Old 07-03-2017, 11:02   #18631 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Write CERT
Selected model: SM-G530H
Selected port: COM166 SAMSUNG Mobile USB Serial Port
Software version: 28.2
Checking CERT file... Ok
KEY ID: 0504
Waiting ADB device... Ok
Reading phone info...
Model: SM-G530H
Android version: 4.4.4
Product code: SM-G530HZWDINS
Phone version: G530HXCU1BOH3
PDA version: G530HXCU1AOE2
CSC version: G530HOJV1AOF1
CSC country code: UAE
CSC sales code: XSG
HW version: MP 0.400
Phone SN: R51G203JXHB
Modem board: MSM8216
RF cal date: 2014.09.30
IMEI: 354381070102914
Writing AT RIL... Ok
Initialization AT RIL... Ok
Bypass MSL... Ok
Checking for compatible phone and cert... Ok
Phone KEY ID: 0504
Writing CERT... Ok
Checking CERT status... Ok
Writing Slave CERT... Ok
Checking Slave CERT status... Ok
Rebooting phone... Ok
Done with Samsung Tool PRO v.28.2
Old 07-03-2017, 13:44   #18632 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 459
Samsung S6 G920F unlock OK!
Operation: Read Codes
Selected model: SM-G920F
Software version: 28.5
Waiting ADB device... OK
Model: SM-G920F
Android version: 7.0
Product code: SM-G920FZDAMAT
Phone version: G920FXXU5EQD1
PDA version: G920FXXS5EQEF
CSC version: G920FOJV5EQD1
CSC country code: MOROCCO
CSC sales code: MAT
HW version: MP 0.800
Phone SN: RF8G405ZVLZ
Chip name: EXYNOS7420
Modem board: SHANNON333
Security patch: 2017-05-01
RF cal date: 20150402
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Initialization zTool... OK
Running zTool, please wait... OK
HWID: 08 8F 28 AE 77 07 00 00 00 00 00 00 00 00 00 00
Calculating... OK
Checking hash file... OK
Please wait, calculating codes... OK (time - 00:00:04)
Freeze code: 04594027
NET lock: 79520318
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.28.5
The Following User Says Thank You to Umbabaraumba For This Useful Post:
Old 07-03-2017, 15:43   #18633 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. If you have one file firmware, then you must check 'Use one package file' option.
4. Check flashing options if needed (Repartition, EFS clear, Boot update).
5. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power).
6. Connect the phone to PC with USB cable, install drivers if needed.
7. Press 'Flash' button.
Operation: Flash
Selected model: GT-S5312
File analysis... OK
Total file size: 0x3612D215 (865 Mb)
Searching USB Flash interface... COM9 detected
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending BcmCP.img... OK
Sending cache.img... OK
Sending system.img... OK
Sending hidden.img... OK
Sending dt-blob... OK
Sending param.lfs... OK
Flashing done (time - 00:05:08)
The Following User Says Thank You to orhan5 For This Useful Post:
Old 07-03-2017, 15:43   #18634 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
Old 07-03-2017, 16:36   #18635 (permalink)
Member: 1834802
Sonork: 100.1659078
Thanks Meter: 89
sm-j510fn read code done
Opération:Read Codes via Server
Modèle sélectionné:SM-J510FN
Version du logiciel:28.5
Checking Login and Password... Ok
Balance: 50 crd.
En attendant le périphériqueADB... Ok
Lecture d'information du telephone...
Modèle: SM-J510FN
Android version: 6.0.1
Code du produit: SM-J510FZDNXEF
Version du telephone: J510FNXXU2APL3
PDA version: J510FNXXU2APL4
CSC version: J510FNXEF2APL1
SCC code de pays: France
CSC code de vente: XEF
HW version: MP 0.300
Téléphones SN: RF8J12CLF5R
Nom de la puce: MSM8916
Prise modem: MSM8916
Security patch: 2016-12-01
RF cal date: 2017.01.20
IMEI:
Redémarrage téléphone... Ok
InitialisationzTool... Ok
CourirzTool, s'il vous plaît patienter...
Démarrer... Ok
Initialisation... Ok
Générer et vérifier client la preuve... Ok
Vérifier la preuve par le client... Ok
Lecture données du Téléphone... Ok
Recherche de l'interfaceRamdump... COM93 détecté
Calcul... Ok
Serveur Recherche... Ok
Waiting for server answer... Ok
Freeze code: 96831514
NET verrou: 09174748
SUB verrou: 00000000
SP verrou: 00000000
CP verrou: 00000000
Pour connaître l'état de verrouillage : *#7465625#
Fait avecSamsung Tool PRO v.28.5
The Following User Says Thank You to cheddihouse For This Useful Post:
Old 07-03-2017, 17:38   #18636 (permalink)
Member: 1062869
Thanks Meter: 81
z3x server credits
Checking Login and Password... OK
Balance: 50 crd.
Model: SM-J510FN
Product code: SM-J510FZDUPHE
Phone version: J510FNXWU2APL3
CSC version: J510FNPHE2APL1
CSC country code: SPAIN
CSC sales code: PHE
Phone SN: RF8HA06DKNR
Chip name: MSM8916
Modem board: MSM8916
RF cal date: 2016.10.03
IMEI:
Rebooting phone... OK
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM57 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 62736283
NET lock: 46484828
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
Old 07-04-2017, 01:16   #18637 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 19
N920P 7.0 QC5 Unlock Done..
