12-03-2020, 08:50 | #1636 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bandarabbas
Member: 2859531 Status: Offline Thanks Meter: 73 | g925a u7 7 patch cert done Reading phone info... Model: SAMSUNG-SM-G925A Android version: 7.0 PDA version: G925AUCS7ERA2 CSC version: G925AATT7ERA2 Phone version: Product code: CSC country code: USA CSC sales code: ATT Phone SN: 00000000000 IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2018-01-01 Boot Warranty bit: 0 Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done |
12-03-2020, 10:23 | #1637 (permalink) |
Banned Join Date: Oct 2016 Location: In Your Heart
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Samsung J2 Hang On Samsung Logo Done With Flash Z3x Samsung Tool Pro FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J200G Software version: 41.2 File analysis... OK Total file size: 0x8DD11790 (2269 Mb) Searching USB Flash interface... COM57 detected Setup connection... OK Reading PIT from phone... OK Sending recovery.img... OK Sending system.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:20) Done with Samsung Tool PRO v.41.2 |
12-03-2020, 14:41 | #1638 (permalink) |
Freak Poster Join Date: Nov 2019 Location: Ghana
Member: 2938458 Status: Offline Thanks Meter: 59 | A105FN UNLOCK DONE Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A105FN Android version: 9 PDA version: A105FNXXU2ASK5 CSC version: A105FNOXM2ASK3 Phone version: A105FNXXU2ASJ2 Product code: SM-A105FZKUBTU CSC country code: UK & IRE CSC sales code: BTU Carrier ID: BTU Phone SN: R*********B IMEI: 3*************0 HW version: MP 0.100 RF cal date: 20200103 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2019-10-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04279282 NET lock: 38139162 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.10 |
12-06-2020, 16:38 | #1639 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-A115M Software version: 41.11 Checking Login and Password... OK Ballance: 13 crd. You have 13 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A115M Android version: 10 PDA version: A115MUBS1ATK4 CSC version: A115MOWA1ATH1 Phone version: A115MUBS1ATK4 Product code: SM-A115MZKACDR CSC country code: Dominican Republic CSC sales code: CDR Carrier ID: CDR Phone SN: R9JN413ZALJ IMEI: 3540761xxxxxxxx HW version: MP1.0 RF cal date: 2420.21.16 Chip name: SDM450 Modem board: SDM450 Security patch: 2020-11-01 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Trying to enable diag port... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM279 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM34 detected Reading data from phone... OK Calculating... Searching server... OK Waiting for server answer... OK Freeze code: 63648075 NET lock: 07427403 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.11 |
12-06-2020, 16:39 | #1640 (permalink) |
12-07-2020, 17:57 | #1642 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Software version: 41.11 Checking Login and Password... OK Ballance: 33 crd. You have 33 credit(s) left. This operation takes 6 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 9 PDA version: G950USQS8DTJ2 CSC version: G950UOYN8DTJ2 Phone version: G950USQS8DTJ2 Product code: SM-G950UZVATMB CSC country code: USA CSC sales code: TMB Carrier ID: TMB Phone SN: R28J83X5Z2N IMEI: 3577530XXXXXXXX HW version: REV1.0 RF cal date: 2017.08.25 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2020-10-01 Boot Warranty bit: 0 SIM State: ABSENT Waiting for device to become ready... OK Searching Samsung diag port... detected COM289 Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM34 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.41.11 |
12-08-2020, 15:54 | #1643 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 50
