Old 03-28-2009, 16:03   #1 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Nokia N98+ Supported ?
Hello all, I would like to know if this model Nokia N98+ is supported or not with infinity box? If yes what are the pinout ?
Thanks in advance.
Old 03-28-2009, 16:06   #2 (permalink)
Member: 243158
Thanks Meter: 25
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 03-28-2009, 19:26   #3 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Originally Posted by abdel7650 View Post
hello!
Correct, Language set to English, then it supported, do u know a pinout for cable? it look like Samsung D800 cable.
Thanks in advance
Old 03-29-2009, 18:04   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Thanks in advance
Hello,
Where is GND and CHARGE pins at phone connector ?
Old 03-29-2009, 21:10   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i would advice to use pinfinder, but if you dont have i can teach how to find pinout using multimeter
Old 03-30-2009, 15:38   #6 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
hello!
Hello, I dont have pinfinder, but you can show me how to find pinout using multimeter. Im on my office and ready to work on it. waiting for ur reply.
thanks
Old 03-30-2009, 20:36   #7 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached, will work on powered phone as well as not powered_On)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
nokia n98 tv mobile yacine ben Infinity-Box 1 04-14-2008 17:51
Page generated in 0.16685 seconds with 9 queries
