12-16-2016, 17:18 | #646 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 395897 Status: Offline Thanks Meter: 56 | Operation: Write CERT Selected model: SM-G920S Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G920S Android version: 6.0.1 Product code: Phone version: G920SKSU3DPK2 PDA version: G920SKSU3DPK2 CSC version: G920SSKC3DPK2 CSC country code: KOREA CSC sales code: SKC HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.5 |
12-17-2016, 05:50 | #647 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Not supported j120az 6.0.1 - read code UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J120AZ Software version: 27.5 Searching Samsung modem... detected COM162 Reading phone info... Ok Model: SM-J120AZ AP version: J120AZTUU2APJ2 CSC version: J120AZAIO2APJ2 CP version: J120AZTUU2APJ2 Product code: SM2J120AZKZAIO Phone SN: R58HB4X8VKE Unique number: CFN002B43FC96A3 Reading IMEI... Ok IMEI: 356419075722845 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 5C 71 DC D4 9C 39 B0 C0 BA 4E 8A 11 8E 9C 0F AE Reading NV data... error (1 5) Done with Samsung Tool PRO v.27.5 |
12-17-2016, 05:51 | #648 (permalink) |
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | Not supported j120az - 6.0.1 - unlock or new unlock UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J120AZ Software version: 27.5 Searching Samsung modem... detected COM162 Reading phone info... Ok Model: SM-J120AZ AP version: J120AZTUU2APJ2 CSC version: J120AZAIO2APJ2 CP version: J120AZTUU2APJ2 Product code: SM2J120AZKZAIO Phone SN: R58HB4X8VKE Unique number: CFN002B43FC96A3 Reading IMEI... Ok IMEI: 356419075722845 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.5 |
12-21-2016, 14:27 | #649 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | dear z3x team please add "nand erase all" as in odin because today i flash samsung A5100 with z3x and 5.1.1 version i give it to customer and after a few customer come back and say to me *#06# key not working i flashed phone with repair firmware but phone does not factory reset . when i hard reset the phone everything is ok but i request to Z3X team add option in z3x flasher "nand erase all" here is link of odin option https://forum.gsmhosting.com/vbb/****************************/?gmg08l34hwnhs2k |
12-22-2016, 23:38 | #650 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | Operation: Read CERT Selected model: SM-G920F Software version: 27.5 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: SM-G920FZDASEB Phone version: G920FXXS4DPIJ PDA version: G920FXXS4DPIJ CSC version: G920FOXX4DPH1 CSC country code: BALTIC CSC sales code: SEB HW version: MP 1.000 Phone SN: RF8H72QGF8Z Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: 20160730 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Exception: Cannot open file ''. The filename, directory name, or volume label syntax is incorrect Done with Samsung Tool PRO v.27.5 |
12-23-2016, 04:50 | #653 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
When keypad commands don't work, it's usually caused by a corrupted CS/CSC partition. Try reflashing a full stock firmware or a matching CS/CSC by itself. It may not need full nand erase. | |
12-24-2016, 13:26 | #654 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Enschede, The Netherlands Age: 41
Member: 8594 Status: Offline Thanks Meter: 13 | Remove G920F reactivation lock is not working anymore, it only tries to erase frp. Problem solved by using SamsungToolPRO_27.3, please add it back in next version of the software Code: Operation: Reset FRP/React/EE Selected model: SM-G920F Software version: 27.6 Searching Samsung USB Flash interface... COM30 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Code: Operation: Reset FRP/React/EE Selected model: SM-G920F Software version: 27.3 Searching Samsung USB Flash interface... COM30 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... Ok Erasing Reactivation lock... Ok Searching EE lock... Ok Erasing EE lock... Ok Reset done |
12-24-2016, 13:55 | #655 (permalink) |
Freak Poster Join Date: Apr 2015 Location: karachi, pakistan Age: 28
Member: 2374540 Status: Offline Sonork: 100.1675955 Thanks Meter: 32 | plzzz add g920p imei changer patch certification ......... plzzz add g920p imei changer patch certification thnxxxx ....... |
12-24-2016, 14:23 | #656 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 523957 Status: Offline Thanks Meter: 118 | Operation: Reset FRP Selected model: SM-J500H Selected port: Software version: 27.6 Waiting ADB device... timeout Phone not found First activate ADB Done with Samsung Tool PRO v.27.6 |
12-28-2016, 00:34 | #658 (permalink) |
Junior Member Join Date: May 2015 Location: Macedonia
Member: 2390679 Status: Offline Thanks Meter: 0 | Not supported samsung galaxy Luna SM-S120VL Any help for Samsung Galaxy Luna SM-S120VL for unlock or repair IMEI? This phone is locked to Tracfone Wireless network! Any help in Z3x box! |
12-29-2016, 18:56 | #659 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 45
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | Operation: Read CERT Selected model: SM-G316ML Software version: 27.6 Waiting ADB device... Ok Reading phone info... Model: SM-G316ML Android version: 4.4.4 Product code: SM-G316MZKLTGP Phone version: G316MLUBU0AOC3 PDA version: G316MLUBU0AOC3 CSC version: G316MLUUB0AOC3 CSC country code: PANAMA CSC sales code: TPA HW version: MP 0.300 Phone SN: R21G50FPY6K Modem board: SC7727S RF cal date: 20150507 IMEI: 357++++++++++ Checking Super user right... true Reading CERT... error (5) Done with Samsung Tool PRO v.27.6 |
12-30-2016, 21:28 | #660 (permalink) |
Junior Member Join Date: Jan 2016 Location: Europe
Member: 2519193 Status: Offline Thanks Meter: 2 | Hello, not working reset FRP! Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 5.1.1 Product code: SM-A510FZDDDDE Phone version: A510FXXU3API1 PDA version: FA51_A510FXXU3API1 CSC version: CSC country code: CSC sales code: HW version: MP 0.200 Phone SN: R58H916BFHW Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20160907 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' |
