01-07-2019, 14:23 | #271 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung s7 edge g935f emergency call only fix done 7.0 to 6.0 samsung s7 edge g935f emergency call only fix done 7.0 to 6.0 1st downgrade 7.0 to 6.0 download this fiile G935FXXS1BPLO_G935FOLB1CPK5_MYM flash FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G935F Software version: 27.5 File analysis... Ok Total file size: 0x10C5C4ECC (4293 Mb) Searching USB Flash interface... COM49 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:05:26) Done with Samsung Tool PRO v.27.5 after flash imei 0000000000 root mobile repier imei mobile show emergency calll only open z3x 27.5 and patch certificate REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G935F Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1CPK2 PDA version: G935FXXS1BPLO CSC version: G935FOLB1CPK5 CSC country code: THAILAND CSC sales code: THL HW version: Phone SN: RF8H50BL1WX Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.5 |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
01-07-2019, 14:42 | #272 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung j200h flash done samsung j200h flash done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J200H Software version: 34.6 File analysis... OK Total file size: 0x50E56994 (1294 Mb) Searching USB Flash interface... COM49 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending spl.img... OK Sending sboot.bin... OK Sending sboot2.bin... OK Sending param.lfs... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending SPRDCP.img... OK Sending SPRDDSP.img... OK Sending nvitem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:01:48) Done with Samsung Tool PRO v.34.6 |
01-07-2019, 19:35 | #273 (permalink) |
No Life Poster Join Date: Nov 2018 Location: Everywhere Your Not
Member: 2875052 Status: Offline Thanks Meter: 211 | Samsung SM G955F Read Codes Successfully Done Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G955F Android version: 8.0.0 PDA version: G955FXXU4CRK1 CSC version: G955FEVR4CRK1 Phone version: G955FXXU4CRK1 Product code: SM-G955FZSAEVR CSC country code: UK CSC sales code: EVR Phone SN: RF8JC1JXCLP IMEI: 351558090xxxxxx HW version: MP 0.501 RF cal date: 20171215 Chip name: EXYNOS8895 Modem board: SHANNON355 Security patch: 2018-11-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 61707058 NET lock: 74860208 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.6 |
01-08-2019, 10:52 | #274 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Mirpur Azad Kashmir Age: 34
Member: 1154111 Status: Offline Sonork: 100.1620855 Thanks Meter: 158 | G570F frp done You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-G570F Android version: 7.0 PDA version: G570FXXU1BQL2 CSC version: G570FOJV1BQL2 Phone version: G570FXXU1BQI6 Product code: SM-G570FZKAXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: R58JA2J836H IMEI: 357766081399698 HW version: MP 0.500 RF cal date: 20171012 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-12-01 Boot Warranty bit: 0 SIM State: READY Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.34.6 |
01-09-2019, 12:09 | #279 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | SM-J330FN Read Codes Done! Reading phone info... Model: SM-J330FN Android version: 7.0 PDA version: J330FNXXU3ARD1 CSC version: J330FNORS3ARD1 Phone version: J330FNXXU3ARB3 Product code: SM-J330FZSNORS CSC country code: Slovakia CSC sales code: ORS Phone SN: R58JC13FW0B IMEI: 353644097XXXXXXX HW version: MP 0.500 RF cal date: 20171208 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-04-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 42070290 NET lock: 72415831 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.6 |
01-09-2019, 12:37 | #280 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 414 | G930W8 u4 8.0 unlock modem free This modem file encrypts the storage so make sure to back up your file first 1. Flash this modem file https://www.4shared.com/archive/66p6...Feiselski.html 2. Hard reset the phone if encrypted. 3.On z3x select G930W8 and hit unlock. no root needed Operation: Unlock Selected model: SM-G930W8 Software version: 34.6 Searching Samsung modem... detected COM312 Reading phone info... Model: SM-G930W8 AP version: G930W8VLS4CRH1 CSC version: G930W8OYA4CRH1 CP version: G930W8VLU4ARH1 Product code: BMC Phone SN: R58H71P33MH IMEI: 356252073213636 Unique number: CE0616061B160F0B05 Reading IMEI... OK IMEI: 356252073213636 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done |
01-09-2019, 13:22 | #281 (permalink) |
Junior Member Join Date: Dec 2008
Member: 934162 Status: Offline Thanks Meter: 2 | N750 / n7500q z3x İmeİ repaİr ok %100 tried and tested .................. Install the 4.4.2 rom on your phone :N750XXUCNH2_OXECNH1_v4.4.2_Repair_Firmware thiss Select model C111 and perform imei repair Select model t311 and perform patch certificate 100% LIVED AND RESULT RECEIVED : D: D: D: D |
The Following 2 Users Say Thank You to bsore For This Useful Post: |
01-10-2019, 14:07 | #283 (permalink) |
Freak Poster Join Date: May 2015 Location: Morocco Age: 28
Member: 2392471 Status: Offline Thanks Meter: 25 | unlock j510f with credit z3x Done 100% Operation: Read Codes via Server Selected model: SM-J510F Software version: 34.6 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? No Operation: Read Codes via Server Selected model: SM-J510F Selected port: COM1 Port de communication Software version: 34.6 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes ADB device not selected Operation: Read Codes via Server Selected model: SM-J510F Selected port: COM1 Port de communication Software version: 34.6 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J510F Android version: 7.1.1 PDA version: J510FXXU2BRE2 CSC version: J510FOJW2BRD1 Phone version: J510FXXU2BRE1 Product code: SM-J510FZKAMAT CSC country code: MOROCCO CSC sales code: MAT Phone SN: RV8J20QYCWW IMEI: 357424073672231 HW version: MP 0.300 RF cal date: 2017.03.03 Chip name: MSM8916 Modem board: MSM8916 Security patch: 2018-06-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM174 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 02860709 NET lock: 59575094 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# |
01-10-2019, 18:17 | #284 (permalink) |
Major Poster Join Date: Mar 2017 Location: Ukraine
Member: 2696899 Status: Offline Sonork: [email protected] Thanks Meter: 8 | Unlock sim SM-J330F done ! Checking Login and Password... OK Ballance: 50 crd. You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330F Android version: 7.0 PDA version: J330FXXU3ARC5 CSC version: J330FXEO3ARC2 Phone version: J330FXXU3ARC3 Product code: SM2J330FZKDXEO CSC country code: Poland CSC sales code: XEO Phone SN: R58K******* IMEI: 35849********** HW version: MP 0.500 RF cal date: 20180730 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-04-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 60970486 NET lock: 57941481 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.6 |