Member: 77043 Status: Offline Thanks Meter: 2 | [ 12/8/2020 4:24:00 PM SM-G973U Unlock ] You have 15 credit(s) left. This operation takes 10 credits.Continue? Yes [ 12/8/2020 4:24:00 PM SM-G973U Unlock ] Waiting ADB device... OK [ 12/8/2020 4:24:02 PM SM-G973U Unlock ] Reading phone info... [ 12/8/2020 4:24:03 PM SM-G973U Unlock ] Model: SM-G973U [ 12/8/2020 4:24:03 PM SM-G973U Unlock ] Android version: 10 [ 12/8/2020 4:24:04 PM SM-G973U Unlock ] PDA version: G973USQS4ETJ2 [ 12/8/2020 4:24:04 PM SM-G973U Unlock ] CSC version: G973UOYN4ETJ2 [ 12/8/2020 4:24:04 PM SM-G973U Unlock ] Phone version: G973USQS4ETJ2 [ 12/8/2020 4:24:05 PM SM-G973U Unlock ] Product code: SM-G973UZWATMB [ 12/8/2020 4:24:05 PM SM-G973U Unlock ] CSC country code: USA [ 12/8/2020 4:24:06 PM SM-G973U Unlock ] CSC sales code: TMB [ 12/8/2020 4:24:06 PM SM-G973U Unlock ] Carrier ID: SPR [ 12/8/2020 4:24:06 PM SM-G973U Unlock ] Phone SN: RF8M30RMR4N [ 12/8/2020 4:24:07 PM SM-G973U Unlock ] IMEI: -------------- [ 12/8/2020 4:24:07 PM SM-G973U Unlock ] HW version: REV1.0 [ 12/8/2020 4:24:08 PM SM-G973U Unlock ] RF cal date: 2019.03.06 [ 12/8/2020 4:24:08 PM SM-G973U Unlock ] Chip name: SM8150 [ 12/8/2020 4:24:08 PM SM-G973U Unlock ] Modem board: SM8150 [ 12/8/2020 4:24:09 PM SM-G973U Unlock ] Security patch: 2020-11-01 [ 12/8/2020 4:24:09 PM SM-G973U Unlock ] Boot Warranty bit: 0 [ 12/8/2020 4:24:09 PM SM-G973U Unlock ] SIM State: CARD_IO_ERROR [ 12/8/2020 4:24:15 PM SM-G973U Unlock ] Waiting for device to become ready... OK [ 12/8/2020 4:24:18 PM SM-G973U Unlock ] Reading IMEI... OK [ 12/8/2020 4:24:19 PM SM-G973U Unlock ] Initialization zTool... OK [ 12/8/2020 4:24:20 PM SM-G973U Unlock ] Running zTool, please wait... OK [ 12/8/2020 4:24:24 PM SM-G973U Unlock ] Checking network lock status... LOCKED [ 12/8/2020 4:24:25 PM SM-G973U Unlock ] Reading data from phone... OK [ 12/8/2020 4:24:25 PM SM-G973U Unlock ] Searching server... OK [ 12/8/2020 4:24:29 PM SM-G973U Unlock ] Waiting for server answer... [ 12/8/2020 4:44:01 PM SM-G973U Unlock ] Operation aborted |
12-08-2020, 15:55 | #1644 (permalink) |
12-08-2020, 23:07 | #1647 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-A315G Software version: 41.11 Checking Login and Password... OK Ballance: 21 crd. You have 21 credit(s) left. This operation takes 3 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A315G Android version: 10 PDA version: A315GDXU1ATEB CSC version: A315GOWE1ATF1 Phone version: A315GDXU1ATF1 Product code: SM-A315GZKMDOR CSC country code: DOMINICAN REPUBLIC CSC sales code: DOR Carrier ID: DOR Phone SN: RF8N804TKTZ IMEI: 3559031xxxxxxxx HW version: MP0.2B0 RF cal date: 20200804 Chip name: MT6768 Modem board: MT6768 Security patch: 2020-06-01 Boot Warranty bit: 0 SIM State: ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Ramdump interface... COM34 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 02817916 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 49574196 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.11 |
12-08-2020, 23:07 | #1648 (permalink) |
12-09-2020, 18:53 | #1650 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-G965U1 Software version: 41.11 Checking Login and Password... OK Ballance: 18 crd. You have 18 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G965U1 Android version: 10 PDA version: G965U1UES7DTE1 CSC version: G965U1OYM7DTE1 Phone version: G965U1UES7DTE1 Product code: SM-G965UZBAATT CSC country code: USA CSC sales code: ATT Carrier ID: ATT Phone SN: R38K20AHG4V IMEI: 3546410xxxxxxxx HW version: REV1.1 RF cal date: 2018.02.22 Chip name: SDM845 Modem board: SDM845 Security patch: 2020-05-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM301 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM34 detected Reading data from phone... OK Calculating... Searching server... OK Waiting for server answer... OK Freeze code: 06364074 NET lock: 36026384 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.41.11 |
