07-12-2019, 19:46 | #856 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-G950F Software version: 36.8 Checking Login and Password... OK Ballance: 22 crd. You have 22 credit(s) left. This operation takes 5 credits.Continue? Sim Waiting ADB device... OK Obtendo informações do celular... Modelo: SM-G950F Android version: 9 PDA version: G950FXXS5DSF1 CSC version: G950FOXM5DSF1 Versão do Celular: G950FXXS5DSF1 Código do Produto: SM2G950FZKAAUT CSC country code: Switzerland CSC sales code: AUT Phone SN: RF8K90GC3QK IMEI: 351717104156389 HW version: MP 0.700 RF cal date: 20180907 Chip name: EXYNOS8895 Modem board: SHANNON355 Security patch: 2019-06-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Obtendo dados do celular... OK Procurando servidor... OK Checking server answer... OK Executing... OK Obtendo dados do celular... error (0 15) Reboot phone and try again. Check ADB drivers, USB cable. Don't use USB Hubs If this repeated then reflash phone and make factory reset. Done with Samsung Tool PRO v.36.8 |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
07-13-2019, 07:54 | #857 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 36
Member: 2371500 Status: Offline Thanks Meter: 5,828 | Samsung Galaxy J7 SM-J700H 6.0.1 efs done BACKUP INSTRUCTIONS: EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Info Selected model: SM-J700H/DS Software version: 36.8 Searching Samsung modem... detected COM432 Reading phone info... Model: SM-J700H AP version: J700HXXS3BQC4 CSC version: J700HOJV2BPL1 CP version: J700HXXU3BQC2 Product code: SM-J700HZKDMID Phone SN: R51J200L2TD IMEI: 352205086399267 IMEI2: 352206086399265 Unique number: C0000D568B10CA3 Reading IMEI... OK IMEI: 352205086399267 (SIGN: OK) IMEI 2: 352206086399265 (SIGN: OK) Done with Samsung Tool PRO v.36.8 BACKUP INSTRUCTIONS: EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Read certificate via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT DIAG' button to read certificates. Operation: Read EFS Selected model: SM-J700H/DS Software version: 36.8 Waiting ADB device... OK Reading phone info... Model: SM-J700H Android version: 6.0.1 PDA version: J700HXXS3BQC4 CSC version: J700HOJV2BPL1 Phone version: J700HXXU3BQC2 Product code: SM-J700HZKDMID CSC country code: Iraq CSC sales code: MID Phone SN: R51J200L2TD IMEI: 352205086399267 HW version: MP 0.401 RF cal date: 20170204 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 Boot Warranty bit: 0 Checking Super user right... true Reading EFS from phone... OK Saved to D:\BST\SamsungToolPRO\backup\EFS\EFS_SM-J700H_J700HXXS3BQC4_352205086399267_R51J200L2TD_13-7-2019_9-50-43.tar Done with Samsung Tool PRO v.36.8 |
07-13-2019, 09:41 | #858 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | Searching Samsung USB Flash interface... COM11 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.36.8 |
07-14-2019, 04:41 | #859 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Puerto Rico
Member: 2549748 Status: Offline Thanks Meter: 212 | Sm-T380 frp bit 3 [Done] first flash full combination COMBINATION_OLB_FA70_T380DXU3ASD1_OLBFAC_CL1206213 5_QB23349593_REV00_user_mid_noship_MULTI_CERT.tar then select g935p and frp put in download mode flash full stock but in AP area untick userdata and CSC select HOME CSC after that active oem unlock ,reset and full flash stock Code: UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-G935P Software version: 36.8 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-T380 Android version: 8.1.0 PDA version: T380DXS3BSD2 CSC version: T380UVS3BSD1 Phone version: Product code: SM-T380NZKAXAR CSC country code: PANAMA CSC sales code: TPA Phone SN: R52K70QXW4D IMEI: HW version: RF cal date: Chip name: MSM8937 Modem board: Security patch: 2019-04-01 Boot Warranty bit: 0 Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.36.8 |
07-16-2019, 13:01 | #860 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 201 | A105G unlocked. Code: Operation: Read Codes via Server Selected model: SM-A105G Software version: 36.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A105G Android version: 9 PDA version: A105GDXU1ASE1 CSC version: A105GOLM1ASD2 Phone version: A105GDXU1ASD3 Product code: SM-A105GZRGXME CSC country code: MALAYSIA CSC sales code: XME Phone SN: R58xxxxxxxxx IMEI: 35xxxxxxxxxxxxxx HW version: MP 0.300 RF cal date: 20190605 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 09319753 NET lock: 61479464 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.36.8 |
