Universalbox Universalbox Official support area |
06-19-2008, 05:19 | #1 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 196633 Status: Offline Thanks Meter: 8 | NK 2610b RH-87 V6.80 unlock problem I just bought the UB today so I am new here. I have a NK 2610b RH-87 V6.80 and need to be unlocked. I use fbus cable to hook the phone, read info, so far so good. problem is when I try to unlock it, show as below log in red TDCT4UnlockThread started at: 2008/06/18 20:55:05 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Reading Info... MCU Version: V 06.80 Date: 18-10-07 Type: RH-87 (Unknown) Additional_1: (c) Nokia. PPM Version: V 06.80 Date: 18-10-07 Type: RH-86_87 (Unknown) Additional_1: (c) Nokia. Pack: MCR Product code: 0554956 Production serial: RHK984413 Hardware version: 7201 Security code: 12345 Original IMEI: 011503-00-017252-8 IMEI: 011503-00-017252-X Asic type: 11 Profile bits: 800000000001000B Lockinfo: 3101700000000000 SIMLock service: SIMLOCK SERVER [010000060C08] -------------------------------------------------------------------------------- TDCT4UnlockThread finished at: 2008/06/18 20:55:08 Terminated with error: Patch file [RH-87_06.80.pat] for this version not found [00011A82]. 00011A86 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBEEGJN9] QUESTION 1: Where can I find the corresponding file of RH-87_06.80.pat QUESTION 2: Why there is NO "patch" folder under the uni\file\nokia\dct-4 BR Diesel |
The Following User Says Thank You to Diesel_sh For This Useful Post: |
06-19-2008, 09:26 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: IRELAND
Member: 87357 Status: Offline Thanks Meter: 9,457 | First Update Your Box. then Flash with another supported Version and Do Unlock Nokia 2610, 2610b: RH-86, RH-87 RH-105, (5.23, 5.90, 6.20, 6.80) Regards F@iSaL |
The Following User Says Thank You to MobilesDoctor For This Useful Post: |
06-19-2008, 13:38 | #3 (permalink) |
Member: 196633 Status: Offline Thanks Meter: 8 | Hi, Thank you for your reply. I had updated the box, and download Nokia file RH-87 5.65, 6.80 When I try to flash the phone, BOX tell me. TDCT4FlashPhoneThread started at: 2008/06/19 05:35:00 -------------------------------------------------------------------------------- MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Input power: 16.82V OK. Hardware ID: 3040 -------------------------------------------------------------------------------- TDCT4FlashPhoneThread finished at: 2008/06/19 05:35:03 Terminated with error: No available bootloader for this ID [00011224]. 0000040D. 00000101. 0000020C. 0001023A. 000110D0. 000111A2. 00011570 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBEEGJN9] Anything I can do? |
06-19-2008, 13:44 | #4 (permalink) | |
Member: 87357 Status: Offline Thanks Meter: 9,457 | Quote:
Check Your Cable it is working Good Or Not Regards F@iSaL | |
06-19-2008, 14:55 | #7 (permalink) |
Member: 87357 Status: Offline Thanks Meter: 9,457 | Today I was unlock of this Model with out any problem Here is Log File Code: MCU Nokia Version: 1.124, and up to date. SMCU Nokia Version: 1.42, and up to date. Reading Info... MCU Version: V 05.65 Date: 06-07-07 Type: RH-87 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.65 Date: 06-07-07 Type: RH-86_87 (Unknown) Additional_1: (c) Nokia. Pack: MTM Product code: 0556402 Production serial: OB1414302 Hardware version: 7001 Security code: 12345 Original IMEI: 011374-00-186444-2 IMEI: 011374-00-186444-X Asic type: 11 Profile bits: 800000000001000B Lockinfo: 3102000000000000 Lock version: 1 SIMLock service: SIMLOCK SERVER [010000060C08] Writing SP info Failed, patching software... Connecting to server: US3 Asking service availability... Connecting to server: US3 Credits: ***X Credits left: ***X Input power: 4.70V OK. Hardware ID: 3040 Boot Loader: u3_2nd.fia 2 kB Version: 4.69.0 Supported Hardwares: [3040, 2292, 3162, 3166, 316A] Max Flash Devices: 2 Flash ID 1: 00EC22E8 - 0000 Rev: 7121 Manufacturer: Samsung MSB: 01 SectorSize: 0x010000 Flash ID 2: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 02 SectorSize: 0x000001 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flash Loader: u3_amd.fia 29 kB Version: 4.69.0 Supported Hardwares: [3040, 2292, 3162, 3166, 316A] ASIC Type: 11 MSID: 84-32299ECE1D9360B6DAFC43B4 CobbaID: 008CA026; 1821DA60 FAID: DE61923236068A9DBF98AE9E Erase time: 3,0 sec. Flashing file: RH-87_05.65.imp Flash time: 4,1 sec. After MCU Flash Delay: 5000 msec. Total time: 22,8 sec. Reading Info... MCU Version: V 05.65 Date: 06-07-07 Type: RH-87 (Unknown) Additional_1: (c) Nokia. PPM Version: V 05.65 Date: 06-07-07 Type: RH-86_87 (Unknown) Additional_1: (c) Nokia. Pack: MTM Product code: 0556402 Production serial: OB1414302 Hardware version: 7001 Security code: 12345 Original IMEI: 011374-00-186444-2 IMEI: 011374-00-186444-X Asic type: 11 Profile bits: 5555555555015555 Lockinfo: 5555555555555555 Lock version: 1 SIMLock service: SIMLOCK SERVER [010000060C08] Calculating SP area Writing SP info Write lock succeeded -------------------------------------------------------------------------------- TDCT4UnlockThread finished at: 2008/06/19 19:43:07 Regards F@iSaL |
06-19-2008, 15:48 | #10 (permalink) |
Member: 196633 Status: Offline Thanks Meter: 8 | - close application - disconnect the box - connect the box - open application PROBLEM SOLVED That reminds me old time , Windows 95 age you need to reboot every time you install something Thank you any way! |
Nokia 2610b rh-87 t-mobile unlock solution 100% tested | shohag | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 03-17-2015 07:08 |
Nokia 2610b Rh-87 T-mobile Unlock Solution 100% Tested | mr_bb5 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-23-2010 21:19 |
Help unlocking Nokia 2610 RH-87 v6.80 | jigaboo77 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 10-12-2008 23:07 |
2610b rh-87 v6.80 | khan_mobiles | HWK | 4 | 09-01-2008 18:17 |
problem with nokia 2610b rh 87 | denisirias | Multi-Box | 8 | 03-12-2008 15:48 |
