07-03-2017, 11:02 | #18631 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G530H Selected port: COM166 SAMSUNG Mobile USB Serial Port Software version: 28.2 Checking CERT file... Ok KEY ID: 0504 Waiting ADB device... Ok Reading phone info... Model: SM-G530H Android version: 4.4.4 Product code: SM-G530HZWDINS Phone version: G530HXCU1BOH3 PDA version: G530HXCU1AOE2 CSC version: G530HOJV1AOF1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: R51G203JXHB Modem board: MSM8216 RF cal date: 2014.09.30 IMEI: 354381070102914 Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0504 Writing CERT... Ok Checking CERT status... Ok Writing Slave CERT... Ok Checking Slave CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.28.2 |
07-03-2017, 13:44 | #18632 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Samsung S6 G920F unlock OK! Operation: Read Codes Selected model: SM-G920F Software version: 28.5 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 7.0 Product code: SM-G920FZDAMAT Phone version: G920FXXU5EQD1 PDA version: G920FXXS5EQEF CSC version: G920FOJV5EQD1 CSC country code: MOROCCO CSC sales code: MAT HW version: MP 0.800 Phone SN: RF8G405ZVLZ Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-05-01 RF cal date: 20150402 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 08 8F 28 AE 77 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 04594027 NET lock: 79520318 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 |
The Following User Says Thank You to Umbabaraumba For This Useful Post: |
07-03-2017, 15:43 | #18633 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. If you have one file firmware, then you must check 'Use one package file' option. 4. Check flashing options if needed (Repartition, EFS clear, Boot update). 5. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 6. Connect the phone to PC with USB cable, install drivers if needed. 7. Press 'Flash' button. Operation: Flash Selected model: GT-S5312 Software version: 28.5 File analysis... OK Total file size: 0x3612D215 (865 Mb) Searching USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... OK Sending cache.img... OK Sending system.img... OK Sending hidden.img... OK Sending dt-blob... OK Sending param.lfs... OK Flashing done (time - 00:05:08) Done with Samsung Tool PRO v.28.5 |
The Following User Says Thank You to orhan5 For This Useful Post: |
07-03-2017, 15:43 | #18634 (permalink) |
07-03-2017, 16:36 | #18635 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | sm-j510fn read code done Opération:Read Codes via Server Modèle sélectionné:SM-J510FN Version du logiciel:28.5 Checking Login and Password... Ok Balance: 50 crd. En attendant le périphériqueADB... Ok Lecture d'information du telephone... Modèle: SM-J510FN Android version: 6.0.1 Code du produit: SM-J510FZDNXEF Version du telephone: J510FNXXU2APL3 PDA version: J510FNXXU2APL4 CSC version: J510FNXEF2APL1 SCC code de pays: France CSC code de vente: XEF HW version: MP 0.300 Téléphones SN: RF8J12CLF5R Nom de la puce: MSM8916 Prise modem: MSM8916 Security patch: 2016-12-01 RF cal date: 2017.01.20 IMEI: Redémarrage téléphone... Ok En attendant le périphériqueADB... Ok Redémarrage téléphone... Ok En attendant le périphériqueADB... Ok InitialisationzTool... Ok CourirzTool, s'il vous plaît patienter... Démarrer... Ok Initialisation... Ok Générer et vérifier client la preuve... Ok Vérifier la preuve par le client... Ok Lecture données du Téléphone... Ok Recherche de l'interfaceRamdump... COM93 détecté Lecture données du Téléphone... Ok Calcul... Ok Serveur Recherche... Ok Waiting for server answer... Ok Freeze code: 96831514 NET verrou: 09174748 SUB verrou: 00000000 SP verrou: 00000000 CP verrou: 00000000 Pour connaître l'état de verrouillage : *#7465625# Fait avecSamsung Tool PRO v.28.5 |
The Following User Says Thank You to cheddihouse For This Useful Post: |
07-03-2017, 17:38 | #18636 (permalink) |
Banned Join Date: Jun 2009 Location: india gujrat navsari Age: 37
Member: 1062869 Status: Offline Thanks Meter: 81 | j510fn read code done z3x server credits Checking Login and Password... OK Balance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-J510FN Android version: 6.0.1 Product code: SM-J510FZDUPHE Phone version: J510FNXWU2APL3 PDA version: J510FNXXU2APL4 CSC version: J510FNPHE2APL1 CSC country code: SPAIN CSC sales code: PHE HW version: MP 0.300 Phone SN: RF8HA06DKNR Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-12-01 RF cal date: 2016.10.03 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM57 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 62736283 NET lock: 46484828 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.5 |
