01-12-2009, 17:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Problems unlocking N82 - won't enter local mode I have tried two different cables (normal + "bb5 universal kit"), but same problem with both: Phone just starts up normally when i connect the cable. Is there something special with this phone? N95 8GB etc works fine... |
01-12-2009, 18:14 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | simple methode unlock it with cable usb Part one- dongle installing 1. Unzip to any folder BB5_TRK_unlocker.zip 3. start install.bat 4. Start BB5CardInfo.exe and click button "Get Info" 5. Copy your serial number and send to reseller . Reseller will provide for you Key file for your dongle. 6. Copy key file on folder where you unzip BB5Cad.zip . 7. Start KeyInstall.bat. 8. Start BB5CardInfo.exe "Get Info". You must get message " Card key is OK! " Part two- phone preparation 1. You must have Nokia data suit because Dejan soft using driver from data suit and to install TRK file 2. After this you need to install s60_3_1_app_trk_2_8_6.sisx or s60_3_1_app_trk_2_8_9.sisx . Which file need to install depending of phone software. First is for older second is for newer phones .You don't need to know joust try to install and one of this must pass instillation. 3. If you have installed data suit and phone connected with usb cable to PC, just click twice on s60_3_1_app_trk_2_8_6.sisx or s60_3_1_app_trk_2_8_9.sisx and installation will start automatically. Confirm all message on phone. 4. Find in your phne where is application installed and start the TRK application. Example in N81 8gb path is MENU/APPLICATION/TRK in some phone MENU/APPLICATION/MY OWN/TRK 5. When you start you will get message "activate blutooth in offline mode" press key NO. 6. Press OPTION button and select SETTINGS and in CONNECTION field change to USB and press button BACK. 7. Close TRK and start again 8. You must have screen like this. I copy this from Nokia N81 8GB: Welcome to TRK for Symbian OS Status: Connected PDD: NONE LDD:EUSBC CSY:ECACM Port number :1 Baud rate: 115200 Part three- unlocking phone. 1. Connect phone to PC with usb cable and start TRK application. 2. Start BB5_TRK_unlocker.exe 3. Clik on button "Read Phone" and you will get phone info on screen. 4. For safety reason click on button " Make Backup". If something goes wrong to have backup for phone. 5. Click on button " SP Unlock" . Wait until on screen not have message " If everything is OK,...." 6. On phone press key for OPTION select with cursor Hello World and confirm . 7. In few seconds you will have UNLOCKED PHONE !!!!!! |
01-12-2009, 18:26 | #3 (permalink) |
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | 5320 : cable used USB 5700 : cable used USB 6110 : cable used USB 6120 : cable used USB 6121 : cable used USB 6124 : cable used USB 6210 : cable used USB 6220c : cable used USB 6290 : cable used USB 6650 : cable used USB e51 : cable used USB e66 : cable used USB e71 : cable used USB n76 : cable used USB n78 : cable used USB n81 : cable used USB n81 8g : cable used USB n79 : cable used USB n85 : cable used USB N82 : cable used USB N95 8gb cable used FBUS N96 cable used FBUS |
The Following 2 Users Say Thank You to ABOUSHADY For This Useful Post: |
01-15-2009, 22:02 | #9 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Around the world Age: 56
Member: 106484 Status: Offline Thanks Meter: 400 | N82 is 2 MCU simbian phone and can be unlocked only with F-bus cable . For enter local mode BSI resistor must be 7.5 to 8.2 Kohm and cable must be with 6 or 7 pin . |
The Following User Says Thank You to Boban For This Useful Post: |
01-20-2009, 18:11 | #10 (permalink) |
Freak Poster Join Date: Oct 2003 Location: srilanka
Member: 40975 Status: Offline Thanks Meter: 62 | how can i use bb5 trk unlocker 1.01 for fbus.i have 1 credit,pkey and jaf only.when i used finally itsays not supported.is it necessory dk smart card to unlock via fbus cable thanks a lot |
01-21-2009, 04:02 | #11 (permalink) | |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
if more help needed, catch on msn or sonork BR, | |
The Following User Says Thank You to boucettay For This Useful Post: |
01-21-2009, 06:04 | #12 (permalink) |
Junior Member Join Date: Aug 2007
Member: 565834 Status: Offline Thanks Meter: 0 | Detected P-KEY: 9000A384 P-key nokia module version 01.02 Detected P-KEY: 9000A384 P-key nokia module version 01.02 Waiting for the last operation to finish... Starting Card UPDATE... .......... 20:55:55.312 Error: JAF dongle init failed ppppppppppplz tell me why my pay ke up date fail plz plz plz plz plz |
01-21-2009, 07:09 | #13 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | i have exactly the same problem...phone can not stand on local mode...i used 8,2kohms resistor and 7,5 khoms...some test doing with 10komhs but always the same result. |
6120c cannot enter local mode or test mode | doublex_gsm | Nokia Hardware & Hardware Repair | 0 | 10-02-2008 15:44 |
N76 problem, Info check fails, won't enter local mode | ManWolf | HWK | 1 | 11-06-2007 22:57 |
