01-19-2019, 09:41 | #317 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung j7 pro j730f after update 8.0 touch not working fix samsung j7 pro j730f after update 8.0 touch not working fix 1st mobile flash combination file frp off FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J730F Software version: 34.8 File analysis... OK Total file size: 0x42BDAE40 (1067 Mb) Searching USB Flash interface... COM27 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending nad_fw.bin... OK Sending nad_refer.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Flashing done (time - 00:01:07) Done with Samsung Tool PRO v.34.8 after flash combination file flash only BL..AP..CSC touch or working REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. Operation: Flash Selected model: SM-J730F Software version: 34.8 File analysis... OK Total file size: 0xEC634052 (3782 Mb) Searching USB Flash interface... COM27 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:37) Done with Samsung Tool PRO v.34.8 |
01-19-2019, 11:59 | #318 (permalink) |
Freak Poster Join Date: Apr 2010 Location: peshawar
Member: 1282804 Status: Offline Sonork: 1636760 Thanks Meter: 82 | T479 unlock done by z3x 2019 ok Reading phone info... OK Model: SGH-T479 Country code: ¹Ì±¹/TMB Cal date: 2010-05-11 Factory SW: UVJE4 Unique number: 76250000263505 Memory phone: K5R2G1GACC(T479)S Phone SN: R8YZ513320 Reading IMEI... OK IMEI: 359402030313071 Reading software version... OK Phone version: T479UVJE4 Searching sysinfo... OK Reading SYSINFO... OK Please wait, calculating codes... OK (time - 00:00:20) Freeze code: 97479738 NET lock: 47527182 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 12369874 SIM lock: 12369874 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-20-2019, 11:12 | #320 (permalink) |
Junior Member Join Date: Mar 2012 Location: Turkmenistan
Member: 1730870 Status: Offline Sonork: sulik Thanks Meter: 2 | Samsung G532G unlock done without root Operation: Read Codes Selected model: SM-G532G Software version: 34.8 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SM-G532G Android version: 6.0.1 PDA version: G532GDXU1AQA4 CSC version: Phone version: G532GDXU1APL3 Product code: SM-G532GZDD CSC country code: CSC sales code: Phone SN: RR8KB09AKCA IMEI: 354357081253912 HW version: MP 0.300 RF cal date: 20181109 Chip name: MT6737T Modem board: MT6737T Security patch: 2017-01-01 Boot Warranty bit: 0 SIM State: ABSENT,NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM18 detected Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:23) Freeze code: 81950249 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 71368646 SIM lock: -------- For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-20-2019, 13:00 | #321 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,698 | SAMSUNG-SM-G891A read code Operation: Read Codes via Server Selected model: SM-G891A Selected port: COM307 SAMSUNG Mobile USB Serial Port Software version: 34.8 Checking Login and Password... OK Ballance: 13 crd. You have 13 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G891A Android version: 7.0 PDA version: G891AUCS2BQE1 CSC version: G891AATT2BQE1 Phone version: G891AUCS2BQE1 Product code: SM2G891AZAAATT CSC country code: USA CSC sales code: ATT Phone SN: R38HA0GW4RF IMEI: 3517130xxxxxxx31 HW version: REV0.5 RF cal date: 2016.10.21 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-05-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 94074268 NET lock: 40314938 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.34.8 |
01-20-2019, 23:32 | #322 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 227 | Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960U Android version: 8.0.0 PDA version: G960USQU3BRJ5 CSC version: G960UOYN3BRJ5 Phone version: G960USQU3BRJ5 Product code: SM-G960UZPATMB CSC country code: USA CSC sales code: TMB Phone SN: R28K238BM0W IMEI: 354825090243421 HW version: REV1.1 RF cal date: 2018.03.02 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-10-01 Boot Warranty bit: 0 SIM State: ABSENT Searching Samsung diag port... detected COM18 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM20 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.3 |
