09-28-2007, 10:25 | #242 (permalink) |
Freak Poster Join Date: Feb 2005 Location: hk, phils.,shenzhen
Member: 120669 Status: Offline Thanks Meter: 15 | another n73 softbank, n70 smart and n6680 unlocked via bb5box!!! n73 softbank unlocked... and we give the unlocking service (same client) for n70 smart, and n6680 for FREE of charged!!! with smile...; MABUHAY!!! -ALONG |
09-28-2007, 14:59 | #243 (permalink) |
Major Poster Join Date: Nov 2004
Member: 94038 Status: Offline Thanks Meter: 0 | dear rascal 5300 dead I have read with interest previous threads about the problems associated with this new box, the fact that *** gave you brain cannot be brushed aside. your contribution to phone unlocking business worldwide cannot be erased from the annals of the history of this business, however, kindly accept that there is a problem with the bb5box as some loyal customers have said. I got a 5300 dead trying to unlock with your box, I specifically bought a new nokia 6230 with ACP-12X charger so that it doesnt go the way some went, but alas,the phone is dead. After phone splock read error thrice. The question is what can you do to rectify this problem especially in the boxes out there already? |
09-28-2007, 15:13 | #244 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
2. Regarding your problem, try to read here: http://forum.gsmhosting.com/vbb/showthread.php?t=448562 | |
09-28-2007, 16:15 | #245 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Wickford, Es***, UK
Member: 112674 Status: Offline Thanks Meter: 5 | Just successfully unlocked Nok 6300 TMobile Uk with ATD chip. Used new V021 software. No Charger. Also have unlocked 5 X N95 using charger. Still got to get my eyes sorted before unlocking 6280, N73 as i keep losing count of the testpoint pins. |
09-28-2007, 16:48 | #246 (permalink) |
Freak Poster Join Date: May 2006 Location: Romania
Member: 283018 Status: Offline Thanks Meter: 46 | a 6233 v3.70 dont working Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_03.70_15-05-06_RM-145_(c)_Nokia IMEI: 359............ SP LOCK status: Block 1: CLOSED Type 5 Data: 23205F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-145_359*******************_Locked_Keycnt_0_Fbuscnt _0__V_03.70_15-05-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. then i maked restore pm.... unlock again, some problem... I tried more them 20 times |
09-28-2007, 17:03 | #247 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 44
Member: 40602 Status: Offline Thanks Meter: 118 | N91 successfully unlocked, easily :P 2morrow will try to unlock 6280 but i'll try a different way to touch the TP (in RAP) rather than use solder that can easily damaged the handset, will post the result here. br, s1emens |
09-28-2007, 21:55 | #249 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2004 Age: 45
Member: 85712 Status: Offline Thanks Meter: 131 | NK 6280 RM-78 V03.36 - Unlock OK NK 6280 RM-78 V03.36 - Unlocked 100% Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.36_05-12-05_RM-78_(c)_Nokia IMEI: 357603004755450 SP LOCK status: Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_357603004755450_Locked_Keycnt_0_Fbuscnt_0__V_03 .36_05-12-05_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
09-28-2007, 22:12 | #250 (permalink) | |
No Life Poster Join Date: Nov 2000 Location: Boro Age: 37
Member: 2461 Status: Offline Thanks Meter: 22 | Quote:
since 2004 | |
09-28-2007, 22:13 | #251 (permalink) | |
6280 and n73 are a piece of cake B.Rgds John... | |
09-29-2007, 06:31 | #255 (permalink) |
Member: 120669 Status: Offline Thanks Meter: 15 | BB5BOX - SUCCESS AGAIN WITH N5200 FLASH CHIP xxxxxx - ATD NICE ONE AGAIN FOR OUR BABIES... MABUHAY ANG PILIPINAS!!! MORE POWER SA MGA BATA!!! -ALONG |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
