02-25-2009, 01:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | Haw to Put safe the Phone in Local Mode with Fbus. Some Phone like (N95,N95-8gb,N96,N82...) can't go in Local Mode Becouse Low Power in USB Port So wii can use USB cable conected to Phone and Fbus cable to give more Power to Phone I don't recomend to use USB Port couse windows will find the Phone and try to instal Driver,and will delay the process. So wi can use usb carger(Tested with 5v and 1A) and connect to Phone(use correct usb data cable to correct Phone). This is tested by me in (N95,N95-8gb,N96,N82) and work fine. See hier the carger type => http://www.iriver.eu.com/fileadmin/u..._charger_b.jpg And don't forget to Share your experience... BR |
The Following 4 Users Say Thank You to vali23_mm For This Useful Post: |
03-01-2009, 22:09 | #2 (permalink) |
Freak Poster Join Date: Nov 2006 Location: London Age: 65
Member: 389313 Status: Offline Thanks Meter: 30 | Phone in Local Mode with Fbus. today i tryed this with n958g it dont work phone keeps turning on & will not read even 5v plug & v3 cable |
The Following User Says Thank You to al ahmet For This Useful Post: |
03-05-2009, 12:18 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | For me what i do is use 7.5k on bsi then as cable attached to phone press power on and attach charger on phone it helps the phone to go on localmode.... done many times in unlocking via dejan's trk |
The Following User Says Thank You to alayne For This Useful Post: |
03-16-2009, 02:36 | #7 (permalink) |
Freak Poster Join Date: May 2006 Location: Malaysia Kuala Lumpur
Member: 276082 Status: Offline Thanks Meter: 113 | i will open the phone and disable the camera to made sure it is not attach to the board. then insert fbus and it will go to local or test mode easily. |
The Following 3 Users Say Thank You to ymtong For This Useful Post: |
03-16-2009, 21:01 | #9 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 596972 Status: Offline Sonork: 100.1591686 Thanks Meter: 55 | If you connect the USB Charger to the nokia phone the phone will be damaged, because the usb-port of phone is not constructed to power the mobile like the HTC-Mobiles e.g. You can see it when you attach the normal USB-Cable to the phone and the computer the phon ewill not be charged!!! Do don't attach an USB-Charger!!! Modify your FBUS-Cable with resistor 7,5k or 10k will also put the phone stable into local mode. Also you can use a stabilisied active USB-HUB with guaranteed 500mV.... But most problem the phon doesn't get into local mode was the problem with the wrong resistor!! |
The Following User Says Thank You to jomafi For This Useful Post: |
03-23-2009, 07:10 | #10 (permalink) |
Junior Member Join Date: Oct 2003 Location: UA Age: 53
Member: 41975 Status: Offline Thanks Meter: 0 | Get out from cable two wires from pins that goes to battery "+" and "ground" connetors and connect them to 4.7-5v stabilizied charger. I'm using regulated DC Power supply, 4,8v. Working 100% OK |
03-25-2009, 20:48 | #11 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Dar-es-salaam
Member: 187686 Status: Offline Sonork: GHANIM Thanks Meter: 48 | Get out from cable two wires from pins that goes to battery "+" and "ground" connetors and connect them to 4.7-5v stabilizied charger. I'm using regulated DC Power supply, 4,8v. Working 100% OK I AGREE WITH YOU BRO THATS IT |
Can't go phone in local mode with yellow adapter? | morya | Cyclonebox | 7 | 09-23-2009 04:16 |
Haw to Put safe the Phone in Local Mode with Fbus. | vali23_mm | BB5 Box by D.K. | 27 | 07-05-2009 14:00 |
Haw to Put safe BB5 Phone in Local Mode with Fbus. | vali23_mm | Nokia Base Band 5 ( BB-5 ) | 0 | 02-25-2009 01:45 |
3650 - how to manually put phone in local mode for use with griffin? | Alinus | Griffin | 10 | 09-18-2003 13:41 |
