Old 03-31-2016, 09:42   #15931 (permalink)
zvrrr's Avatar
Member: 1995502
Thanks Meter: 139
Selected model: C3530
Selected com port: COM3
Selected speed port: 921600
Phone must be OFF
Press * and connect phone by USB cable
Connecting to Device... OK
Sending preloader ... OK
Sending loader ... OK
Damping ... OK
Damping ... OK
Damping ... OK
Damping ... OK
Damping ... OK
Patch block
Patch block
Already patched SW
Erasing ... OK
Writing ... OK
After power on phone - connect to UART cable
Phone SN: RF6B808447
Deactivate MSL - OK
Calculated code please wait...
Decrypted time: 25 sec
This is zone 0
[PCK]:Enter this without sim #0141*00000000# this is sim lock
[NCK]:Enter this without sim #0111*23535888# this is net lock
[SCK]:Enter this without sim #0121*00000000# this is CP lock
[SPCK]:Enter this without sim #0133*00000000# this is SP lock
[MCK]:Enter this without sim #0199*44371399# this is Master(freeze) code
Read info - ok
Elapsed time: 123 second, sw ver: 3.5.0040
Old 03-31-2016, 12:17   #15932 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
SM-G531H/DS FRP Reset Done
The Following User Says Thank You to Dilip_Nath For This Useful Post:
Old 04-01-2016, 11:03   #15933 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
samsung s3 mini i8200n unlock Done
Operation: Unlock
Selected model: GT-I8200N
Software version: 25.0
Waiting ADB device... OK
Reading phone info...
Model: GT-I8200N
Android version: 4.2.2
Product code: GT-I8200MBNVDI
Phone version: I8200NXXUANG1
PDA version: I8200NXXUANG1
CSC version: I8200NVFGANG1
CSC country code: Ireland
CSC sales code: VDI
HW version: MP 0.300
Phone S/N: R21FB08RBKN
Modem board: PXA986
RF cal date: 20141104
IMEI: 35991905xxxxxxx
Checking Super user right... true
Bypass MSL... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.25.0
Thanks z3x Team
The Following User Says Thank You to sr8787 For This Useful Post:
Old 04-01-2016, 15:08   #15934 (permalink)
Member: 1406357
Sonork: 100.1654421
Thanks Meter: 45
Operation: Unlock
Selected model: SM-G920T
Model: SM-G920T
Android version: 5.1.1
Product code: SM-G920TZKAXAR
Phone version: G920TUEU3COK1
PDA version: G920TUEU3COK1
CSC version: G920TXAR3COK1
CSC country code: USA
CSC sales code: XAR
HW version: REV1.0
Phone S/N: R58xxxxxxxx
Modem board: SHANNON333
RF cal date: 20150319
IMEI:
Initializating zTool... OK
Running zTool, please wait...
Start... OK
Init... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Unlocking... OK
Unlock done
The Following 2 Users Say Thank You to kiki49 For This Useful Post:
Old 04-01-2016, 18:45   #15935 (permalink)
Member: 841640
Thanks Meter: 86
SAMSUNG S6 EDGE+ (SM-G928C) FRP REMOVE
Operation: Reset FRP/React/EE
Selected model: SM-G928C
Searching Samsung USB Flash Interface... detected COM78
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... OK
Erasing Reactivation lock... OK
Searching EE lock... OK
Erasing EE lock... OK
Reset done
The Following 2 Users Say Thank You to lovist2 For This Useful Post:
Old 04-02-2016, 16:32   #15936 (permalink)
Member: 1501098
Thanks Meter: 4
g920f cert write successfull
Model: SM-G920F
Android version: 6.0.1
Product code: SM-G920FZWFVOD
Phone version: G920FXXS3DPC2
PDA version: G920FXXS3DPC2
CSC version: G920FVFG3DPC1
CSC country code: UK
CSC sales code: VOD
HW version: MP 0.80V
Phone S/N: RF8G50J4QVT
RF cal date: 20150509
IMEI:
Start... OK
Init... OK
Reading data... OK
Checking certificate file... OK
KEY ID: 0346
Calculating... OK
Writing nv data... OK
Write CERT done
The Following 2 Users Say Thank You to saaim For This Useful Post:
Old 04-02-2016, 21:48   #15937 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
repair imei sgh-i747 repair done
REPAIR INSTRUCTIONS:
Repair IMEI/Serial/BT/WiFi/Product Code:
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Reboot phone.
4. Connect USB cable, install drivers if needed.
5. Select Samsung diagnostic port in port settings.
6. Press 'Reset MSL' button to deactivate security.
7. Wait till phone reboot.
8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
9. Select device in ADB settings.
10. Fill values what you need to repair.
11. Press 'Repair' button.
Reset EFS, Disable Factory Mode:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button.
Wipe EFS/NVM:
If you have 'IMEI null/null' or 'Phone baseband unknown' errors,
Then you can try to repair this errors with this function.
1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power).
2. Connect USB cable, install drivers if needed.
3. Press 'Wipe EFS/NVM' button to deactivate security.
4. Wait till phone reboot.
Operation: Repair
Selected model: SGH-I747
Selected port: COM141 SAMSUNG Mobile USB Serial Port
Please, allow USB debugging on phone... OK
Model: SAMSUNG-SGH-I747
Android version: 4.4.2
Product code: Not Active
Phone version: I747UCUFNE4
PDA version: I747UCUFNE4
CSC version: I747ATTFNE4
CSC sales code: ATT
HW version: I747.00
Phone S/N: R21CA2W61YY
Modem board: MSM8960
RF cal date: NONE
IMEI:
Initialization AT RIL... OK
Bypass MSL... OK
Repairing IMEI... OK
Repair done
The Following 2 Users Say Thank You to ghacks For This Useful Post:
Old 04-03-2016, 11:38   #15938 (permalink)
Crazy Poster
Member: 1055926
Thanks Meter: 31
S6 G920F 6.0.1 Unlock Done !
