaged, new file was uploaded.
Download flash file again from "main" support area.
Alway's Show - error: data error ! Loading failed, probably damaged data file amol_sm Infinity-Box 4 09-12-2009 00:20
Damaged data file in support! JoAoOpAuLo Infinity-Box 3 05-09-2009 18:47
6300 RM217 Probably Damage Data File zahidnawaz Infinity-Box 2 12-30-2008 07:34
N95 1-SIM 2-SLIDER N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32 Damaged data file fastlink Jogja Infinity-Box 4 12-10-2008 18:29
LOAD FAILED PROBABLY DAMAGED DATA FILE...why showme this???? mangofree Infinity-Box 6 09-29-2008 21:34
Page generated in 0.15845 seconds with 9 queries
