05-11-2017, 22:03 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 509870 Status: Offline Thanks Meter: 2 | i dont understand same binary number for restore? |
05-11-2017, 22:44 | #6 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | What do you intend to do on this phone? Why do you want to downgrade? Also, show logs of operations with tool. |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
05-11-2017, 23:00 | #7 (permalink) |
Member: 509870 Status: Offline Thanks Meter: 2 | im trying to unlock it, i unlocked it and it worked for a little bit and now it says " roaming indicator off" it wont let me get into the roming options , there not there anymore.. nor the apn settings.. i tried network reset, SCRTN reset, rerooted and reunlocked, and Enabled gcf.. so i think i may of currupted the firmware.. whats best reflash the QC1 and do it again or downgade ? |
05-11-2017, 23:07 | #9 (permalink) |
Member: 509870 Status: Offline Thanks Meter: 2 | <ID:0/040> Added!! <ID:0/040> Removed!! <ID:0/004> Added!! <ID:0/004> Removed!! <ID:0/047> Added!! <ID:0/047> Removed!! <ID:0/004> Added!! <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin engine v(ID:3.1100).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> emmc_appsboot.mbn <ID:0/004> NAND Write Start!! <ID:0/004> lksecapp.mbn <ID:0/004> xbl.elf <ID:0/004> tz.mbn <ID:0/004> hyp.mbn <ID:0/004> devcfg.mbn <ID:0/004> pmic.elf <ID:0/004> rpm.mbn <ID:0/004> cmnlib.mbn <ID:0/004> keymaster.mbn <ID:0/004> apdp.mbn <ID:0/004> msadp.mbn <ID:0/004> cmnlib64.mbn <ID:0/004> sec.dat <ID:0/004> NON-HLOS.bin <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img.ext4 <ID:0/004> persist.img.ext4 <ID:0/004> modem.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> adspso.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> cache.img.ext4 <ID:0/004> meta-data/ <ID:0/004> meta-data/download-list.txt <ID:0/004> FAIL! <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1 |
05-11-2017, 23:07 | #10 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Open the Settings app. In the Wireless & Networks section, touch the More item. Choose Mobile Networks. . Remove the check mark by the Data Roaming option. If you cannot perform these operations because the settings are not there anymore, I will advice that you restore to it's original version to fix the errors. Once, unlocked, it will still remain unlocked even if you restore to original version |
05-11-2017, 23:21 | #13 (permalink) |
Member: 509870 Status: Offline Thanks Meter: 2 | QC1 failed to?? im choosing Home CSC and using odin 3 10.7 ? <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/004> Odin engine v(ID:3.1100).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> emmc_appsboot.mbn <ID:0/004> NAND Write Start!! <ID:0/004> lksecapp.mbn <ID:0/004> xbl.elf <ID:0/004> tz.mbn <ID:0/004> hyp.mbn <ID:0/004> devcfg.mbn <ID:0/004> pmic.elf <ID:0/004> rpm.mbn <ID:0/004> cmnlib.mbn <ID:0/004> keymaster.mbn <ID:0/004> apdp.mbn <ID:0/004> msadp.mbn <ID:0/004> cmnlib64.mbn <ID:0/004> sec.dat <ID:0/004> NON-HLOS.bin <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img.ext4 <ID:0/004> persist.img.ext4 <ID:0/004> meta-data/ <ID:0/004> meta-data/fota.zip <ID:0/004> FAIL! <ID:0/004> <ID:0/004> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
