12-09-2023, 21:57 | #2191 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Tarragona, Spain
Member: 36126 Status: Offline Thanks Meter: 311 | C3510 Flash and Unlock Samsung C3510 Flash with Rumanian language and Unlock it was resisting to unlock before Flash and was with Movistar Spain but needed Romanian language so flashed with this Rom C3510XXJI1_OXEJJ1 from Z3X support and unlocked, All went Superb. WBR Here is the log Selected model: C3510 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok TFS flash - ok Start Flash CSC CSC format - ok Mount CSC - ok Create DIR - ok CSC flash - ok Write signature - ok Download - ok Elapsed time: 1380 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3510 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Unlock - ok Elapsed time: 21 second, sw ver: 3.5.0040 |
01-07-2024, 16:13 | #2192 (permalink) |
Freak Poster Join Date: Mar 2020 Location: bolivia
Member: 2951556 Status: Offline Thanks Meter: 243 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch CERT Aug 2019 Selected model: SM-G610M Software version: 45.14 Waiting ADB device... OK Reading phone info... Model: SM-G610M Android version: 7.0 PDA version: G610MUBU1BQK9 CSC version: G610MUUB1BQL1 Phone version: G610MUBU1BQK8 Product code: SM-G610MZKGBVO CSC country code: Bolivia CSC sales code: BVO Phone SN: R5xxxxxxxxx IMEI: 357xxxxxxxxxxxx HW version: MP 0.100 RF cal date: 20170424 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-08-01 Boot Warranty bit: 1 SIM State: READY Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.45.14 [SM-G610M,Patch CERT Aug 2019] |
01-11-2024, 07:06 | #2193 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G920f repair securiety success UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Unlock Selected model: SM-G920F Selected port: COM11 USB Serial Port Software version: 45.14 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 PDA version: G920FXXU6EVG1 CSC version: G920FAUT6EVG1 Phone version: G920FXXU6ERF6 Product code: SM-G920FZKAVOD CSC country code: Switzerland CSC sales code: AUT Phone SN: RF8GA1MMDJL IMEI: 35980710XXXXXXXXXXXX HW version: MP 1.00V RF cal date: 20160625 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: C8 24 0E EE B5 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.45.14 [SM-G920F,Unlock] |
01-11-2024, 08:09 | #2194 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 428 | G532F Patch Success REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-G532F Software version: 45.14 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 PDA version: G532FXWU1ARE1 CSC version: G532FOJV1ARE1 Phone version: G532FXXU1ARB1 Product code: SM-G532FZDDEGY CSC country code: Egypt CSC sales code: EGY Phone SN: RV8JC01HEDP IMEI: 35013618xxxxxxxx HW version: MP 0.300 RF cal date: 20171206 Chip name: MT6737T Modem board: MT6737T Security patch: 2018-05-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Preparation of data... OK Writing data to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.45.14 [SM-G532F,Patch Certificate] |
01-11-2024, 23:14 | #2195 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Read Codes via Server [Mar 2020] Selected model: SM-G930F Software version: 45.14 Checking Login and Password... OK Balance: 15 crd. You have 15 credit(s) left. This operation takes 0 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 8.0.0 PDA version: G930FXXS8ETK3 CSC version: G930FUWT8ETCA Phone version: G930FXXS8ETCZ Product code: SM-G930FZKLCHT CSC country code: Chile CSC sales code: CHT Phone SN: R58xxxxxxxx IMEI: 357xxxxxxxxxxxx HW version: MP 0.700 RF cal date: 20160301 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code(MCK, PUK): 61571860 NET lock: 93082594 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.45.14 [SM-G930F,Read Codes via Server [Mar 2020]] |
01-17-2024, 19:26 | #2196 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 243 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J500M Software version: 45.14 Searching Samsung USB Flash interface... COM22 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.45.14 [SM-J500M,Reset FRP/React/EE] |
02-14-2024, 20:06 | #2197 (permalink) |
