Old 07-23-2017, 19:20   #796 (permalink)
Member: 2281288
I am having problems selecting the ADB but just for some phones(G900P, J727P) so far
When I try to select the ADB port the Samsung Tool Pro gets into not responding status and keep that way until I unplug the USB cable
Need assistance
Im on Windows 8 on a Microsoft Surface PRO
Old 07-24-2017, 13:32   #797 (permalink)
Castle2k's Avatar
Member: 1763284
Thanks Meter: 56
Need assistance
Hello! Sometimes this happens to me when i have something else that can connect to adb too. Another time it was the version of Z3X pro itself that has a bug like this... Freezes for a moment then crash.... Check your version and install another one...
Sent from my XT1254 using Tapatalk
Old 07-26-2017, 09:46   #798 (permalink)
Member: 1375596
Operation: Root
Selected model: SM-G930F
Software version: 28.8.1
Waiting ADB device... OK
Reading phone info...
Model: SM-G930F
Android version: 6.0.1
Product code: SM2G930FZKATEB
Phone version: G930FXXU1BPH1
PDA version: G930FXXU1BPH6
CSC version: G930FTEB1BPH2
CSC country code: Bosnia
CSC sales code: TEB
HW version: MP 0.700
Phone SN: R58J14JX08N
Chip name: EXYNOS8890
Modem board: SHANNON335
Security patch: 2016-08-01
RF cal date: 20170120
IMEI:
Checking Super user right... false
Rebooting to download... OK
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM13 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... timeout
Phone not found
Done with Samsung Tool PRO v.28.8.1
After root mobile is bricked and stay only an samsung logo!
Old 07-26-2017, 10:03   #799 (permalink)
wisam_wa's Avatar
Member: 103945
Sonork: 100.112828
Thanks Meter: 355
G955F Direct READ codes via server test
can you supported
Old 08-07-2017, 02:12   #800 (permalink)
Member: 2563951
Thanks Meter: 4
Z3X Latest Update Improvements
Dear Z3X Team
First of all want to thank you for your continous development
and improvements, sure make this products the best and indispensable for us.
Latest update you add "Repair Tab" hide when press CTRL button, is ok but, we use many times CRTL+C / CTRL+V to copy paste and repair and "Repair Tab" is hiding all the time when use this commands making the repair process a tedious process. Have to tell not only me involved with this issue, many users of Z3X mentions and asking that in forums and groups. So kindly request if is possible to fix or improve this function.
Thanks in advance
Gabriel Knox
The Following User Says Thank You to pwrgabe For This Useful Post:
Old 08-09-2017, 05:19   #801 (permalink)
Member: 2066431
Thanks Meter: 11
G570F/DD unlock error says (Security Damage)
Firmware:
BL_G570FDDU1AQE1
AP_G570FDDU1AQE1
CP_G570FDDU1AQG1
CSC_G570FODD1AQG2
Security Patch level: May1/2017
No other firmware or modem compatible except CP_G570FDDxxxx
Old 08-25-2017, 07:25   #802 (permalink)
Member: 1659385
Sonork: 100.1678591
Thanks Meter: 115
Add model AND sales code verification in order to charge unlock credits. Maybe somenthing like this:
If model = G955U & sales code = SPR then "This model is not supported"
If model = G955U & sales code = ATT then "Model is supported proceeding with unlock"
This will save the team a lot of complaints...
The Following User Says Thank You to jcdes For This Useful Post:
Old 08-27-2017, 03:07   #803 (permalink)
Member: 870866
Thanks Meter: 51
Please add support for Samsung SM-J327T1 Unlock and IMEI Repair.
Old 08-29-2017, 03:44   #804 (permalink)
Member: 698469
help g925v
error Reading phone info...
Reading IMEI... OK
IMEI: 354207070241305
Reseting MSL security... error (0)
Done with Samsung Tool PRO v.28.6
error write cert g925v
Checking CERT file... OK
KEY ID: 0449
Please, allow USB debugging on phone... OK
Model: SM-G925V
Android version: 5.1.1
Product code: Not Active
Phone version: G925VVRU4BOG9
PDA version: G925VVRU4BOG9
CSC version: G925VVZW4BOG9
CSC country code: USA
CSC sales code: VZW
HW version: G925V.04
Phone SN: R28G5258XRZ
Modem board: MDM9635M
RF cal date: 2015.05.22
IMEI:
Writing AT RIL... OK
Initialization AT RIL... OK
Bypass MSL... error (2)
First reset MSL
Old 08-31-2017, 03:22   #805 (permalink)
Member: 2749852
Samsung j510mn
Reparar imei o write cert
Old 08-31-2017, 06:44   #806 (permalink)
mianjabbar's Avatar
Member: 481915
Sonork: 100.1604233
Thanks Meter: 476
need SM-N910F DRK Repair solution
Old 09-02-2017, 11:29   #807 (permalink)
Member: 1061292
Thanks Meter: 5
i use z3x pro for reset frp/react but afte use this option of z3x pro my phone storage decreace . in g920f my phone show 8gb instead of 32gb and in j700f show 4gb instead of 16gb. in both phone device model in setting show s6 edge+ . plase fix this bux
Old 09-02-2017, 11:39   #808 (permalink)
Member: 2683817
Thanks Meter: 29
It's not bug. Disable OEM lock and enter your Samsung account. After reflash the device.
Отправлено с моего SM-G930F через Tapatalk
Old 09-02-2017, 16:19   #809 (permalink)
Member: 1061292
Thanks Meter: 5
you say check OEM lock then insert any samsung account in setting and finaly flash device?
Old 09-02-2017, 17:22   #810 (permalink)
Member: 2683817
Thanks Meter: 29
Yes
Page generated in 0.28055 seconds with 9 queries
