Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 11-25-2009, 15:21   #1 (permalink)
phanthom2o4o's Avatar
Member: 33736
Thanks Meter: 15
HELP SUPPORT!!! ERROR : $NXP3G is not a valid integer value
Hi,
I have an Infinity Activated SPT software, and i am tring UNLOCK a SAMPLE C276 , and when i check the proper COM port and 115200 as boudrate and click on SPT Mode button, i samply give this error : "$NXP3G" is not a valid integer value
Please see the attach...
The Factory mode button works fine.....
Old 11-25-2009, 20:01   #2 (permalink)
Member: 535033
Sonork: 100.45908
Thanks Meter: 18,870
so we have 2 different way for that if one not work try second mean spt mode not work try factory if factory not work try spt mode
B.R
Old 11-26-2009, 12:16   #3 (permalink)
Member: 33736
Thanks Meter: 15
B.R
Factory mode button works fine, but not unlocky the phone..
SPT Mode samply gives that error...
Any Idea???????????
Old 11-28-2009, 09:33   #4 (permalink)
Member: 535033
Sonork: 100.45908
paste here factory mode complete message please
Old 11-28-2009, 15:08   #5 (permalink)
Member: 33736
Thanks Meter: 15
After check Unlock AND Factory default boxes, the phone is unlocked.......
Old 11-29-2009, 12:19   #6 (permalink)
Member: 535033
Sonork: 100.45908
hehe yes without mark unlock sw just read phone info must mark unlock then press factory mode
Old 11-29-2009, 12:29   #7 (permalink)
Member: 33736
Thanks Meter: 15
I did made it, marked unlock box and not work with factory mode... it only work when o mark unlock AND factory default boxes....
'0C' is not a valid integer value WHAT SHOULD BE DONE? ockiya Cyclonebox 0 02-19-2010 08:57
'$' is not a valid integer value sunrise gsm VygisToolbox 31 07-21-2009 10:22
M'%+a Is Not A Valid Integer Value!!!!!!????? farouk842000 FuriousGold 0 08-05-2008 18:58
Need solution (Lg Unlocking $ is not a valid integer ) Moosani Redbox 20 09-29-2006 22:39
G5300i $ is not a valid integer value dannyogolo Redbox 5 02-18-2005 15:28
Page generated in 0.20142 seconds with 10 queries
