01-20-2008, 13:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Ukraine. Lviv Age: 43
Member: 19633 Status: Offline Thanks Meter: 13 | 5300 RM-146 4.70 can`t unlock Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 4 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-146, Ver: 04.70 Reading imei... Imei: 356408019810576 Reading HW ID...2508 Found general data... Waiting for TP confirmation.....................Sending code... Waiting for TP confirmation......Sending code... Error unlocking! Code: 08 all time seme eror : Whot is wrong? 4.70 is anonced like suported to unlock wersion! Hove to unlok it??? |
01-20-2008, 14:06 | #4 (permalink) |
Member: 19633 Status: Offline Thanks Meter: 13 | flash chip is SEC740SF75 alredy try 5.0 - not work. Some peopel wrote thet 3.92 can be don. I`ll try. But if 5.0 and 4.70 are not subported why it anonsed in manual like suported one?! |
01-20-2008, 16:13 | #7 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | just update to 5.02 and do it. tested on many many pcs... v-spec team should do the same for 5300 as they done for 5200. 5200 rocks now on v-spec. add support for this flash to. |
01-20-2008, 20:49 | #9 (permalink) |
Member: 19633 Status: Offline Thanks Meter: 13 | Here is ful log, there is two strange moments: JAF version 1.98.45 Detected PKEY: 90000*** Card life counter: 53.77% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 *** Switching to serial... Powering the phone... Reading... MCU SW version: V 04.70 24-01-07 RM-146 (c) Nokia. HW version: 2507 PCI version: RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.70 24-01-07 RM-146 (c) Nokia. I BT MCM version: 06cc-P8.0 Retu version: 32 Tahvo version: 53 Content Pack version: Content: tmo_uk_v2 V 04.70 24-01-07 RM-146 (c) Nokia. Production serial number: PNB124405 Product code: 0551729 Module code: 0203051 Basic production code: 0530535 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35640801******3 IMEI spare to net: 3A 65 04 08 61 44 23 02 IMEI SV to net: 33 65 04 08 61 44 23 02 F6 LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-146.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0551729 *** Done! Backup simlock data first... Setting local mode... Reading IMEI... D:\Program Files\ODEON\JAF\ProgData\RM-146_356408016443223_04.70_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-146, Ver: 04.70 Reading imei... Imei: 35640801******3 Reading HW ID...2507 Found general data... Waiting for TP confirmation...................................... ......................Sending code... Waiting for TP confirmation......Sending code... Error unlocking! Code: 08 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 04.70 24-01-07 RM-146 (c) Nokia. HW version: 2507 PCI version: RFIC version: 17211721 DSP version: pb06w14v33 PPM version: V 04.70 24-01-07 RM-146 (c) Nokia. I BT MCM version: 06cc-P8.0 Retu version: 32 Tahvo version: 53 Content Pack version: Content: tmo_uk_v2 V 04.70 24-01-07 RM-146 (c) Nokia. Production serial number: PNB124405 Product code: 0551729 Module code: 0203051 Basic production code: 0530535 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35640801******3 IMEI spare to net: 3A 65 04 08 61 44 23 02 IMEI SV to net: 33 65 04 08 61 44 23 02 F6 LOCK STATUS: CONFIG KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 2, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-146.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0551729 typical eror for all phone from box - Waiting for TP confirmation...................................... ......................Sending code... Waiting for TP confirmation......Sending code... Error unlocking! Code: 08 Olso counter increse two time. Strange because I toch TP only one time. Key Code count: 0, FBUS Code count: - Key Code count: 2, FBUS Code count: 0 Whay key code count incrase? Pleas explane |
01-21-2008, 06:02 | #10 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | Before you keep tp..tp getting ground. Dont worry about counting, after 13 counts phone automatically restore all counters to 0 again |
01-21-2008, 09:27 | #12 (permalink) | |
Member: 19633 Status: Offline Thanks Meter: 13 | Quote:
Produkt supporters, pleas any info about thys situation. | |
Nokia 6300 version 4.70 can t unlock with last update V spec | Unlocker AL | J.A.F. V-SPEC | 1 | 07-09-2008 13:12 |
problem with 5300 RM-146 Version: V_03.50_14-09-06_RM-146 | yecaluna21 | BB5BOX | 0 | 10-22-2007 22:14 |
Flash a 5300 rm-146 to a rm-147 possible? | csmall | Nokia Base Band 5 ( BB-5 ) | 8 | 06-13-2007 10:58 |