First Root the phone with CF-Auto-Root-zeroflte-zerofltexx-smg920f.zip
Unlock codes did not work, But after Direct unlock - all ok
Operation: Read Codes
Selected model: SM-G920F
Checking hash file... OK
Model: SM-G920F
Product code: SM-G920FZWAITV
Phone version: G920FXXS3DPB3
PDA version: G920FXXS3DPB2
CSC version: G920FITV3DPB2
CSC country code: ITALY
CSC sales code: ITV
HW version: MP 0.800
Phone S/N: R28G30ESW3J
RF cal date: 20150305
IMEI:
Start... OK
Init... OK
Reading data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:09)
Freeze code: 81609080
NET lock: 61495963
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Operation: Unlock
Model: SM-G920F
CSC sales code: ITV
IMEI:
Start... OK
Init... OK
Reading data... OK
Calculating... OK
Unlocking... OK
Unlock done
The Following 4 Users Say Thank You to skynett_md For This Useful Post:
Old 04-03-2016, 12:01   #15939 (permalink)
Member: 155989
Thanks Meter: 14
Need imei repair
Hello all users
My samsung galaxy S6 SM-G920T need imei repair : 350000000000006/19
Not have Z3x box
Thank you
Old 04-03-2016, 13:43   #15940 (permalink)
Member: 2553197
Thanks Meter: 32
samsung sgh-i317 unlock done
The Following User Says Thank You to .:: A R X ::. For This Useful Post:
Old 04-03-2016, 15:09   #15941 (permalink)
anis_rainbow's Avatar
Member: 597569
Sonork: 100.1593870
Thanks Meter: 271
SM-J110G unlocked
Operation: Unlock
Selected model: SM-J110G
Model: SM-J110G
Android version: 4.4.4
Product code: SM-J110GZWDXME
Phone version: J110GDXU0AOH3
PDA version: J110GDXU0AOH2
CSC version: J110GOLB0AOH2
CSC country code: MALAYSIA
CSC sales code: XME
HW version: MP 0.400
Phone S/N: R58G91DS6QD
Modem board:
RF cal date: 20150917
IMEI: 353406070382306
Analysing SEC file... OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Old 04-03-2016, 15:15   #15942 (permalink)
mr.luckytarun's Avatar
Member: 1195083
Sonork: QQ:3208821449
Thanks Meter: 1,348
SM-G530H flash done
File analysis... OK
Total file size: 0x52A655EC (1322 Mb)
Searching USB Flash Interface... detected COM33
Set PIT file... OK
Sending aboot.mbn... OK
Sending sbl1.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending hyp.mbn... OK
Sending NON-HLOS.bin... OK
Sending sec.dat... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending persist.img.ext4... OK
Sending persdata.img.ext4... OK
Sending modem.bin... OK
Sending cache.img.ext4... OK
Sending hidden.img.ext4... OK
Flashing done (time - 00:03:14)
The Following User Says Thank You to mr.luckytarun For This Useful Post:
Old 04-04-2016, 01:50   #15943 (permalink)
Member: 2444830
Thanks Meter: 162
Operation: Unlock
Selected model: SM-N920W8
Model: SM-N920W8
Product code: SM-N920WZDAPCT
Phone version: N920W8VLU2AOK5
PDA version: N920W8VLU2AOK5
CSC version: N920W8UWA2AOL1
CSC country code: Puerto Rico
CSC sales code: PCT
HW version: REV1.0
Phone S/N: RF8G811FJ4F
RF cal date: 20150812
IMEI:
Start... OK
Init... OK
Reading data... OK
Calculating... OK
Unlocking... OK
Unlock done
Old 04-04-2016, 04:37   #15944 (permalink)
Member: 166459
Thanks Meter: 9
Model: SM-G925W8
Product code: SM-G925WZWERWC
Phone version: G925W8VLU3BOJ7
PDA version: G925W8VLU3BOJ7
CSC version: G925W8OYA3BOJ7
CSC country code: Canada
CSC sales code: RWC
HW version: REV0.1
Phone S/N: R58G61GNB8L
RF cal date: 20150905
IMEI:
Start... OK
Init... OK
Reading data... OK
Calculating... OK
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Selected model: SM-G930W8
Model: SM-G930W8
Product code: SM-G930WZKATLS
Phone version: G930W8VLU1APB7
PDA version: G930W8VLU1APB7
CSC version: G930W8OYA1APB7
CSC sales code: TLS
HW version: REV0.2
Phone S/N: R58H20TLLNM
Modem board: SHANNON335
RF cal date: 20160211
IMEI:
Start... OK
Init... OK
Reading data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:06)
Freeze code: 50394281
NET lock: 81814240
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Old 04-04-2016, 08:57   #15945 (permalink)
sr8787's Avatar
Member: 788946
Sonork: 100.1682685
Thanks Meter: 502
Samsung S5 unlock Done
Operation: Unlock
Selected model: SM-G900W8
Selected port: COM424 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 35230806xxxxxxx
Unlocking... OK
Reseting... OK
Unlock done
Thanks z3x Team
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.43466 seconds with 10 queries
