12-18-2008, 12:25 | #436 (permalink) |
Product Manager Join Date: Nov 2002 Location: ✿ Age: 47
Member: 17865 Status: Offline Sonork: 100.73724 Thanks Meter: 267 | tray to flash your mobile and b4 you flash the mobile you must take copy from your mobile flash file cuz if you got any problim than you can reten this file back to your mobile |
12-18-2008, 12:56 | #437 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | Quote:
@SATGURU to solve this problem you need to reflash your set with backup flash file from any other working phone ****DONT make FORMAT after flash TESTED good luck BR, ...............shehab.......... | |
The Following User Says Thank You to gsm2start For This Useful Post: |
12-19-2008, 13:31 | #438 (permalink) |
Crazy Poster Join Date: Feb 2007
Member: 450579 Status: Offline Thanks Meter: 5 | CECT v2 watch phone Made back up of above model then flashed then dead any suggestions. Back up file that caused dead fone is at following link. http://www.swedafone.com/files/v2.bin |
12-20-2008, 21:06 | #439 (permalink) | |
will you please explane more do you mean the phone is dead even with the backup file ??? BR, .........shehab........ | |
12-21-2008, 13:56 | #442 (permalink) | |
Member: 450579 Status: Offline Thanks Meter: 5 | Quote:
http://www.swedafone.com/files/v2.bin | |
12-21-2008, 19:16 | #444 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | hi,,sir,,,i goit some problem,with new update,,when i instal, the last new update,2.51..so,the sw can not work,,i mean,box can not connect,,,in error message ,says,,reconnect ,the box,i reconnect the box many time,,but stil,not connected,but when,i remove the the new update and install, the old 2.462 its working properly,,,no any error,,so what is this,,remember how,i instal,the new update,,first i remove the old version,,then i install,the new version,,so,,plz help me,,,,,when i install the version,,in box flashing lights,,are running,,,i think,it is the driver problem,,but i run all drivers,,...but same,,problem,,reconnect the box...plz help |
12-21-2008, 20:44 | #445 (permalink) | |
**remove the old drivers too **restart pc **install the latest version **install the drivers again conferm me with the result please regards BR. .............shehab........... | |
12-21-2008, 20:47 | #446 (permalink) | |
you must have made read flash after format post here the name of the flash file i will try to find you good working one regards BR, .............shehab......... | |
12-22-2008, 16:06 | #447 (permalink) |
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | hmmmmmmmmmm,,,thx my problem,have been solved,,thank u so much,,,really working...uninstall,,the old drivers,,and instal,the new,,,good work,,thx again,,now my ,sw working properly,, |
12-22-2008, 22:32 | #448 (permalink) | |
Member: 450579 Status: Offline Thanks Meter: 5 | File Name Quote:
I did a snap shpt of a boot read where the file name is hope it will help you http://www.swedafone.com/files/v2.gif | |
12-23-2008, 08:56 | #450 (permalink) |
Junior Member Join Date: Aug 2008
Member: 827480 Status: Offline Thanks Meter: 3 | Dear Freinds, I have a problem connecting my Spider Man Box when i Press Connect it shows the below msg and if i press connect again it is accepting can you pl tell me what am i doing wrong. cant connect box extra_comport 1.did you already install FT232_USB_COMPORT Driver 2. this comport is used by anotherfirmware now? close this window please. pl help lucki |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
