06-18-2022, 13:16 | #1981 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | A127F Patch Selected model: SM-A127F Software version: 44.10 Waiting ADB device... OK Reading phone info... Model: SM-A127F Android version: 11 PDA version: A127FXXU5AVC4 CSC version: A127FOXM5AVC4 Phone version: A127FXXU5AVC3 Product code: SM-A127FZBUSKZ CSC country code: Kazakhstan CSC sales code: SKZ Carrier ID: SKZ Phone SN: RF8RA1ACPXP IMEI: 35687XXXXXXXXXX HW version: REV1.0 RF cal date: 20211028 Chip name: EXYNOS850 Modem board: SHANNON318 Security patch: 2022-03-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Root version: 24.3:MAGISKSU Checking data... OK Searching server... OK Checking server answer... OK Data preparation... OK Searching server... OK Waiting for server answer... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.44.10 [SM-A127F,Patch Certificate] |
06-18-2022, 13:39 | #1982 (permalink) |
Junior Member Join Date: Apr 2017 Location: Sherpur,Bangladesh
Member: 2705008 Status: Offline Sonork: 12885689 Thanks Meter: 7 | UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-J410F Software version: 44.10 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting for device to become ready... OK Reading phone info... Model: SM-J410F Android version: 8.1.0 PDA version: J410FXXS2ATC1 CSC version: J410FOJM2ASL2 Phone version: J410FXXS2ATC1 Product code: SM-J410FZDDKSA CSC country code: KSA CSC sales code: KSA Phone SN: R28M11XM9TL IMEI: 353XXXXXXXXXXX HW version: MP 0.200B RF cal date: 2019.01.21 Chip name: MSM8917 Modem board: MSM8917 Security patch: 2020-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM10 Initialization zTool... OK Running zTool, please wait... OK Executing... OK Searching Ramdump interface... COM11 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 82470617 NET lock: 63742815 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.44.10 [SM-J410F,Read Codes via Server] |
06-22-2022, 12:08 | #1983 (permalink) |
Freak Poster Join Date: Apr 2007 Location: ZANZIBAR
Member: 496694 Status: Offline Thanks Meter: 95 | samsung wide 4 frp done. UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Reset FRP Selected model: SM-A205S Software version: 44.11 Searching Samsung modem... detected COM264 Reading phone info... Model: SM-A205S AP version: A205SKSU7CUK1 CSC version: A205SSKC7CUK1 CP version: A205SKSU7CUK1 OS version: 11 Product code: SKC Phone SN: R59N900RFLD IMEI: NONE Unique number: CBJ0086148FB787 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.11 [SM-A205S,Reset FRP] |
06-22-2022, 12:09 | #1984 (permalink) |
Member: 496694 Status: Offline Thanks Meter: 95 | samsung wide 4 (a205s) samsung wide 4 frp done. UNLOCK INSTRUCTIONS: To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Reset FRP Selected model: SM-A205S Software version: 44.11 Searching Samsung modem... detected COM264 Reading phone info... Model: SM-A205S AP version: A205SKSU7CUK1 CSC version: A205SSKC7CUK1 CP version: A205SKSU7CUK1 OS version: 11 Product code: SKC Phone SN: R59N900RFLD IMEI: NONE Unique number: CBJ0086148FB787 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.11 [SM-A205S,Reset FRP] |
06-26-2022, 11:00 | #1985 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | Samsung A037G U1 imei 00000 Repair and Patch Done Operation: Repair [ROOT] Selected model: SM-A037G Software version: 44.11 Waiting ADB device... OK Reading phone info... Model: SM-A037G Android version: 11 PDA version: A037GXXU1AUH6 CSC version: A037GOXM1AUH6 Phone version: A037GXXU1AUH4 Product code: SM-A037GZKNBTU CSC country code: UK & IRE CSC sales code: BTU Carrier ID: EUX Phone SN: R9PR90ELFVM IMEI: 000000000000000 HW version: REV1.0 RF cal date: 20210829 Chip name: MT6765 Modem board: MT6765 Security patch: 2021-08-01 Boot Warranty bit: 1 SIM State: LOADED,ABSENT Checking Super user right... true Root version: 23.0:MAGISKSU Saving security data... [sec0] ... [sec1] ... [sec2] ... [sec3] ... OK Backup saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\backup\NV\SM-A037G_R9PR90ELFVM_000000000000000_2022-06-26_14-56-19.bkp Searching server... OK Waiting for server answer... OK Checking data... OK Reading 'boot' image... OK Loading data from 'boot'... OK Reading 'modem' image... OK Loading data from 'modem'... OK Preparation of data... OK Initialization zTool... OK Running zTool, please wait... OK Executing... OK Reparing... OK Rebooting phone... OK Done with Samsung Tool PRO v.44.11 [SM-A037G,Repair [ROOT]] |
07-02-2022, 13:15 | #1986 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | G920T simple flash FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G920T Software version: 44.11 File analysis... OK Total file size: 0xDB370740 (3507 Mb) Searching USB Flash interface... COM33 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending modem.bin... OK Flashing done (time - 00:04:47) Done with Samsung Tool PRO v.44.11 [SM-G920T,Flash] |
