Old 05-30-2009, 17:47   #1 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
need flash file s91
I flash cect U90+ slide set with wrong flash files, now set is on but LCD display is white. please someone give its OK flash file.
it has mt6226ba chip.
on board = S91-QHMB0004B-PCB
ON STRIP= S91-FPC
ON LCD= TFT 8K0023FBC-A1
Old 06-01-2009, 00:00   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must open with notepad operation.log file which is located in Chinese Miracle folder.
scrool it from up from end and find First operation with this phone.
there you will see Original software version.
post it here, we will advice flash file which will restore your phone
Old 06-01-2009, 15:27   #3 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
I think this you ask for
==== log: [5/23/2009 12:51:51 PM] ====
COM12 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:EF0D:6D2C
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5F352FC5.[A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517.BIN_986E0B6B].rpl
identification#1 detection finished
device-id: 5F352FC5
identification#1 protocol ver: 04
ver. sw 1: A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517.BIN
ver. sw 2: S91B_YY01_01_06.48.1.1T01M0517, 94F49167
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: A8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01 M0517__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\A8_PCB01_GPRS_MT6 226_S01.S91B_YY01_01_06_48_1_1T01M0517__ffs_200905 23-125750.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.S91B_YY01_01_06_48_1_1T01M 0517__system_log_5F352FC5_986E0B6B_20090523-125810.B0X.bin
Finished, time used: 375 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
please help me as soon as possible, thanx for reply.
Old 06-01-2009, 21:39   #4 (permalink)
Member: 148515
hello!
try this flash file:
flashfiles/ChineseMiracle/_MT6226/CM_Cect-V400_N80__A8_PCB01_GPRS_MT6226_S01.S91_YY01_01_06_ 48_1_2T03M0212_16m_En_Cn.B0M.bin
unfortunately, we dont have exactly same flash file
Old 06-04-2009, 15:20   #5 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
LCD ok but sim problem
Thank you for this file. Now LCD ok but i have another problem. when i insert sim in set and power on it, set start and off , without sim the set is start ok and open menu, everything ok, but when i use sim set starts, show his welcome screen and then off.
please help me in this regard as soon as possible.
Old 06-04-2009, 23:00   #6 (permalink)
Member: 148515
hello!
use safe format, if not help- complete
post result
Old 06-08-2009, 05:54   #7 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
sim ok
thanks, .................................................. ...............
Old 06-14-2009, 14:32   #8 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
lcd ok but sim is not working ok
without sim phone is ok, but when i insert sim phone first off, then i start again, sometime phone is running with sim but many time phone shut down.
i flash the phone with safe mode and also complete flash, but problem is same.
with sim phone starts and them off.
please help me in this regard.
Old 06-14-2009, 18:36   #9 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
Did you tried to make 112/emergence call without sim card ?
What is the result ?
Old 06-16-2009, 07:44   #10 (permalink)
Member: 763332
Sonork: rashid
Thanks Meter: 3
emergency call
i dont have emergency call service, but when i dial , set dialing but after 3,4 seconds call ended
Old 01-30-2011, 07:37   #11 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
Here is tested flash file : Sigmatel Gild Fxd S91 flash file 100% tested.
This file for Spiderman box only.
Sigmatel Gild S91 Spiderman 100% tested.bin
Request to Infinity team to convert & upload to support site.
Thanks
The Following User Says Thank You to nakshatra For This Useful Post:
NKTEL A200 flash file in Spider man box need flash file? >>.123.<< SpiderMan 15 11-12-2010 16:12
E66 nokia need flash file no flash file in support lilong_lee Infinity-Box 11 02-07-2010 01:51
!!!!! Needed, flash file for 8120 02 sfi file !!! stemo FuriousGold 2 03-11-2009 20:08
L7i need flash file and boot file aukonline Smart-Clip 3 03-10-2009 11:15
i need flash file and database file for t190 v 1.71 becuase nanana Motorola ODM 0 08-17-2002 11:37
Page generated in 0.23025 seconds with 9 queries
