02-15-2008, 15:28 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Everywhere
Member: 249836 Status: Offline Thanks Meter: 18 | 6280 unlock failed Reading phone info ... Type: RM-78 Version: V_03.41_14-01-06_RM-78_(c)_Nokia IMEI: 357926000290127 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357926000290127_Locked_Keycnt_0_Fbuscnt_10__V_0 3.41_14-01-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. Try every way but still can't unlock. |
02-15-2008, 20:19 | #3 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
ur counter is 10/10 so write back-up 308 PM.............. RM-78_357926000290127_Locked_Keycnt_0_Fbuscnt_10__V_0 3.41_14-01-06_RM-78_(c)_Nokia.bin thanks reaz. | |
02-15-2008, 20:36 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | Make test point very very carefully and try again and again until phone going to unlock.Wish your good luck... hackerbd ************* |
02-18-2008, 12:42 | #5 (permalink) |
Member: 249836 Status: Offline Thanks Meter: 18 | sINCE I update with version 3.7 I get error. I try do another 2 6280 with flash chip SEC **** ETA i get error. I try change new TP point cable but still the same. I done so many, I remember by heart and normal it take me 5 minute to unlock a 6280. I think it the new version 3.7. Anyone encounter this problems???? |
02-18-2008, 13:01 | #6 (permalink) | |
Member: 249836 Status: Offline Thanks Meter: 18 | Quote:
It wouldn't let me unlock it qithout WRITING PM. Cheers | |
02-18-2008, 13:11 | #7 (permalink) |
Freak Poster Join Date: May 2007
Member: 518708 Status: Offline Thanks Meter: 67 | Hy! You wrote that your phone has sec****eta chip. i also had problems with 2 phones with sec chip. so i tried a lot of methods. I selected SPANSION chip on those 2 phones with sec****eta and i was able to unlock them. With one phone i connected ground like on the pic, and on the other phone i connected ground on vibra. best regards and good luck p.s also try to use an other sw version i unlocked those two phones with v0.25 |
02-20-2008, 22:23 | #8 (permalink) |
Junior Member Join Date: Sep 2007 Location: Austria
Member: 588991 Status: Offline Sonork: 100.1590416 Thanks Meter: 0 | I have also problems with 6280, usually you should flash do V 6.10 and then no errors. I have testet many 6280, with 6.10 i all unlock. Greets |
02-28-2008, 07:01 | #12 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Just Use Good Microscoppe, And Very Thin Needle (for Diabetic) śWork 10000% Tested |
02-29-2008, 14:41 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2006 Location: spansion chip
Member: 267822 Status: Offline Sonork: 100.1605213 Thanks Meter: 64 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357603000667691 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357603000667691 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603000667691_Locked_Keycnt_0_Fbuscnt_0__V_03 .40_20-12-05_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2229900093172790 Block 1: OPEN Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thinx bb5 box!!! br abdelfattah |
6280 Unlock Failed..???? | communication_expert | MT-BOX | 2 | 01-07-2008 06:11 |
* * * * Nokia 6280 Unlock Fail * * * * | E_H | BB5BOX | 20 | 01-07-2008 00:18 |
6280 unlock fail! | tuhingr | BB5BOX | 3 | 11-23-2007 12:33 |
6280 Unlock fail ????? | CEPHASTANESİ | BB5BOX | 5 | 11-17-2007 23:51 |
6280 unlock failed!!!!!!!!!! | Jr Telecom | BB5BOX | 31 | 11-03-2007 11:49 |
