10-29-2019, 15:51 | #1171 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Selected model: SM-G550T1 Software version: 38.2 Searching Samsung USB Flash interface... COM489 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.38.2 |
10-29-2019, 18:55 | #1172 (permalink) |
Freak Poster Join Date: Mar 2009 Location: morocco Age: 38
Member: 986038 Status: Offline Thanks Meter: 43 | oppo f11 pro done format password Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0B00B01052118F1C, ,FW Ver.: 01.63 CMD Pullup Level:2165 mV CMD Active Level:3093 mV Box IO Level:3300 mV CLK Rate:3000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D42021F5590CAC508 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 525701322 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB , 0xE8F6000 pages , 0x1D1EC00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 368 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000DE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x01D0800000 (432.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01EB800000 (108.742GB) , formatting... Done. Done. Done. |
11-01-2019, 11:03 | #1173 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | A260g unlock done Code: Checking Login and Password... OK Ballance: 7 crd. You have 7 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A260G Android version: 8.1.0 PDA version: A260GDDU1ASD7 CSC version: A260GODM1ASD7 Phone version: A260GDDU1ASD3 Product code: SM-A260GZKGINS CSC country code: India CSC sales code: INS Phone SN: RZ8M70YEGBP IMEI: 357348108800000 HW version: MP 0.300 RF cal date: 20190705 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-04-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 74024704 NET lock: 74817261 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.38.2 |
11-01-2019, 15:06 | #1174 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Reset FRP/React/EE Selected model: SM-J500M Software version: 38.2 Searching Samsung USB Flash interface... COM489 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.38.2 |
11-02-2019, 09:07 | #1175 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,338 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Repair Selected model: SM-A105F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-A105F Android version: 9 PDA version: A105FDDU1ASD2 CSC version: A105FOJM1ASCB Phone version: A105FDDU1ASC9 Product code: SM-A105FZKEXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RF8M50WJ3TK IMEI: 355 HW version: MP 0.300 RF cal date: 20190507 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-02-01 Boot Warranty bit: 0 SIM State: ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Writing security... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-A105F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-A105F Android version: 9 PDA version: A105FDDU1ASD2 CSC version: A105FOJM1ASCB Phone version: A105FDDU1ASC9 Product code: SM-A105FZKEXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RF8M50WJ3TK IMEI: 350 HW version: MP 0.300 RF cal date: 20190507 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-02-01 Boot Warranty bit: 1 SIM State: ABSENT Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
11-02-2019, 09:08 | #1176 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,338 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Repair Selected model: SM-A205F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 9 PDA version: A205FXXU1ASC5 CSC version: A205FOJM1ASC5 Phone version: A205FDDU1ASC6 Product code: SM-A205FZKEXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: R58M41959MZ IMEI: 35 HW version: REV0.3 RF cal date: 20190406 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-02-01 Boot Warranty bit: 0 SIM State: LOADED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Writing security... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-A205F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 9 PDA version: A205FXXU1ASC5 CSC version: A205FOJM1ASC5 Phone version: A205FDDU1ASC6 Product code: SM-A205FZKEXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: R58M41959MZ IMEI: 35 HW version: REV0.3 RF cal date: 20190406 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-02-01 Boot Warranty bit: 1 SIM State: LOADED Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
11-02-2019, 09:08 | #1177 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,338 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-J260F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-J260F Android version: 8.1.0 PDA version: J260FXXU1ARH7 CSC version: J260FOJM1ARH6 Phone version: J260FXXU1ARGF Product code: SM-J260FZKAXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RZ8K90JY8QD IMEI: 35 HW version: MP 0.500 RF cal date: 20180907 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2018-07-01 Boot Warranty bit: 1 SIM State: READY Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
11-02-2019, 14:03 | #1178 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,338 | REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Repair Selected model: SM-J600F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-J600F Android version: 9 PDA version: J600FXXU5BSH5 CSC version: J600FOJM5BSH5 Phone version: J600FXXU5ASH1 Product code: SM-J600FZPAXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RZ8K81G75CM IMEI: 35 HW version: REV0.3A RF cal date: 20180818 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-09-01 Boot Warranty bit: 0 SIM State: LOADED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Writing security... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 REPAIR INSTRUCTIONS: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reboot to...' button and select mode to reboot (download or recovery). Operation: Patch Certificate Selected model: SM-J600F Software version: 38.2 Waiting ADB device... OK Reading phone info... Model: SM-J600F Android version: 9 PDA version: J600FXXU5BSH5 CSC version: J600FOJM5BSH5 Phone version: J600FXXU5ASH1 Product code: SM-J600FZPAXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RZ8K81G75CM IMEI: 35 HW version: REV0.3A RF cal date: 20180818 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-09-01 Boot Warranty bit: 1 SIM State: LOADED Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
11-03-2019, 13:46 | #1179 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Reset FRP/React/EE Selected model: SM-G550T Software version: 38.2 Searching Samsung USB Flash interface... COM489 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.38.2 |
11-03-2019, 21:40 | #1180 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | g920t unlock done make root bit 6 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 PDA version: G920TUVS6FRC1 CSC version: G920TTMB6FRC1 Phone version: G920TUVS6FRC1 Product code: SM2G920TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R58G92PA86M IMEI: 357746063xxxxxxx HW version: REV1.0 RF cal date: 20150930 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-03-01 Boot Warranty bit: 1 SIM State: ABSENT Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 48 A8 8D 0F F4 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.38.2 use this file to root http://h**ps://download.chainfire.eu...ue-smg920t.zip |
