10-01-2016, 14:26 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: East Coast
Member: 2189329 Status: Offline Thanks Meter: 8 | LG MS428 pattern lock I put the phone in download mode. LG 2-3G Tool v9.25 supported models: 1380 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.25) I cant find a root for this phone????? |
10-01-2016, 16:32 | #2 (permalink) |
Product Supporter Join Date: Feb 2007 Location: Europe
Member: 445973 Status: Offline Thanks Meter: 3,489 | Hi, Select H900 for example, Put phone in download mode, Press Reset Screen Lock button -- |
The Following User Says Thank You to andrew_tm For This Useful Post: |
10-02-2016, 02:40 | #3 (permalink) |
Member: 2189329 Status: Offline Thanks Meter: 8 | LG MS428 pattern lock this is what i keep getting LG 2-3G Tool v9.25 supported models: 1380 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.25) Not detect phone! Please manual select port or reboot PC! does the phone have to be rooted? Should i be connected to the z3x box or PC? |
10-02-2016, 07:39 | #4 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Quote:
Should be connected to the PC Search phone Press Reset Screen Lock button | |
The Following User Says Thank You to mbiborna For This Useful Post: |
10-02-2016, 14:52 | #6 (permalink) |
Member: 2189329 Status: Offline Thanks Meter: 8 | LG MS428 pattern lock Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.25) Phone mode is DOWNLOAD Start reset screen locks... Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: 358479073352084 Truncate file 0... Laf flash ext4 error: could not find inode for "/system/backuppin.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 1... Laf flash ext4 error: could not find inode for "/system/gesture.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 2... Laf flash ext4 error: could not find inode for "/system/password.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 3... done Truncate file 4... done Truncate file 5... done Screen locks removed. Elapsed: 42 secs. --> (v9.25) It has a APP called 360 security and I think that is what gives the pattern lock. Also now its stuck on the boot logo Metro Pc. when i try to factory reset the phone the program just locks up. |
10-02-2016, 15:20 | #7 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | If phone still Goes download mode Flash same Software verion: MS42810c Post result. |
10-02-2016, 17:27 | #8 (permalink) |
Member: 445973 Status: Offline Thanks Meter: 3,489 | You need reflash phone with checked: flash in direct mode erase user data after flash 360 security this not standard app. -- |
10-02-2016, 21:35 | #11 (permalink) |
Member: 2189329 Status: Offline Thanks Meter: 8 | LG MS428 pattern lock Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.25) Phone mode is DOWNLOAD Start flashing. Open KDZ File : C:\Users\NEW\Desktop\LG MS428\MS42810c_00_0514.kdz Model : LGMS428 SwVersion : MS42810c BuildTime : 0000-00-00 00:00:00 Total Files : 52 Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: 358479073352084 Laf cmd error: LAF_CMD_UNLINK fail[LAF_ERROR_FAILED]. Start indirect download mode. Sending image... Verifying image... Checking image... Flashing image... Done. Elapsed: 219 secs. --> (v9.25) |
10-02-2016, 21:52 | #12 (permalink) | ||
Member: 445973 Status: Offline Thanks Meter: 3,489 | Quote:
2. I write you in post: Quote:
10-02-2016, 23:41 | #13 (permalink) |
Member: 2189329 Status: Offline Thanks Meter: 8 | LG MS428 pattern lock I was able to remove 360 app security. 1st long press on the settings icon and drag it to the bottom bar. 2nd long press the settings icon and look for the 360 app and drag it to the uninstall location at top of screen. thats it the pattern lock is gone. I want to thank every body for there help. Oh by the way how do you unlock this phone. |
11-21-2016, 21:36 | #14 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Same issue trying to remove PIN lock from same model (normal PIN lock, not "360 security app"). Unable to get comport information , check system LG 2-3G Tool v9.27 supported models: 1397 Mode: Emergency Model: MS428 Elapsed: 2 secs. --> (v9.27) Phone mode is DOWNLOAD Start reset screen locks... Model name: LGMS428 Software verion: MS42810c Android verion: 6.0.1 IMEI: Truncate file 0... Laf flash ext4 error: could not find inode for "/system/backuppin.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 1... Laf flash ext4 error: could not find inode for "/system/gesture.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 2... Laf flash ext4 error: could not find inode for "/system/password.key". Laf flash ext4 error: [TruncateFile] could not find inode. Truncate file 3... done Truncate file 4... done Truncate file 5... done Screen locks removed. Elapsed: 50 secs. --> (v9.27) And phone stuck on Metro PCS logo and does not advance from there. Assistance needed please |
11-22-2016, 20:20 | #15 (permalink) | |
- flash in direct mode - erase user data after flash. -- | |
