06-16-2008, 17:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: jb cell world Age: 47
Member: 70916 Status: Offline Thanks Meter: 56 | nfinity team pls help mpeg4 p888 thank in advance sir help me urgent |
06-18-2008, 06:01 | #6 (permalink) |
Member: 70916 Status: Offline Thanks Meter: 56 | COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer: wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 1637 sec Remove/Install battery now ! |
06-18-2008, 17:28 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you are working with 6205 MCU, it is Second MCU (MCU_b) in order to reapir restaring - you must find pinout for First MCU (MCU_a) and format it |
06-23-2008, 14:26 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to find pinout for 1st CPU and make format for 1st CPU. You need to run PinFinder again, disable pins that you already found and make pinout detection process again. Please, see here how to exclude some pins from detection process: http://www.infinity-box.biz/download..._PinFinder.pdf |
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? | vintel | Infinity-Box | 4 | 03-07-2010 11:29 |
infinity team pls help mpeg4 p888 | jbbasha | Infinity-Box | 1 | 03-27-2008 16:43 |
UST PRO Team...PLS Help help help help | xxemoxx | UST Pro II | 9 | 09-19-2007 19:55 |
Furious Team Pls. help!!! | CELLCORE | FuriouS II | 6 | 12-29-2004 16:42 |
FURIOUS TEAM, PLS help me | Leo140 | FuriouS II | 1 | 12-27-2004 13:30 |
