04-29-2015, 22:54 | #166 (permalink) | |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | Quote:
is it possible for you to make a step by step guide on how to locate the required files and read them from the phone and then edit them to remove this stupid from the phones. and i'm sure after your helpful tutorial, no body will be bothering you and then you can enjoy your cold beers.. | |
04-30-2015, 02:30 | #167 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | If anyone had a G850F that isn't blocked by the EE computrace lock I'd gladly take a video of why I asked for certain files, where these files came from, and what to do with them. This can then be applied to all devices that are rootable. Although I think a LOT of support should be thrown towards @Venereo. He is the one trying to discover a true fix for this lock. My fix is nothing more than a workaround. |
04-30-2015, 13:02 | #169 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893471 Status: Offline Thanks Meter: 25 | here is samsung s6 SM-G920f partition details, Code: at /proc/partitions ajor minor #blocks name 8 0 31240192 sda 8 1 4096 sda1 8 2 4096 sda2 8 3 20480 sda3 8 4 8192 sda4 8 5 28672 sda5 8 6 34816 sda6 8 7 8192 sda7 8 8 43008 sda8 8 9 1024 sda9 8 10 1024 sda10 8 11 768 sda11 8 12 256 sda12 8 13 9216 sda13 8 14 15360 sda14 8 15 3788800 sda15 259 0 204800 sda16 259 1 153600 sda17 259 2 26902528 sda18 8 16 4096 sdb 8 32 4096 sdc 253 0 1310720 vnswap0 Code: 1|shell@zeroflte:/ $ ls -al /dev/block/platform/15570000.ufs/by-name ls -al /dev/block/platform/15570000.ufs/by-name lrwxrwxrwx root root 2013-02-15 22:58 BOOT -> /dev/block/sda5 lrwxrwxrwx root root 2013-02-15 22:58 BOTA0 -> /dev/block/sda1 lrwxrwxrwx root root 2013-02-15 22:58 BOTA1 -> /dev/block/sda2 lrwxrwxrwx root root 2013-02-15 22:58 CACHE -> /dev/block/sda16 lrwxrwxrwx root root 2013-02-15 22:58 DNT -> /dev/block/sda10 lrwxrwxrwx root root 2013-02-15 22:58 EFS -> /dev/block/sda3 lrwxrwxrwx root root 2013-02-15 22:58 HIDDEN -> /dev/block/sda1 7 lrwxrwxrwx root root 2013-02-15 22:58 OTA -> /dev/block/sda7 lrwxrwxrwx root root 2013-02-15 22:58 PARAM -> /dev/block/sda4 lrwxrwxrwx root root 2013-02-15 22:58 PERSDATA -> /dev/block/sd a13 lrwxrwxrwx root root 2013-02-15 22:58 PERSISTENT -> /dev/block/ sda11 lrwxrwxrwx root root 2013-02-15 22:58 RADIO -> /dev/block/sda8 lrwxrwxrwx root root 2013-02-15 22:58 RECOVERY -> /dev/block/sd a6 lrwxrwxrwx root root 2013-02-15 22:58 SBFS -> /dev/block/sda14 lrwxrwxrwx root root 2013-02-15 22:58 STEADY -> /dev/block/sda1 2 lrwxrwxrwx root root 2013-02-15 22:58 SYSTEM -> /dev/block/sda1 5 lrwxrwxrwx root root 2013-02-15 22:58 TOMBSTONES -> /dev/block/ sda9 lrwxrwxrwx root root 2013-02-15 22:58 USERDATA -> /dev/block/sd a18 shell@zeroflte:/ $ If you need more than ask, thanks br |
The Following 2 Users Say Thank You to teetopati For This Useful Post: |
05-05-2015, 19:10 | #177 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1540240 Status: Offline Thanks Meter: 15 | i dump both partition from two diffrent phone one is with absolute app and one without attaching here both file but i don know how to edit and make file if someone can help thanks |
05-05-2015, 19:34 | #178 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2331163 Status: Offline Thanks Meter: 4 | G901F worked thanks for the g900p file worked a charm. Downloaded 4.4 NK5 Netherlands Stock and downgraded. Flashed the G900P file. Didn't allow the phone to boot. Flashed the NK5 Stock file. Didn't allow the phone to boot. Put the phone straight into recovery and did a full wipe. Then allowed the phone to boot completely. Phone is fully functional and has been running for about 5 hours, also have been downloading apps directly from play store and it has not relcoked. Still testing for a few days before I return the handset. |
The Following User Says Thank You to shortcirkuit For This Useful Post: |