01-21-2019, 11:09 | #323 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | a310f screen lock remove without data loss Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM65 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: A310FXXU3BQC8 Platform: exynos7580 Boot serial: 3100f1e71a0f43ed Product board: a3xelte Erasing locks... OK Rebooting phone... OK Reset locks done Done with Samsung Tool PRO v.34.8 |
01-21-2019, 13:47 | #324 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,338 | LG H840(LGH840) aka LG G5 SE FRP Reset done! LG 2-3G Tool v9.53 supported models: 1562 Mode: Emergency Model: H840 Read info... Laf Protocol: 01000004 Model name: LG-H840 Software verion: H84011h Android verion: 6.0.1 Target operator: GLOBAL Target country: COM Chipset: msm8952 IMEI: 3579XXXXXXXXXXX Elapsed: 6 secs. --> (v9.53) Phone mode is DOWNLOAD Start reset FRP... Laf Protocol: 01000004 Model name: LG-H840 Software verion: H84011h Android verion: 6.0.1 Target operator: GLOBAL Target country: COM Chipset: msm8952 IMEI: 3579XXXXXXXXXXX Detecting write method... Init write method... fail Init misc method... done Resetting... done FRP Reset done! Elapsed: 5 secs. --> (v9.53) |
01-21-2019, 18:14 | #325 (permalink) |
Insane Poster Join Date: Oct 2017 Location: algeria
Member: 2768436 Status: Offline Sonork: 100.650600 Thanks Meter: 5 | j730f 8.1 u2 ulock done En attendant le périphériqueADB... Ok Lecture d'information du telephone... Modèle: SM-J730F Android version: 7.0 PDA version: J730FXXU2ARB1 CSC version: J730FXEF2ARB1 Version du telephone: J730FXXU2ARB1 Code du produit: SM-J730FZKDXEF SCC code de pays: France CSC code de vente: XEF Téléphones SN: R58K706191D IMEI: 3592*******889423 HW version: MP 0.500 RF cal date: 20180702 Nom de la puce: EXYNOS7870 Prise modem: SHANNON315 Security patch: 2018-02-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED,ABSENT Vérification de droit de super utilisateur... vrai La lecture des données deNV... Ok VérificationNV data ... Ok Lecturedata... Ok Détection MODEM... Ok LectureMODEM... Ok Calcul... Ok Initialisationdata... Ok Redémarrage téléphone... Ok En attendant le périphériqueADB... Ok Waiting for device to become ready... Ok RédactionzTool... Ok InitialisationzTool... Ok CourirzTool, s'il vous plaît patienter... Ok Lecture de données... Ok HWID: 4F 9E 2B E9 2E 66 D5 61 B6 54 37 60 EF 1E 10 49 Calcul... Ok Déblocage... Ok RédactionNV data... Ok Redémarrage téléphone... Ok Désimlockage Effectué Fait avecSamsung Tool PRO v.34.6 root files : 1- recovery : https://mega.nz/#!8TQnXIaQ!Z4sXoGO0r...pyyKK9pxYRVBWY 2- root : https://mega.nz/#!kBlmEYrK!2RfM0P-y3...0oYIouIC1gbb9g |
01-21-2019, 18:50 | #326 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | j337a bit4 unlock server Operation: Unlock Selected model: SM-J337A Software version: 34.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J337A Android version: 8.0.0 PDA version: J337AUCU4ARL1 CSC version: J337AATT4ARL1 Phone version: J337AUCU4ARL1 Product code: SM2J337AZKBATT CSC country code: USA CSC sales code: ATT Phone SN: RFggggggggg IMEI: 3521451jjjjjjjjj HW version: REV0.7 RF cal date: 20181011 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-12-01 Boot Warranty bit: 0 SIM State: READY Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Unlocking... OK Unlock done Done with Samsung Tool PRO v.34.8 |
01-21-2019, 18:53 | #327 (permalink) |
Member: 2549748 Status: Offline Thanks Meter: 212 | Lg h872pr unlock by z3x After unlock Operation ,if imei put ''0'' repair with IMEI 0 FIX LG 2-3G Tool v9.59 supported models: 1568 Mode: Normal Model: LGH872PR Build version: Aug 17 201719:38:04May 31 201723:00:00LGH872PR SW Version: MPSS.TH.2.0.1.c3.1-00018-M8996FAAAANAZM-1 IMEI: 00000000000000-0 BlueTooth Address: 00:00:00:00:00:00 Phone Code: default Elapsed: 1 secs. --> (v9.59) Checking phone at COM24 Detected ID: 00001010 (MSM8996) SW Version: MPSS.TH.2.0.1.c3.1-00018-M8996FAAAANAZM-1 Reading ESN... OK Read SPC... SPC: 000000 Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Laf Protocol: 01000005 Model name: LG-H872PR Software verion: H87210a Android verion: 7.0 Target operator: CLR Target country: PR Chipset: msm8996 IMEI: 000000000000000 Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\H872PR_000000000000000_21012019_121038.l gsb1 Write security zone... Erase part1... done Erase part2... done Erase part3... done Reboot... Phone detected! Reading QCN file... OK Checking phone at COM24 Detected ID: 00001010 (MSM8996) SW Version: MPSS.TH.2.0.1.c3.1-00018-M8996FAAAANAZM-1 Read SPC... SPC: 000000 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 482 secs. --> (v9.59) |
