09-26-2007, 15:21 | #212 (permalink) |
Junior Member Join Date: Sep 2004 Age: 46
Member: 83437 Status: Offline Thanks Meter: 0 | tested Hi 5200 black case.......done N50........................done 6085.......................done 6288.......................done N73........................done (all withouht carger) Thx raskal |
09-26-2007, 15:41 | #213 (permalink) |
Registered User Join Date: Aug 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 48
Member: 76714 Status: Offline Thanks Meter: 34 | n73 unlock ok hi bb5box ok work i have box v2 no need to use 12.v it good ot day i try to unlock n73 flash to hight version support and unlock good |
09-26-2007, 18:47 | #216 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Dubai - Damas
Member: 125982 Status: Offline Sonork: 100.109498 Thanks Meter: 573 | Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_03.70_15-05-06_RM-145_(c)_Nokia IMEI: 359728008153218 SP LOCK status: Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-145_359728008153218_Locked_Keycnt_0_Fbuscnt_0__V_0 3.70_15-05-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
09-26-2007, 18:53 | #217 (permalink) |
Member: 125982 Status: Offline Sonork: 100.109498 Thanks Meter: 573 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 356962012XXXX0 SP LOCK status: Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 21407F Block 3: CLOSED Type 5 Data: 21402F Block 4: CLOSED Type 5 Data: 74000F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70503F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71402F Block 9: CLOSED Type 5 Data: 71030F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Block 14: CLOSED Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_3569620126ْْْْْ_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 732123 Block 2: OPEN Type 5 Data: 21407F Block 3: OPEN Type 5 Data: 21402F Block 4: OPEN Type 5 Data: 74000F Block 5: OPEN Type 5 Data: 33403F Block 6: OPEN Type 5 Data: 70503F Block 7: OPEN Type 5 Data: 70604F Block 8: OPEN Type 5 Data: 71402F Block 9: OPEN Type 5 Data: 71030F Block 10: OPEN Type 5 Data: 71606F Block 11: OPEN Type 5 Data: 73002F Block 12: OPEN Type 5 Data: 72207F Block 13: OPEN Type 5 Data: 74807F Block 14: OPEN Type 5 Data: 73404F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
09-27-2007, 05:57 | #224 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
2. What is so hard to understand from this message: Not suported model/version? Also, if you search/read a little bit more other threads in this forum, you will find that this problem was discussed more than one time, and YES, 5200 with SEC ...-ATB chip is NOT SUPPORTED NOW (any version is NOT supported). So, better stop play with flashing your 5200 phone, you can end with an messed-up phone after a lot of upgrades/downgrades. We will receive this kind of phone TODAY and will make update to BB5 Box software TODAY too. | |
09-27-2007, 06:00 | #225 (permalink) | |
http://forum.gsmhosting.com/vbb/show...&postcount=220 | |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
