Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 05-29-2009, 19:28   #1 (permalink)
Member: 76533
Urgent please cvp flash nokia e71 2x5
The one problem with the flash Nokia e71 mt 6225 2x5
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: TD.E11ATV.E11.F1.1.0.T04D090314.BIN
ver. sw 2: TD.E11ATV.E11.F1.1.0.T04D090314, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detection phase #1...
Old 05-29-2009, 20:17   #2 (permalink)
Member: 319827
We are here.............................................. .................................................. ............
Old 05-29-2009, 20:52   #3 (permalink)
malpinssa's Avatar
Member: 476420
Sonork: 100.1605239
bro i wellgive you easy method to flush all chaines phone.its same with u phone
1. If you don't know original/required firmware version: check phone PCB to find any reference to originl firmware version.
2. Many phones has different name but the same hardware, so main criteria to find correct flash file is firmware version but not phone model name.
3. Flash file name consist of the next parts:
file name: E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1__Cect-T689_16m_En_Fr.B0M.bin
"E550_A5FRENCHBT_E550_GPRS_MT6226_S01.01_1": firmware version (with CPU info)
"Cect-T689": model name
"16m": flash chip size: 4Mb, 8Mb, 16Mb, 32m, 64m
"En_Fr": languages inside firmware (English, French)
"B0M.bin": firmware file extension
"B0E.bin": eeprom/ffs file extension
file name: CM_GPRS-K588_Y560_JGH_PCB01_GPRS_MT6227_S01_16m_En_Cn_w_ee prom.B0M.bin
"CM": "ChineseMiracle"
"GPRS-K588": model name
"Y560_JGH_PCB01_GPRS_MT6227_S01": firmware version (with CPU info)
"En_Cn": languages inside firmware
"w_eeprom": contain eeprom/ffs inside file, it's "full flash"
The Following User Says Thank You to malpinssa For This Useful Post:
Old 05-30-2009, 13:56   #4 (permalink)
Member: 76533
Thanks for the reply, but Flash 6225 I hope you did not understand the explanation
Old 05-30-2009, 14:16   #5 (permalink)
Member: 76533
Flash did not understand the kind of help I hope
OM3 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:2A03:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:FFFFFF00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support (mt62xx@gmail.com) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
can't detect fat record name location
error: ffs/eeprom detection failed: element #1
detecting ffs/eeprom structure pass 2...
error: ffs/eeprom detection failed element #2
Check firmware integrity Done
Check firmware content ...
detecting firmware version...
done
warning: can not detect firmware version
if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
done
detecting product-id...
done
detecting languages...
error: can't detect language parameter #1
warning: can not detect language names
if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation.
Check firmware content Done
Backup required data ...
Finished, time used: 220 sec
Remove/Install battery now !
Old 05-31-2009, 23:27   #6 (permalink)
Member: 148515
hello!
what problem did you have with your phone?
Old 06-01-2009, 20:44   #7 (permalink)
Member: 76533
hello!
Thank you, the latter follow-up
Hello
I Pfermat Li optimize the machine did not ignite Search Flash
Old 06-01-2009, 21:49   #8 (permalink)
Member: 148515
hello!
sorry, i still dont get what problem do you facing.
have you tried to solve your problem by format FFS?
Old 06-02-2009, 10:52   #9 (permalink)
Member: 76533
hello!
Hello
You in every way but to no avail now the phone is not working I Assistant e71 tv
urgent please flash nokia e71 2x5 plz bahsar333 Chinese Miracle & PinFinder 7 07-22-2009 16:00
Can flash Nokia E71-2 RM-357 With MT-Box??? svchost MT-BOX 2 02-26-2009 23:27
Urgent please help on nokia 2310 software ok but no power on with battery mobilecitycbk Nokia Hardware & Hardware-Repair Area 1 11-15-2007 12:09
[URGENT!!!]Where to flash Nokia 9290 ROM? geniusb Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-15-2005 23:22
Page generated in 0.74125 seconds with 12 queries
