02-24-2008, 09:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Insert provider code directly using BB5box? mate is there any chance to implement this feature? For example got a 6500s (not supported yet) but have the provider code. I would like to enter the code directly as client exhausted all the 3 tries. thanks |
03-11-2008, 23:02 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
i was looking in forum and not found how to do it counter 3/3 and can t reset it to enter code with kbd its a 6120 | |
03-12-2008, 10:49 | #7 (permalink) | |
Freak Poster Join Date: May 2007
Member: 518708 Status: Offline Thanks Meter: 67 | Quote:
you need to select com1 in the cfg. and then connect phone to dku2/miniusb, connect the red and black power like you would do for tp unlocking and dejan unlocker will find your phone and you can enter unlockcode by fbus. best regards | |
03-12-2008, 20:25 | #8 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: I'm back to business
Member: 184793 Status: Offline Sonork: 100.1574609 Thanks Meter: 45 | Quote:
just use JAF or multibox to enter code using cable Br LordMen007 | |
03-12-2008, 22:42 | #9 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | 6120 counter 3/3 0/10 unlocked with log entered with bb5box as ftdi com and dejan free soft make a file caled imei_BB5.psw where imei is imei of he phone and put it in sw folder. run dejan soft click read phone than sp unlock phone unlocked that's fine |
03-13-2008, 23:29 | #11 (permalink) | |
personally i used cables of bb5 box, mobile in test mode it took 2 sec | |
03-14-2008, 09:23 | #12 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | i am getting in test mode ok but my problem is that Dejan software is not reading the phone. Is it possible to just use the CA-101 cable (connected to a USB port) or have i got to use the 6500 microusb connector to the phone to be able to read and write to it? i got it recognised in the device manager but cant get it to be read via the software. thanks |
03-15-2008, 09:29 | #13 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | Quote:
Go to control panel with your bb5box connected, look what port number is assigned to your bb5 box, go to cfg file in DK folder, rplace the port with your bb5 port. It should work. if you have alrady done that then try and flash the phone. Br Kenny | |
03-15-2008, 09:54 | #14 (permalink) |
Freak Poster Join Date: Oct 2003 Location: nigeria
Member: 41664 Status: Offline Thanks Meter: 37 | 6500c Just to let you guys know and if u can help out on this .... I have a similar problem with my 6500c. key counter blocked ......and i try to put code from provider by cable.... I tried with DEJAN FREE + the usb cable that came with the phone. Got the phone to local mode by connecting the RED, YELLOW & groung connector from BB5BOX cable. I can read the phone with the DEJAN FREE in that mode ...but cant get to do the SP unlock....it says "wrong password". Do u think the code is wrong ...or something difffrent in this phone ..........??? Let me here what u think is the problem ...maybe i need to talk to my code provider........(allgsm...) justx24 |
6110 Navigator unlock using BB5Box or other | majid | Nokia Base Band 5 ( BB-5 ) | 3 | 01-12-2008 09:31 |
Problems using BB5Box and BB5Box microscope | tito millo | BB5BOX | 2 | 12-06-2007 04:35 |
Tips, BKM (Best Known Method) in unlocking BB5 phone using BB5Box | glicos | BB5BOX | 0 | 09-25-2007 18:02 |
Step by Step how to Unlock BB5 Phone Using BB5BOX By Raskal | Ron2pet | BB5BOX | 12 | 09-21-2007 09:54 |
If you got unlock codes from your provider and you used all yours 3 attempts | hassan35278 | Nokia Base Band 5 ( BB-5 ) | 2 | 05-14-2007 07:56 |
