Old 06-16-2008, 17:15   #1 (permalink)
Member: 70916
Thanks Meter: 56
nfinity team pls help mpeg4 p888
hi infinity team i have strange problem china mpeg4 p888 restart with and without sim and iam unable to format full as well as safe mode so even to read the flsh file iam unable to boot bcos before complete the boot it is starting and again restart and also to flash iam unable to know the firware so kindly help me i have two pieces to solve the issue
thank in advance sir
help me urgent
Old 06-16-2008, 17:51   #2 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
what type of cpu type in your set.pls upload phone picture
Old 06-16-2008, 18:01   #3 (permalink)
Member: 70916
Thanks Meter: 56
The cpu type is mt6205
Old 06-16-2008, 22:37   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post log of unsuccesfull boot
Old 06-18-2008, 01:50   #5 (permalink)
Member: 744651
Thanks Meter: 20
Mpeg4 P888
Hi,
I have the same problem also, you can't do anything with the handset, because it just keeps switching on and off, once it has a power source.
hello!
Old 06-18-2008, 06:01   #6 (permalink)
Member: 70916
Thanks Meter: 56
hello!
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
error: no any expected answer
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 1637 sec
Remove/Install battery now !
Old 06-18-2008, 17:28   #7 (permalink)
Member: 148515
hello!
you are working with 6205 MCU, it is Second MCU (MCU_b)
in order to reapir restaring - you must find pinout for First MCU (MCU_a)
and format it
Old 06-19-2008, 14:22   #8 (permalink)
Member: 744651
Thanks Meter: 20
Hi,
Thanks for the response, how do i find that PIN out?
Old 06-19-2008, 22:01   #9 (permalink)
Member: 148515
hello!
how did you find CPU2 pinout?
Old 06-22-2008, 15:36   #10 (permalink)
Member: 70916
Thanks Meter: 56
i had findout through the pinoutfinder.
Old 06-23-2008, 14:26   #11 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You need to find pinout for 1st CPU and make format for 1st CPU.
You need to run PinFinder again, disable pins that you already found and make pinout detection process again.
Please, see here how to exclude some pins from detection process: http://www.infinity-box.biz/download..._PinFinder.pdf
Old 06-23-2008, 16:00   #12 (permalink)
Member: 70916
Thanks Meter: 56
yes its working iam able to find the other pinouts and the mobile is ok another time the infinty has proven for the best support
thanks again
Old 10-13-2008, 19:21   #13 (permalink)
Member: 234985
mpeg4 p888 flash file need plz argent thank you
Old 10-13-2008, 21:45   #14 (permalink)
Member: 148515
hello!
post your phone version readed in "read detailed information" mode.
we will advice flash file
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? vintel Infinity-Box 4 03-07-2010 11:29
infinity team pls help mpeg4 p888 jbbasha Infinity-Box 1 03-27-2008 16:43
UST PRO Team...PLS Help help help help xxemoxx UST Pro II 9 09-19-2007 19:55
Furious Team Pls. help!!! CELLCORE FuriouS II 6 12-29-2004 16:42
FURIOUS TEAM, PLS help me Leo140 FuriouS II 1 12-27-2004 13:30
Page generated in 0.23808 seconds with 9 queries
