04-08-2016, 10:52 | #15977 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | FLASH INSTRUCTIONS: 1. Choose OPS file. 2. Check flashing options if needed (Use one package file, PDA format, EFS clear, Boot update). 2. Choose correct flash file(s). 3. Power on phone in download mode (turn off phone, hold Volume Up + Volume Down + Power or turn off phone, hold Volume Down + Power.) 4. Connect phone to PC with USB cable, install drivers if needed. 5. Press 'Flash' button. Operation: Flash Selected model: GT-S5670 Software version: 25.0 File analysis... OK Searching USB Flash Interface... detected COM28 Setup connection... OK Sending mibib... OK Sending qcsbl... OK Sending oemsbl... OK Sending amss... OK Sending arm11boot... OK Sending boot... OK Sending recovery... OK Sending system... OK Sending data... OK Sending csc... OK Reseting... OK Flashing done (time - 00:02:05) Done with Samsung Tool PRO v.25.0 |
04-08-2016, 11:18 | #15978 (permalink) |
No Life Poster Join Date: Oct 2008 Location: chennai
Member: 880497 Status: Offline Thanks Meter: 197 | N7505 Imei repair done vai Write Cert Operation: Write CERT Selected model: SM-N7505 Software version: 25.0 Checking certificate file... OK KEY ID: 0028 Waiting ADB device... OK Reading phone info... Model: SM-N7505 Android version: 4.3 Product code: Not Active Phone version: N7505XXUANAC PDA version: N7505XXUANB2 CSC version: N7505OJVANA4 CSC country code: France CSC sales code: XEF HW version: REV__ Phone S/N: RF8F20PAM6E Modem board: XMM7160 RF cal date: Unknown IMEI: 004999010640000 Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.25.0 |
The Following User Says Thank You to kathir. For This Useful Post: |
04-08-2016, 11:23 | #15979 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Samsung s5 unlock done Operation: Unlock Selected model: SM-G900F Selected port: COM435 SAMSUNG Mobile USB Serial Port Software version: 25.0 Reading phone info... Reading IMEI... OK IMEI: 356765068xxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.0 Thanks z3x team |
The Following User Says Thank You to sr8787 For This Useful Post: |
04-08-2016, 11:28 | #15980 (permalink) |
Freak Poster Join Date: Jun 2012 Location: India Pune
Member: 1778852 Status: Offline Sonork: 100.1641316 Thanks Meter: 231 | Samsung SM-E500H Write Cert File Done By Z3x Box BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-E500H Selected port: COM157 SAMSUNG Mobile USB Serial Port Software version: 24.6 Checking certificate file... OK KEY ID: 0056 Waiting ADB device... OK Reading phone info... Model: SM-E500H Android version: 5.1.1 Product code: SM-E500HZKDINS Phone version: E500HXXU1BOI6 PDA version: E500HXXU1BPA1 CSC version: E500HODD1BPC1 CSC country code: India CSC sales code: INS HW version: MP 0.800 Phone S/N: RZ1G21JKETH Modem board: MSM8216 RF cal date: 2015.10.02 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0056 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.24.6 |
The Following 2 Users Say Thank You to Gsm Narendra For This Useful Post: |
04-08-2016, 20:14 | #15982 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung Galaxy XCover 2 S7710 Direct Unlock done.. UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button. Operation: Unlock Selected model: GT-S7710 Software version: 25.0 Waiting ADB device... OK Reading phone info... Model: GT-S7710 Android version: 4.1.2 Product code: GT-S7710TAAMOB Phone version: S7710XXAMB6 PDA version: S7710XXAMB6 CSC version: CSC country code: CSC sales code: HW version: MP 0.900 Phone S/N: RV1F6153ZGN Modem board: DB8520H RF cal date: 2014.06.17 IMEI: 352735062760XXX Checking Super user right... true Reading data from phone... OK Analysing SEC file... OK Bypass MSL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.0 |
04-08-2016, 22:46 | #15983 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2510231 Status: Offline Thanks Meter: 11 | Sm-n920p ok3 unlock Operation: Unlock SPRNT Selected model: SM-N920P Software version: 25.1 Waiting ADB device... OK Reading phone info... Model: SM-N920P Android version: 5.1.1 Product code: Not Active Phone version: N920PVPS2AOK3 PDA version: N920PVPS2AOK3 CSC version: N920PSPT2AOK3 CSC country code: USA CSC sales code: SPR HW version: N920P.03 Phone S/N: 00000000000 Modem board: MDM9635M RF cal date: 2015.08.01 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.1 |
04-08-2016, 22:54 | #15984 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SGH-T999L Android version: 4.3 Product code: Not Active Phone version: T999LUVUBNC1 PDA version: T999LUVUBNC1 CSC version: T999LTMBBNC1 CSC country code: USA CSC sales code: TMB HW version: T999L.00 Phone S/N: R21DA9PVT9B Modem board: MSM8960 RF cal date: 2012.07.09 IMEI: 355XXXXXXXXXXXXX Initialization AT RIL... OK Bypass MSL... OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.25.0 |
04-08-2016, 22:54 | #15985 (permalink) |
04-09-2016, 11:13 | #15986 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | Operation: Reset FRP/React/EE Selected model: SM-J500H Selected port: Software version: 25.1 Searching Samsung USB Flash Interface... detected COM15 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.1 |
04-09-2016, 11:13 | #15987 (permalink) |
04-09-2016, 14:27 | #15988 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung E1200I Unlock code read done.. UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: GT-E1200I Selected port: COM52 SciCmpst Diag Software version: 25.0 Reading phone info... OK IMEI Master: 3595160668139XX Product code: GT-E1200ZWITSC Phone HW: MP 0.400 Phone S/N: R21G41BJDE Reading codes... OK Please wait, calculating codes... OK (time - 00:01:33) Freeze code: 72909302 NET lock: 68281460 Sub lock: 00000000 SP lock: 25725279 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.0 |
04-09-2016, 14:27 | #15989 (permalink) |
04-10-2016, 11:02 | #15990 (permalink) |
Member: 880497 Status: Offline Thanks Meter: 197 | S7392 Flashing failed with Odin,Done by z3x Operation: Flash Selected model: GT-S7392 Software version: 25.0 File analysis... OK Total file size: 0x332DC068 (818 Mb) Searching USB Flash Interface... detected COM54 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... OK Sending dt-blob... OK Sending cache.img... OK Sending system.img... OK Sending hidden.img... OK Sending param.lfs... OK Flashing done (time - 00:02:20) Done with Samsung Tool PRO v.25.0 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
