Old 03-04-2016, 16:40   #15736 (permalink)
kingsoftaz's Avatar
Member: 1996171
Thanks Meter: 74
Unlock samsung T599N by z3x
Old 03-04-2016, 18:55   #15737 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
t999 unlock
  UNLOCK INSTRUCTIONS:
     Micro-USB cable:
  1. Phone must be powered on.
  2. Type *#0808# and select 'DM+MODEM+ADB'.
  3. Type *#9090# and choose USB (or 'DM/DUN over HSIC').
  4. Reboot phone.
  5. Connect USB cable, install drivers if needed.
  6. Select Samsung diagnostic port in port settings.
  7. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: SGH-T999
Selected port: COM89 SAMSUNG Mobile USB Serial Port
Software version: 24.0
Reading phone info...
Reading IMEI... OK
IMEI: 353022056325787
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.24.0
Old 03-04-2016, 18:56   #15738 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
j7 frp
   Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
     tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button for direct unlock.
   To reset Google account activation or Samsung reactivation lock:
  1. Power on phone in download mode (turn off phone, press vol.down + home + power).
  2. Connect phone to PC with USB cable, install drivers if needed.
  3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
    (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Reset FRP/React/EE
Selected model: SM-J700H/DS
Searching Samsung USB Flash Interface... detected COM49
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 03-04-2016, 19:02   #15739 (permalink)
Member: 2541058
note edge tmobile
software says phone is unlocked but is not what can it be thanks.
Old 03-04-2016, 22:59   #15740 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Unlock
Selected model: SM-N915T
Selected port: COM57 SAMSUNG Mobile USB Serial Port
Software version: 24.6
Reading IMEI... OK
IMEI: 35502XXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.24.6
Old 03-04-2016, 23:10   #15741 (permalink)
Member: 2541058
Originally Posted by Gambitv01 View Post
Operation: Unlock
Reading IMEI... OK
IMEI: 35502XXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
i have same model software says same thats is done but phone still locked
Old 03-05-2016, 00:21   #15742 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SGH-M919
File analysis... OK
Total file size: 0x96FE9CF8 (2415 Mb)
Searching USB Flash Interface... detected COM4
Sending aboot.mbn... OK
Sending sbl1.mbn... OK
Sending sbl2.mbn... OK
Sending sbl3.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending cache.img.ext4... OK
Sending hidden.img.ext4... OK
Sending modem.bin... OK
Sending NON-HLOS.bin... OK
Flashing done (time - 00:14:06)
Old 03-05-2016, 02:49   #15743 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Unlock
Selected model: SM-G900A
Selected port: COM29 SAMSUNG Mobile USB Serial Port
Software version: 24.4
Reading IMEI... OK
IMEI: 353920XXXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.24.4
Operation: Unlock
Selected port: COM35 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 352132XXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Operation: Unlock
Selected port: COM38 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 35469106XXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Operation: Unlock
Selected port: COM41 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 35392006XXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Operation: Unlock
Selected port: COM26 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 3539200XXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
Old 03-05-2016, 05:53   #15744 (permalink)
Member: 2125684
try version 23.5
Originally Posted by BowChaser View Post
I am trying to perform the IMEI repair on S3 (SGH-I747M). I am stuck at bypassing MSL. I keep getting "MSL... error" message. The phone is rooted.
Any help would be greatly appreciated.
Waiting ADB device... OK
Model: SGH-I747M
Android version: 4.4.2
Product code: SGH-I747MBBRWC
Phone version: I747MVLUFNF2
PDA version: I747MVLUFNF2
CSC version: I747MOYAFNF2
CSC country code: Canada
CSC sales code: RWC
HW version: REV0.4
Phone S/N: R21DB0B7FBA
Modem board: MSM8960
RF cal date: 2013.11.02
IMEI: 353************
Initialization AT RIL... OK
Bypass MSL... error
First reset MSL
Done with Samsung Tool PRO v.24.2
Reading IMEI... OK
IMEI: 353*********
Reseting MSL security... error
Try version 23.5 . I have the same problem with 24.2 while I am repairing my s4 i377m imei. Then I try version 23.5 and it worked perfectly.
Old 03-05-2016, 05:57   #15745 (permalink)
Member: 2087016
Thanks Meter: 67
http://s6.uplod.ir/i/00752/1495b3plflkn.png
Old 03-05-2016, 07:13   #15746 (permalink)
Member: 1948608
Thanks Meter: 1,744
SAM SM-J500F UNLOCK DONE JUST SINGLE CLICK....