01-21-2019, 21:40 | #328 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Santiago de Cuba
Member: 2510340 Status: Offline Thanks Meter: 74 | unlock g965u_bit 3_Xfinyty s9 plus just flash the combo modem in bit 3 and read codes with z3x Operation: Read Codes via Server Selected model: SM-G965U Software version: 34.8 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G965U Android version: 8.0.0 PDA version: G965USQS3BRK2 CSC version: G965UOYN3BRK2 Phone version: G965USQU3ARG2 Product code: SM4G965UZKACCT CSC country code: USA CSC sales code: CCT Phone SN: R28K72BCLEY IMEI: 35xxxxxxxxxxxxx HW version: REV1.1 RF cal date: 2018.07.26 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-12-01 Boot Warranty bit: 0 SIM State: ABSENT Searching Samsung diag port... detected COM49 Reading phone info... OK Reading data from phone... error (1), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM56 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 28572702 NET lock: 48406403 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# |
The Following 2 Users Say Thank You to duboy For This Useful Post: |
01-22-2019, 00:14 | #329 (permalink) |
Major Poster Join Date: Feb 2018 Location: mexico Age: 40
Member: 2815735 Status: Offline Thanks Meter: 15 | UNLOCK SUCCESS J737TI METRO PCS WHIT Z3X THANKS Operation: Unlock Selected model: SM-J737T1 Software version: 34.8 Checking Login and Password... Listo Ballance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits.Continue? Si Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-J737T1 Android version: 8.0.0 PDA version: J737T1UVS3ARK1 CSC version: J737T1TMK3ARK1 Versión del telefono: J737T1UVS3ARK1 Código del Producto: SM2J737TZSATMK Código de país CSC: USA Código de Venta CSC: TMK Phone SN: R58KB391ARY IMEI: 359797092895265 HW version: REV1.0 RF cal date: 20181115 Chip name: EXYNOS7870 Módem: SHANNON315 Security patch: 2018-11-01 Boot Warranty bit: 0 SIM State: READY Initialization zTool... Listo Running zTool, please wait... Listo Lectura de datos desde el teléfono ... Listo Buscando servidor... Listo Checking server answer... Listo Executing... Listo Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Waiting ADB device... Listo Waiting for device to become ready... Listo Initialization zTool... Listo Running zTool, please wait... Listo Lectura de datos desde el teléfono ... Listo Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.34.8 |
01-22-2019, 01:24 | #330 (permalink) |
Member: 2815735 Status: Offline Thanks Meter: 15 | UNLOCK SUCCESS SAMSUNG J260T1 METRO PCS THANKS Operation: Unlock Selected model: SM-J260T1 Software version: 34.8 Checking Login and Password... Listo Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Si Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-J260T1 Android version: 8.1.0 PDA version: J260T1UVU1ARK8 CSC version: J260T1TMK1ARK8 Versión del telefono: J260T1UVU1ARK8 Código del Producto: SM2J260TZKATMK Código de país CSC: USA Código de Venta CSC: TMK Phone SN: R28KC0R3YFM IMEI: 352000000000000 HW version: REV1.0 RF cal date: 20181212 Chip name: EXYNOS7570 Módem: SHANNON305 Security patch: 2018-11-01 Boot Warranty bit: 0 SIM State: READY Initialization zTool... Listo Running zTool, please wait... Listo Lectura de datos desde el teléfono ... Listo Buscando servidor... Listo Checking server answer... Listo Executing... Listo Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Waiting ADB device... Listo Waiting for device to become ready... Listo Initialization zTool... Listo Running zTool, please wait... Listo Lectura de datos desde el teléfono ... Listo Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.34.8 |