Operation: Unlock
Selected model: SM-N920P
Please, allow USB debugging on phone... OK
Model: SM-N920P
Product code: Not Active
Phone version: N920PVPU3DQC5
PDA version: N920PVPU3DQC5
CSC version: N920PSPT3DQC5
CSC country code: USA
CSC sales code: XAS
HW version: N920P.03
Phone SN: 00000000000
Modem board: MDM9635M
Security patch: 2017-03-01
RF cal date: 2015.08.12
IMEI:
Writing AT RIL... OK
Initialization AT RIL... root required
Initialization AT RIL... OK
Unlocking... OK
Unlock done
Old 07-04-2017, 01:36   #18638 (permalink)
Member: 914220
Thanks Meter: 206
g610m success unlock
Operation: Unlock
Selected model: SM-G610M
Model: SM-G610M
Product code: SM-G610MZKADOR
Phone version: G610MUBU1AQB3
PDA version: G610MUBU1AQB3
CSC version: G610MUWE1AQB3
CSC country code: DOMINICAN REPUBLIC
CSC sales code: DOR
HW version: MP 0.100
Phone SN: R58J321JJJW
Chip name: EXYNOS7870
Modem board: SHANNON315
Security patch: 2017-02-01
RF cal date: 20170310
IMEI:
Reading NV data... Ok
Checking NV data... Ok
Reading data... Ok
Detecting MODEM... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Initialization zTool... Ok
Start... Ok
Initialization... Ok
Generate and check client proof... Ok
Verify proof by client... Ok
Reading data... Ok
HWID: 0D 07 00 00 00 00 00 00 00 00 00 00 0D 86 7B D4
Calculating... Ok
Unlocking... Ok
Writing NV data... Ok
Unlock done
Old 07-04-2017, 08:38   #18639 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
REPAIR INSTRUCTIONS:
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
8. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Operation: Repair
Selected model: SM-J710F
If you are looking for 'Repair Network' function then you should use 'Patch Certificate'
Please, allow USB debugging on phone... Ok
Model: SM-J710F
Product code: SM-J710FZWDXSG
Phone version: J710FXXU2AQB2
PDA version: J710FXXU2AQB3
CSC version: J710FOJV2AQB2
CSC sales code: XSG
Phone SN: RF8J51RDN1D
RF cal date: 20170516
IMEI:
Reading data... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Start... Ok
Reading data... Ok
HWID: B7 06 00 00 00 00 00 00 00 00 00 00 E9 E1 BE 18
Calculating... Ok
Repairing... Ok
Repair done
Old 07-04-2017, 08:39   #18640 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
Operation: Patch Certificate
Model: SM-J710F
CSC sales code: XSG
IMEI:
Reading data... Ok
Reading MODEM... Ok
Calculating... Ok
Writing zTool... Ok
Patching CERT check... done
Old 07-04-2017, 10:39   #18641 (permalink)
Member: 2733082
Unlock code please
Help im from philippines
Unlock code please...
Imei: 012233003609248
at&t
model sgh-a107
tia
Old 07-04-2017, 14:17   #18642 (permalink)
tharakax1's Avatar
Member: 2363369
Thanks Meter: 95
sm-g532f unlock done
Model: SM-G532F
Product code: SM-G532FZSDKSA
Phone version: G532FXXU1APL1
PDA version: G532FXWU1AQA1
CSC version: G532FOJV1AQA1
CSC country code: KSA
CSC sales code: KSA
Phone SN: R58J31LNSTK
Chip name: MT6737T
Modem board: MT6737T
Security patch: 2017-01-01
RF cal date: 20170308
IMEI:
Reading security... Ok
Unlocking... Ok
Writing security... Ok
Unlock done
Old 07-04-2017, 18:07   #18643 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Samsung Galaxy S6 EDGE Network Repair Done..
Selected model: SM-G925T
Software version: 28.4
Model: SM-G925T
Product code: SM-G920FZKATMB
Phone version: G925TUVU5EQC2
PDA version: G925TUVU5EQC2
CSC version: G925TTMB5EQC2
CSC sales code: TMB
Phone SN: RF1D4AAAAGR
RF cal date: 20150406
IMEI:
Reading modem... OK
Patching modem... OK
Writing modem... OK
Done with Samsung Tool PRO v.28.4
Old 07-05-2017, 04:40   #18644 (permalink)
DALIM SARKAR's Avatar
Member: 1703431
Sonork: 100.1619192 QQ 3271159180
Thanks Meter: 2,106
Samsung SM-J700F (Galaxy J7) Emergency Calls Only Done By Z3X
Download
The Following User Says Thank You to DALIM SARKAR For This Useful Post:
Old 07-05-2017, 07:48   #18645 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
j710f reset frp
Operation: Reset FRP
Software version: 28.6
Model: SM-J710F
Product code: SM-J710FZKDTHR
CSC country code: IRAN
CSC sales code: THR
Phone SN: RF8HB2M5CNW
RF cal date: 20161121
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.28.6
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.41754 seconds with 10 queries
