Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 01-20-2008, 13:03   #1 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
5300 RM-146 4.70 can`t unlock
hi. Use last update of JAF. Phone 4.70 Here is log:
Detecting phone...
Reading simlock...
LOCK STATUS:
CONFIG KEY: 2343000000000000
Provider: T-Mobile-One 2 One;United Kingdom
Key Code count: 3, FBUS Code count: 4
Block 1:
Lock 1: CLOSED -> Lock Data: 23430F
Reading phone...Type: RM-146, Ver: 04.70
Reading imei...
Imei: 356408019810576
Reading HW ID...2508
Found general data...
Waiting for TP confirmation.....................Sending code...
Waiting for TP confirmation......Sending code...
Error unlocking! Code: 08
all time seme eror : Whot is wrong? 4.70 is anonced like suported to unlock wersion! Hove to unlok it???
Old 01-20-2008, 13:21   #2 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
What is the flash chip?
Old 01-20-2008, 13:38   #3 (permalink)
Member: 137049
Thanks Meter: 7
try another firmware firmware version....
Old 01-20-2008, 14:06   #4 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
flash chip is SEC740SF75
alredy try 5.0 - not work. Some peopel wrote thet 3.92 can be don. I`ll try.
But if 5.0 and 4.70 are not subported why it anonsed in manual like suported one?!
Old 01-20-2008, 14:15   #5 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
Try downgrade to 3.92 - phone is dead
Product supporter! Pleas, let me knou hove to unlock 5300 4.70 !!!!
Old 01-20-2008, 15:16   #6 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
as we tried many times This flash chip SEC740SF75 doesn't support
Old 01-20-2008, 16:13   #7 (permalink)
Member: 31028
Thanks Meter: 56
just update to 5.02 and do it. tested on many many pcs... v-spec team should do the same for 5300 as they done for 5200. 5200 rocks now on v-spec. add support for this flash to.
Old 01-20-2008, 16:59   #8 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
theris no 5.02 for 5300 on suppport! Maby You meens some ather version??? Pleas, confirm!
Old 01-20-2008, 20:49   #9 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
Here is ful log, there is two strange moments:
JAF version 1.98.45
Detected PKEY: 90000***
Card life counter: 53.77%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.70
24-01-07
RM-146
(c) Nokia.
HW version: 2507
PCI version:
RFIC version:  17211721
DSP version: pb06w14v33
PPM version: V 04.70
24-01-07
RM-146
(c) Nokia.
I
BT MCM version: 06cc-P8.0
Retu version: 32
Tahvo version: 53
Content Pack version: Content: tmo_uk_v2
V 04.70
24-01-07
RM-146
(c) Nokia.
Production serial number: PNB124405
Product code: 0551729
Module code: 0203051
Basic production code: 0530535
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 35640801******3
IMEI spare to net: 3A 65 04 08 61 44 23 02
IMEI SV to net: 33 65 04 08 61 44 23 02 F6
LOCK STATUS:
Key Code count: 0, FBUS Code count: 0
Block 1:
Searching for saved ini...
Checking for file D:\Program Files\ODEON\JAF\JAF_RM-146.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0551729
Done!
Backup simlock data first...
Reading IMEI...
D:\Program Files\ODEON\JAF\ProgData\RM-146_356408016443223_04.70_LCK_backup.pm
Done!
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Imei: 35640801******3
Reading HW ID...2507
Waiting for TP confirmation...................................... ......................Sending code...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Reading...
24-01-07
RM-146
(c) Nokia.
HW version: 2507
PCI version:
24-01-07
RM-146
(c) Nokia.
I
Retu version: 32
Tahvo version: 53
V 04.70
24-01-07
RM-146
(c) Nokia.
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Key Code count: 2, FBUS Code count: 0
Block 1:
typical eror for all phone from box -
Olso counter increse two time. Strange because I toch TP only one time.
Key Code count: 0, FBUS Code count: - Key Code count: 2, FBUS Code count: 0
Whay key code count incrase? Pleas explane
Old 01-21-2008, 06:02   #10 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
Before you keep tp..tp getting ground.
Dont worry about counting, after 13 counts phone automatically restore all counters to 0 again
Old 01-21-2008, 07:17   #11 (permalink)
Member: 31028
Thanks Meter: 56
5.02 is on support check 5300b
Old 01-21-2008, 09:27   #12 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
No! I`m shoore I not toch GND! try fey times on feu phones on diferents SW version - same log. All phones have SEC740SF75
Produkt supporters, pleas any info about thys situation.
Old 01-21-2008, 09:45   #13 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
http:///vbb/showthread.php?t=491590
http:///vbb/showthread.php?t=486264
Old 01-21-2008, 10:13   #14 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
thenks. but thys method not acepted for big quantity
Old 01-21-2008, 10:49   #15 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
Yes thats right....JAF team will correct this problem,But They need time
Nokia 6300 version 4.70 can t unlock with last update V spec Unlocker AL J.A.F. V-SPEC 1 07-09-2008 13:12
problem with 5300 RM-146 Version: V_03.50_14-09-06_RM-146 yecaluna21 BB5BOX 0 10-22-2007 22:14
Flash a 5300 rm-146 to a rm-147 possible? csmall Nokia Base Band 5 ( BB-5 ) 8 06-13-2007 10:58
Page generated in 0.33805 seconds with 9 queries
