12-13-2008, 10:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2001 Location: Bucharest, Romania Age: 48
Member: 3180 Status: Offline Thanks Meter: 12 | V810 drivers can't install b.r. p.s. also with original sim card i set in phone menu type of connection: usb modem |
12-13-2008, 13:31 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan Age: 36
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | You Don,t need to put phone in Flash Mode Cause micro-box will do that Automaticaly... When You see 3 Options on your pc then simple Ignore them and Open module ... Select Corresponding Phone Model, Software will detect Usb Port.... |
12-13-2008, 21:45 | #5 (permalink) |
Freak Poster Join Date: Oct 2004 Location: India
Member: 86448 Status: Offline Sonork: 100.113881 Thanks Meter: 106 | yes, no need to press any buttons, Install vodafone pc Assistant and then all will ok , automatically drivers will installed, then select port with name : Vodafone Mobile Adopter and click read code |
12-16-2008, 12:57 | #6 (permalink) |
Member: 3180 Status: Offline Thanks Meter: 12 | customer trust in me and come back ..but i still can't install driver. Cable it's original from phone box, phone it's not in flash mode, voda activator it's installed so i suposed the last chance it's to remove some driver installed for usb ports. Do u have a remover or something? i trying also ignoring those 3 options and start module..but nothing happend ..on ports : "not found" it's the messaje |
After installing updated setup can't install box drivers | kfkevin | Infinity-Box | 4 | 01-18-2010 15:09 |
foma L601i driver can't install on xp [SOLVED] | MR.PRESIDENT | FuriousGold | 23 | 06-05-2009 10:20 |
Can't install drivers! | JC_BY | JAFWM | 7 | 02-28-2009 03:53 |
Problems with Driver, can't install Drivers on VISTA and XP | carlito79 | Infinity-Box | 10 | 05-24-2008 18:49 |
URGENT! Can't install Cruiser multiserver cable driver | hyds | Cruiser Suite | 4 | 08-26-2005 02:09 |