07-04-2017, 01:16 | #18637 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | N920P 7.0 QC5 Unlock Done.. Operation: Unlock Selected model: SM-N920P Software version: 28.5 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920P Android version: 7.0 Product code: Not Active Phone version: N920PVPU3DQC5 PDA version: N920PVPU3DQC5 CSC version: N920PSPT3DQC5 CSC country code: USA CSC sales code: XAS HW version: N920P.03 Phone SN: 00000000000 Modem board: MDM9635M Security patch: 2017-03-01 RF cal date: 2015.08.12 IMEI: Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done |
07-04-2017, 01:36 | #18638 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | g610m success unlock Operation: Unlock Selected model: SM-G610M Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-G610M Android version: 6.0.1 Product code: SM-G610MZKADOR Phone version: G610MUBU1AQB3 PDA version: G610MUBU1AQB3 CSC version: G610MUWE1AQB3 CSC country code: DOMINICAN REPUBLIC CSC sales code: DOR HW version: MP 0.100 Phone SN: R58J321JJJW Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: 20170310 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 0D 07 00 00 00 00 00 00 00 00 00 00 0D 86 7B D4 Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
07-04-2017, 08:38 | #18639 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-J710F Software version: 28.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZWDXSG Phone version: J710FXXU2AQB2 PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: RF8J51RDN1D Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: 20170516 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: B7 06 00 00 00 00 00 00 00 00 00 00 E9 E1 BE 18 Calculating... Ok Repairing... Ok Writing NV data... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.28.2 |
07-04-2017, 08:39 | #18640 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-J710F Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZWDXSG Phone version: J710FXXU2AQB2 PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: RF8J51RDN1D Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: 20170516 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.28.2 |
07-04-2017, 14:17 | #18642 (permalink) |
Freak Poster Join Date: Mar 2015 Location: srilanka
Member: 2363369 Status: Offline Thanks Meter: 95 | sm-g532f unlock done Waiting ADB device... Ok Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZSDKSA Phone version: G532FXXU1APL1 PDA version: G532FXWU1AQA1 CSC version: G532FOJV1AQA1 CSC country code: KSA CSC sales code: KSA HW version: MP 0.300 Phone SN: R58J31LNSTK Chip name: MT6737T Modem board: MT6737T Security patch: 2017-01-01 RF cal date: 20170308 IMEI: Checking Super user right... true Reading security... Ok Unlocking... Ok Writing security... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.2 |
07-04-2017, 18:07 | #18643 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung Galaxy S6 EDGE Network Repair Done.. Operation: Patch Certificate Selected model: SM-G925T Software version: 28.4 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: SM-G920FZKATMB Phone version: G925TUVU5EQC2 PDA version: G925TUVU5EQC2 CSC version: G925TTMB5EQC2 CSC country code: USA CSC sales code: TMB HW version: MP 0.800 Phone SN: RF1D4AAAAGR Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-03-01 RF cal date: 20150406 IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.28.4 |
07-05-2017, 04:40 | #18644 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Bangladesh Age: 40
Member: 1703431 Status: Offline Sonork: 100.1619192 QQ 3271159180 Thanks Meter: 2,106 | Samsung SM-J700F (Galaxy J7) Emergency Calls Only Done By Z3X |
The Following User Says Thank You to DALIM SARKAR For This Useful Post: |
07-05-2017, 07:48 | #18645 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | j710f reset frp Code: Operation: Reset FRP Selected model: SM-J710F Software version: 28.6 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKDTHR Phone version: J710FXXU2AQB2 PDA version: J710FXXU2AQB3 CSC version: J710FOJV2AQB2 CSC country code: IRAN CSC sales code: THR HW version: MP 0.400 Phone SN: RF8HB2M5CNW Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-02-01 RF cal date: 20161121 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.6 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