07-08-2022, 11:01 | #1987 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Sm-g998b reset frp done Code: Searching Samsung modem... detected COM20 Reading phone info... Model: SM-G998B AP version: G998BXXU5CVDD CSC version: G998BOXM5CVDD CP version: G998BXXU5CVDD OS version: 12 Product code: CAU Phone SN: R5CR314HZPW IMEI: 350299947613521 IMEI2: 352817867613524 Unique number: CE022152B91705CD197E Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.11 [SM-G998B,Reset FRP] |
07-08-2022, 16:10 | #1988 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-A032M Software version: 44.11 Checking Login and Password... OK Balance: 11 crd. You have 11 credit(s) left. This operation takes 1 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A032M Android version: 11 PDA version: A032MUBU1AVC1 CSC version: A032MOWE1AVC1 Phone version: A032MUBU1AVC1 Product code: SM-A032MZBADOR CSC country code: DOMINICAN REPUBLIC CSC sales code: DOR Carrier ID: DOR Phone SN: R7SRC340NZT IMEI: 351517234550125 HW version: REV1.0 RF cal date: 2021.12.05 Chip name: UNISOC_9863A Modem board: SC9863a Security patch: 2022-02-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Searching Samsung modem... detected COM68 Executing... OK Searching server... OK Waiting for server answer... OK Freeze code: 40496909 NET lock: 40496909 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.44.11 [SM-A032M,Read Codes via Server] |
07-11-2022, 14:20 | #1989 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 576 | Operation: Read Codes via Server Selected model: SM-A325M Software version: 44.11 Checking Login and Password... OK Balance: 5 crd. You have 5 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A325M Android version: 11 PDA version: A325MUBS2AVD1 CSC version: A325MOWA2AUJ4 Phone version: A325MUBS2AVD1 Product code: SM-A325MZKMCDR CSC country code: Dominican Republic CSC sales code: CDR Carrier ID: CDR Phone SN: RF8RA15S0VR IMEI: 3562633179xxxxx HW version: MP 0.200 RF cal date: 20211026 Chip name: MT6769T Modem board: MT6765 Security patch: 2022-04-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Using method: [Oct 2021] Searching Samsung modem... detected COM160 Executing... OK Searching Ramdump interface... detected COM16 Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 24640913 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 60753185 For check lock status: *#7465625# Done with Samsung Tool PRO v.44.11 [SM-A325M,Read Codes via Server] |
07-11-2022, 14:20 | #1990 (permalink) |
07-17-2022, 14:45 | #1993 (permalink) |
Insane Poster Join Date: May 2021 Location: Pakistan. Rajanpur
Member: 2989274 Status: Offline Thanks Meter: 20 | Sm-a217f u8 imei repair done by z3x king Operation: Repair Selected model: SM-A217F Software version: 44.11 Waiting ADB device... OK Reading phone info... Model: SM-A217F Android version: 11 PDA version: A217FXXS8CVD1 CSC version: A217FOJM8CVC2 Phone version: A217FXXU8CVC2 Product code: SM-A217FZKJPAK CSC country code: PAKISTAN CSC sales code: PAK Carrier ID: PAK Phone SN: RF8NXXXXXXX IMEI: 3523XXXXXXXXXX HW version: MP 0.500 RF cal date: 20201007 Chip name: EXYNOS850 Modem board: SHANNON318 Security patch: 2022-04-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Checking Super user right... true Root version: 24.3:MAGISKSU Checking data... OK Searching server... OK Checking server answer... OK Data preparation... OK Initialization zTool... OK Running zTool, please wait... OK Executing 1st step... OK Executing 2nd step... OK Searching server... OK Waiting for server answer... OK Reparing... OK Rebooting phone... OK Last edited by Bismillah.; 07-17-2022 at 14:52. |
07-31-2022, 08:29 | #1994 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | Samsung A3s A037F U1 Successful Patch Operation: Patch Certificate [ROOT] Selected model: SM-A037F Software version: 44.11 Waiting ADB device... OK Reading phone info... Model: SM-A037F Android version: 11 PDA version: A037FXXU1AUI7 CSC version: A037FOXE1AUI7 Phone version: A037FXXU1AUI7 Product code: SM-A037FZKDSKZ CSC country code: Kazakhstan CSC sales code: SKZ Carrier ID: SKZ Phone SN: R9HRA0DZ1TZ IMEI: 3XXXXXXXXXXXXX HW version: REV1.0 RF cal date: 20211023 Chip name: MT6765 Modem board: MT6765 Security patch: 2021-09-01 Boot Warranty bit: 1 SIM State: LOADED,ABSENT Checking Super user right... true Root version: 23.0:MAGISKSU Searching server... OK Waiting for server answer... OK Checking data... OK Reading 'boot' image... OK Loading data from 'boot'... OK Reading 'modem' image... OK Loading data from 'modem'... OK Preparation of data... OK Patching... OK Rebooting phone... OK Done with Samsung Tool PRO v.44.11 [SM-A037F,Patch Certificate [ROOT]] |
07-31-2022, 09:07 | #1995 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | J330fn stuck successful done FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J330FN Software version: 44.11 File analysis... OK Total file size: 0xF5981A53 (3929 Mb) Searching USB Flash interface... COM33 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending userdata.img.lz4... OK Sending modem.bin.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... OK Flashing done (time - 00:04:35) Done with Samsung Tool PRO v.44.11 [SM-J330FN,Flash] |
The Following User Says Thank You to qasir_amz For This Useful Post: |
