04-24-2009, 22:24 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: The Netherlands Antilles Age: 50
Member: 179391 Status: Offline Thanks Meter: 57 | Nk 6300 V6.60 Unlock Problem Phone had software problem. I did flash it, MCU, PPM, CNT and Good PM Now the phone is :Phone restricted I use BB5Box for unlocking. I get this result. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3548260XXXXXXXX SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_354826010320745_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Unlock fail. Please try again. What can I do? Phone was network locked, but now it do not accept the simcard it was locked to. |
04-24-2009, 22:41 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | You are still using BB5Box for unlocking phones?????????? ...the forum is full of free NO TP unlock solution for this model and you are using the hard one... |
6300 v6.01 unlock spansion | KRIZA | BB5 Box by D.K. | 13 | 10-12-2008 19:27 |
6300 v6.60 | junkmonkey | Nokia Base Band 5 ( BB-5 ) | 3 | 08-05-2008 08:48 |
NK 2610b RH-87 V6.80 unlock problem | Diesel_sh | Universalbox | 11 | 06-30-2008 12:58 |
Nk 6133 v5.60 Unlocking Problem, Help | citifone | J.A.F. V-SPEC | 6 | 12-14-2007 16:29 |
MC 60 Unlock Problem Now it is dead.. | HackO | S-Gold Based Phones | 1 | 01-26-2005 09:21 |