Old 03-05-2016, 07:56   #15747 (permalink)
aitta7130's Avatar
Member: 320655
Thanks Meter: 28
unlock done I317M
Selected model: I317M
Selected port: COM10 Qualcomm HS-USB Diagnostics 9004
Selected port speed: 115200
Build: M9615ACEHWMAZD179550
Done with Samsung Tool v.19.1
Reading security... OK
Searching server... OK
NET lock: 16314049
Sub lock: 00000000
SP lock: 00000000
For check lock status: *#7465625#
Writing security... OK
Reseting...
Unlock done
Old 03-05-2016, 08:33   #15748 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Samsung S6500d unlocked done
Checking phone at COM343
Reading phone info... OK
Model: GT-S6500D
Country code: ªU
Cal date: ªU
Factory SW: S6500DXXMD1
Unique number: CS50299EF7E9F21
Memory phone: ªU
Phone S/N: RF1D31QVJE
PDA/CSC version: S6500DXXMD1/none
Phone version: S6500DXXMD1
Phone HW: MP 0.300
Cal date: 2013.03.06
Reading IMEI... OK
IMEI: 3529920562xxxxx
Bypass MSL... OK
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool v.20.5
Old 03-05-2016, 08:54   #15749 (permalink)
mr.luckytarun's Avatar
Member: 1195083
Sonork: QQ:3208821449
Thanks Meter: 1,348
GT-S8530i hang on logo solved by flash
[IMG][/IMG]
Old 03-05-2016, 10:24   #15750 (permalink)
Registered User
Member: 2538950
Sonork: 100.1672378:mota
Thanks Meter: 5
g928f unloking falid[QUOTE[ 3/5/2016 1:55:00 PM ] Operation: Unlock
[ 3/5/2016 1:55:00 PM ] Selected model: SM-G928F
[ 3/5/2016 1:55:00 PM ] Software version: 24.4
[ 3/5/2016 1:55:00 PM ] Waiting ADB device... OK
[ 3/5/2016 1:55:00 PM ] Reading phone info...
[ 3/5/2016 1:55:00 PM ] Model: SM-G928F
[ 3/5/2016 1:55:00 PM ] Android version: 5.1.1
[ 3/5/2016 1:55:00 PM ] Product code: SM-G928FZDAEVR
[ 3/5/2016 1:55:00 PM ] Phone version: G928FXXU1AOH3
[ 3/5/2016 1:55:00 PM ] PDA version: G928FXXU1AOH3
[ 3/5/2016 1:55:00 PM ] CSC version: G928FEVR1AOH1
[ 3/5/2016 1:55:00 PM ] CSC country code: UK
[ 3/5/2016 1:55:00 PM ] CSC sales code: EVR
[ 3/5/2016 1:55:00 PM ] HW version: MP 0.500
[ 3/5/2016 1:55:00 PM ] Phone S/N: R58G819H89L
[ 3/5/2016 1:55:00 PM ] Modem board: SHANNON333
[ 3/5/2016 1:55:00 PM ] RF cal date: 20150818
[ 3/5/2016 1:55:00 PM ] IMEI:
[ 3/5/2016 1:55:00 PM ] Checking Super user right... true
[ 3/5/2016 1:55:00 PM ] Initialization AT RIL... error (0)
[ 3/5/2016 1:58:00 PM ] Operation: Unlock
[ 3/5/2016 1:58:00 PM ] Selected model: SM-G928F
[ 3/5/2016 1:58:00 PM ] Software version: 24.6
[ 3/5/2016 1:59:00 PM ]
[ 3/5/2016 1:59:00 PM ] Waiting ADB device... OK
[ 3/5/2016 1:59:00 PM ] Reading phone info...
[ 3/5/2016 1:59:00 PM ] Model: SM-G928F
[ 3/5/2016 1:59:00 PM ] Android version: 5.1.1
[ 3/5/2016 1:59:00 PM ] Product code: SM-G928FZDAEVR
[ 3/5/2016 1:59:00 PM ] Phone version: G928FXXU1AOH3
[ 3/5/2016 1:59:00 PM ] PDA version: G928FXXU1AOH3
[ 3/5/2016 1:59:00 PM ] CSC version: G928FEVR1AOH1
[ 3/5/2016 1:59:00 PM ] CSC country code: UK
[ 3/5/2016 1:59:00 PM ] CSC sales code: EVR
[ 3/5/2016 1:59:00 PM ] HW version: MP 0.500
[ 3/5/2016 1:59:00 PM ] Phone S/N: R58G819H89L
[ 3/5/2016 1:59:00 PM ] Modem board: SHANNON333
[ 3/5/2016 1:59:00 PM ] RF cal date: 20150818
[ 3/5/2016 1:59:00 PM ] IMEI:
[ 3/5/2016 1:59:00 PM ] Checking Super user right... true
[ 3/5/2016 1:59:00 PM ] Initialization AT RIL... error (0)
][/QUOTE]
The Following User Says Thank You to mota ali For This Useful Post:
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.32387 seconds with 10 queries
