02-28-2009, 18:48 | #16 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Germany
Member: 753732 Status: Offline Thanks Meter: 252 | The Phone goes to Locale Mode, but after this operation if i try to connect the Phone with Nokia PC Suite, it not found the Phone more. I think the USB Port on the N95, dont work after this Operation.. |
04-07-2009, 11:57 | #24 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | This is risky....I have broken 1 phone no usb connection! There is another solution that you can use an ordinary power supply and connect it to phones battery terminals!Set your power supply on 5v for better results!Method is 100% working and safe! |
The Following User Says Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post: |
04-07-2009, 15:37 | #25 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | Quote:
Its red wire is giving negative(-) and black wire is giving (+) current.many thanks muneeb dear...... | |
05-10-2009, 07:22 | #27 (permalink) |
Junior Member Join Date: Oct 2008
Member: 874961 Status: Offline Thanks Meter: 2 | sir , can anyone say what is USB CHARGER SPECIFICATION SIR, can anyone say what is the specification of usb charger. is the output 5V AND 1A CAN it be used for nokia n95? advance thanx |
07-05-2009, 14:00 | #28 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 45
Member: 71874 Status: Offline Thanks Meter: 34 | I was having issues changing the Nokia N96 to local mode. I connected both the USB cable and the FBUS cable and wow the handset was in local model. Give it a go! Maj |
Can't go phone in local mode with yellow adapter? | morya | Cyclonebox | 7 | 09-23-2009 04:16 |
Haw to Put safe the Phone in Local Mode with Fbus. | vali23_mm | JAF No Tp Unlocker by Cinek | 20 | 09-22-2009 17:26 |
Haw to Put safe BB5 Phone in Local Mode with Fbus. | vali23_mm | Nokia Base Band 5 ( BB-5 ) | 0 | 02-25-2009 01:45 |
3650 - how to manually put phone in local mode for use with griffin? | Alinus | Griffin | 10 | 09-18-2003 13:41 |