07-19-2019, 12:43 | #863 (permalink) | |
Junior Member Join Date: May 2017
Member: 2713083 Status: Offline Thanks Meter: 12 | Z3X say unlock done but phone remain locked I have one that I tried to unlock with z3x and it took me 5 credit, on the final opration it said unlock done but phone remain locked Quote:
07-19-2019, 15:46 | #865 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Unlock Selected model: SM-J737T1 Software version: 36.8 Checking Login and Password... OK Ballance: 34 crd. You have 34 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J737T1 Android version: 8.0.0 PDA version: J737T1UVS5ASE1 CSC version: J737T1TMK5ASE1 Phone version: J737T1UVS5ASE1 Product code: SM2J737TZSATMK CSC country code: USA CSC sales code: TMK Phone SN: R58M30KRXMM IMEI: 3558651xxxxxxxx HW version: REV1.0 RF cal date: 20190305 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-05-01 Boot Warranty bit: 0 SIM State: READY Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.36.8 |
07-20-2019, 19:50 | #866 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-A105M Software version: 36.8 Checking Login and Password... OK Ballance: 29 crd. You have 29 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A105M Android version: 9 PDA version: A105MUBU1ASD1 CSC version: A105MOWA1ASC7 Phone version: A105MUBU1ASC7 Product code: SM-A105MZRMCDR CSC country code: Dominican Republic CSC sales code: CDR Phone SN: R28M515A6JH IMEI: 3558601xxxxxxxx HW version: MP 0.300 RF cal date: 20190515 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-02-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 97190575 NET lock: 25738261 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.36.8 |
07-20-2019, 21:37 | #867 (permalink) |
Freak Poster Join Date: Jul 2018
Member: 2851505 Status: Offline Sonork: 100.750600 Thanks Meter: 22 | samsung tool pro v36.8 Support Flash Model Port POA verston; CSC version: 3260TITMKIASA3 Phone version: 3260TIUVUIASA3 Product code: SM2) 260TZKATMK Country code CSC: USA CSC Sales Code: TMK Phone SN: R28MIOXSLCT IMEI: 35 HW version: REVI.O RF cal date: 20190111 chip name: EXYNOS7570 Modem: SHANNON305 Security patch: 2019-01-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool ... LÉto Running zToolt please wat ... LÉto Reading data from the phone ... Ready Looking for a sitter ... Ready Checkhg server answer ... Done Executhg ... Done Reading data from the phone • LSto Calculating ", LSto Searching server ", Ready Watúng for server answer ", LÉto watrjg ADB device ", Done Watng for device to become ready ", 'Initi & atjon zT001 ", Ready Runnhg zTool, please wait ", LÉto Reading data from the phone LSto Renting phone Ready Clearing Done |
07-21-2019, 13:44 | #868 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2417530 Status: Offline Thanks Meter: 0 | T380 frp binary 3 frp need help T380 FRP HELP NEED HELP HELP ME TO FIND COMBINATION BINARY 3 MOBILE INFO Connecting to Phone,Wait...Done Getting phone Infor... MN(SM-T380) BASE(SM-N900) VER(T380DXU3BSD1/T380XNZ3BSD1/T380DXU3BSD1/T380DXU3BSD1) HIDVER(T380DXU3BSD1/T380XNZ3BSD1/T380DXU3BSD1/T380DXU3BSD1) MNC() MCC() PRD(XNZ) OMCCODE() SN(R52M100BKXE) HVID(Data:196609,Cache:262145,System:327681) >>Done! |
07-22-2019, 15:42 | #870 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Cote d'Ivoire
Member: 841640 Status: Offline Thanks Meter: 87 | SAMSUNG SM-J737T1 SUCCESSFULLY UNLOCKED WITH Z3x BOX ( 5 crédits ) UNLOCK INSTRUCTIONS: Unlocking using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-J737T1 Software version: 36.8 Checking Login and Password... OK Ballance: 10 crd. You have 10 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J737T1 Android version: 8.0.0 PDA version: J737T1UVS5ASE1 CSC version: J737T1TMK5ASE1 Phone version: J737T1UVS5ASE1 Product code: SM2J737TZSATMK CSC country code: USA CSC sales code: TMK Phone SN: R58M466ALKX IMEI: 3558651xxxxxxxx HW version: REV1.0 RF cal date: 20190423 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-05-01 Boot Warranty bit: 0 SIM State: SIM_SERVICE_PROVIDER_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.36.8 |