Member: 2951556 Status: Offline Thanks Meter: 243 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-G532M Software version: 45.14 Waiting ADB device... OK Reading phone info... Model: SM-G532M Android version: 6.0.1 PDA version: G532MUMU1AQA3 CSC version: G532MUUB1AQA1 Phone version: G532MUBU1APL6 Product code: SM-G532MZKATPA CSC country code: PANAMA CSC sales code: TPA Phone SN: RV8Kxxxxxxxxxxx IMEI: 354xxxxxxxxxxxx HW version: MP 0.300 RF cal date: 20180502 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-01-01 Boot Warranty bit: 1 SIM State: ABSENT Checking Super user right... true Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Preparation of data... OK Writing data to phone... OK Rebooting phone... OK Done with Samsung Tool PRO v.45.14 [SM-G532M,Patch Certificate] |
02-23-2024, 08:45 | #2198 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Samsung GT E2530 unlock done Selected model: E2530 Selected com port: COM7 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 14 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: E2530 Selected com port: COM7 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Phone SN: RP3B800767 Deactivate MSL - OK Calculated code please wait... Decrypted time: 55 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*90123460# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*94675172# this is Master(freeze) code Read info - ok Elapsed time: 125 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
03-31-2024, 14:35 | #2199 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | SM-A300FU Unlocking... OK Operation: Unlock Selected model: SM-A300FU Selected port: COM24 SAMSUNG Mobile USB Serial Port Software version: 45.14 Reading phone info... Reading IMEI... OK IMEI: 359655067695625 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.45.14 [SM-A300FU,Unlock] |
04-03-2024, 08:03 | #2200 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | A225FXXU6DWE3 Frp done Code: Operation: Reset FRP Selected model: SM-A225F Software version: 45.14 Searching Samsung modem... detected COM315 Reading phone info... Model: SM-A225F AP version: A225FXXU6DWE3 CSC version: A225FOXM6DWE3 CP version: A225FXXU6DWE3 OS version: 13 Product code: SKZ Phone SN: R58RC4QCESB IMEI: 355221178956242 IMEI2: 357893208956240 Unique number: CDP007746D47968 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.45.14 [SM-A225F,Reset FRP] |
04-08-2024, 11:54 | #2201 (permalink) |
Junior Member Join Date: Jun 2012 Location: nigeria
Member: 1772864 Status: Offline Thanks Meter: 0 | Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-G960F Software version: 45.14 Checking Login and Password... OK Balance: 14 crd. You have 14 credit(s) left. This operation takes 8 credits. Attention! In case if phone asking MCK(Freeze, PUK) code, using this method will consume credits twice - first for MCK(Freeze, PUK) code and then for NCK(Network, PIN). Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960F Android version: 10 PDA version: G960FXXSEFUA1 CSC version: G960FOVFEFUA1 Phone version: G960FXXSEFUA1 Product code: SM-G960FZPAVOD CSC country code: UK CSC sales code: VOD Carrier ID: VOD Phone SN: 23d9f9b72b037ece IMEI: 359664095666467 HW version: MP 0.900 RF cal date: 20180907 Chip name: EXYNOS9810 Modem board: SHANNON360 Security patch: 2021-02-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Checking SIM status... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Executing... OK Searching Ramdump interface... COM11 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... OK Now only the MCK(Freeze, PUK) code will be calculated. Continue? Yes Searching server... OK Waiting for server answer... OK Freeze code (MCK, PUK): 05936192 To calculate NCK(Network, PIN, REGIONAL) code perfom the following operations: 1. Insert the SIM card. 2. Enter the MCK(Freeze, PUK) code. 3. Remove the SIM card. 4. Reboot phone. 5. Try again. PLS RETURN MY CREDIT. THE CODE DID NOT WORK USERNAME :zsc_mdlTGTPP |
04-23-2024, 10:23 | #2203 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Philippines
Member: 853601 Status: Offline Thanks Meter: 251 | Samsung B3410 Sun Locked Openline Done Quote:
