04-26-2008, 18:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: nil Age: 48
Member: 5291 Status: Offline Sonork: nil Thanks Meter: 7 | who can show the proper solution Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 5050100058056920 Provider: Telstra Mobile Comms;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50501F Block 2: Lock 1: CLOSED -> Lock Data: 50501F Reading phone...Type: RM-198, Ver: 05.03 Reading imei... Imei: 353085020040808 Reading HW ID...1402 Found general data... Waiting for TP confirmation................... |
04-27-2008, 16:52 | #3 (permalink) |
Member: 5291 Status: Offline Sonork: nil Thanks Meter: 7 | tp is connect properly ,have do scratch clean tp also.Is new never unlock any phone yet ,could this be error box cause no light coming from box even power light is not coming.have do update p-key many times also same error. In box rj45 pin which one is data and clk (tp) |
04-27-2008, 18:04 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | the pin with a button is DATA and the thinner pin is CLK and if the power light of vspec is not glowing how you posted the logs it will not detect phone if vspec is not powering |
04-27-2008, 18:12 | #5 (permalink) |
Member: 5291 Status: Offline Sonork: nil Thanks Meter: 7 | this is the problem .Cable ,box or what is wrong.The box is no light connect cable power on the phone go local mode ok when show tp confirmation ,i start connect the tp just nothing going ............................all the way failed |
04-27-2008, 18:22 | #6 (permalink) |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | did you connect the cable properly of vspec with jaf box 1 side it has 10 pin it should connect to vspec and other side it has 8 pin that should connect to jaf box |
Who can give the steps of like unlock to the ME240q | justincel | VygisToolbox | 0 | 01-10-2008 04:47 |
whats the proper solution for SP corrupted | Tinotenda | Nokia Base Band 5 ( BB-5 ) | 4 | 07-19-2007 11:27 |
who can give 100% unlock solution for new a52 ver 7! | infogsm | E-Gold Based Phones | 16 | 02-19-2004 08:59 |
GDFS backup - who can reset the counter so I can write back and solve 4 locks? | Nick-A | Sony Ericsson | 2 | 08-22-2003 11:29 |
who can backup the BF4 !!! | viewgsm | BF, BG, TH, BHx Series | 1 | 07-03-2002 13:55 |
