09-01-2017, 19:18 | #19006 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | lg vs425 frp ok Model: LS665 Read info... Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US IMEI: 354874075xxxx Elapsed: 3 secs. --> (v9.38) Phone mode is DOWNLOAD Start FRP remove... Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US IMEI: 35487407566xxxx Init EXT4 ... Save EXT4... FRP Reset Done. Elapsed: 12 secs. --> (v9.38) Mode: Emergency Model: LS665 Read info... Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US IMEI: 3548740756xxxx Elapsed: 3 secs. --> (v9.38) Phone mode is DOWNLOAD Start FRP remove... Model name: VS425PP Software verion: VS425PP1 Android verion: 5.1.1 Target operator: VZW Target country: US IMEI: 354874075xxxx Init EXT4 ... Restore data detected! Save EXT4... FRP Restore Done! Elapsed: 9 secs. --> (v9.38) |
09-01-2017, 20:48 | #19007 (permalink) |
Insane Poster Join Date: Sep 2014 Location: UNITED STATES Age: 37
Member: 2266076 Status: Offline Sonork: Propery Thanks Meter: 19 | J120A Unlock Done by code read Operation: Read Codes Selected model: SM-J120A Software version: 29.2 Searching Samsung modem... detected COM54 Reading phone info... OK Model: SM-J120A AP version: J120AUCS3AQE1 CSC version: J120AATT3AQE1 CP version: J120AUCU3AQE1 Product code: SM2J120AZWCATT Phone SN: R58J666Mxxx Unique number: C8G010F39B0xxxx Reading IMEI... OK IMEI: 35707308552xxxx (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNOxxxx HWID: 5A 09 B3 FC 45 BC 9F 0A 1E 50 64 45 75 57 BA A7 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 31697361 NET lock: 68580624 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 |
09-02-2017, 08:24 | #19008 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Sm-g610f frp G610 FRP Done. Code: UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-G610F Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDINS Phone version: G610FDDU1AQE4 PDA version: G610FDDU1AQE4 CSC version: G610FODD1AQE2 CSC country code: India CSC sales code: INS HW version: MP 0.300 Phone SN: R28J12NVTMX Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-05-01 RF cal date: 20170118 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
09-02-2017, 08:26 | #19009 (permalink) |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | G610F Unlocked! G610F Unlocked! Code: UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G610F Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZDDINS Phone version: G610FDDU1AQE4 PDA version: G610FDDU1AQE4 CSC version: G610FODD1AQE2 CSC country code: India CSC sales code: INS HW version: MP 0.300 Phone SN: R280000MX Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-05-01 RF cal date: 20170118 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 8C 04 00 00 00 00 00 00 00 00 00 00 58 EB 45 5F Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-03-2017, 11:47 | #19010 (permalink) |
Freak Poster Join Date: Apr 2011 Location: BANGLADESH Age: 29
Member: 1553137 Status: Offline Sonork: 100.1652229 Thanks Meter: 56 | G920t unlock done Code: Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: SM-G920TZDATMB Phone version: G920TUVU5FQG3 PDA version: G920TUVU5FQG3 CSC version: G920TTMB5FQG3 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58GA2KZG1W Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: 20151029 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: C8 E4 93 76 76 06 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-03-2017, 15:52 | #19011 (permalink) |
Freak Poster Join Date: Nov 2010 Location: SOUTH AFRICA
Member: 1449328 Status: Offline Thanks Meter: 77 | Z200f imei repair done z3x Operation: Repair Selected model: SM-Z200F Software version: 29.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting SDB device... OK Reading phone info... Model: SM-Z200F Build: Z200FDDU0API2 Tizen version: Tizen release 2.4.0 (Magnolia) Checking Super user right... true HW version: MP 0.300 Phone SN: R58H91Q3WJB Product code: SM-Z200YZKAXFV Reading data from phone... OK Repairing IMEI... OK Writing data to phone... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.2 Operation: Patch Certificate Selected model: SM-Z200F Software version: 29.2 Waiting SDB device... OK Reading phone info... Model: SM-Z200F Build: Z200FDDU0API2 Tizen version: Tizen release 2.4.0 (Magnolia) Checking Super user right... true HW version: MP 0.300 Phone SN: R58H91Q3WJB Product code: SM-Z200YZKAXFV Reading data from phone... OK Patching CERT check... OK Writing data to phone... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 BR KHAN MOBILES |
09-03-2017, 19:05 | #19012 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | G920w8 androit 7 unlock ok Code: Searching Samsung modem... detected COM79 Reading phone info... OK Model: SM-G920W8 AP version: G920W8VLS5DQG1 CSC version: G920W8OYA5DQG1 CP version: G920W8VLU5API1 Product code: TLS Phone SN: RF8G31XZ4JN Unique number: 02157DF2B4C53D09 Reading IMEI... OK IMEI: 351559070072012 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-04-2017, 05:02 | #19013 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-A320FL Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-A320FL Android version: 6.0.1 Product code: SM-A320FZDNNEE Phone version: A320FLXXU1AQB3 PDA version: A320FLXXU1AQG1 CSC version: A320FLNEE1AQG1 CSC country code: Nordic CSC sales code: NEE HW version: MP 0.300 Phone SN: RF8J803CE1E Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-07-01 RF cal date: 20170801 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: B4 07 00 00 00 00 00 00 00 00 00 00 88 B8 F8 C3 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 01:02 | #19014 (permalink) |
Junior Member Join Date: Sep 2016 Location: los angeles ca
Member: 2627990 Status: Offline Thanks Meter: 7 | samsung SM-N920T latest security patch rooted CF-auto Root!! Operation: Unlock [ 8/27/2017 7:18:00 AM ] Selected model: SM-N920T [ 8/27/2017 7:18:00 AM ] Selected port: COM7 USB Serial Port [ 8/27/2017 7:18:00 AM ] Software version: 29.1 [ 8/27/2017 7:18:00 AM ] [ 8/27/2017 7:19:00 AM ] Waiting ADB device... [ 8/27/2017 7:19:00 AM ] Please, allow USB debugging on phone... OK [ 8/27/2017 7:19:00 AM ] Reading phone info... [ 8/27/2017 7:19:00 AM ] Model: SM-N920T [ 8/27/2017 7:19:00 AM ] Android version: 7.0 [ 8/27/2017 7:19:00 AM ] Product code: SM-N920TZKATMB [ 8/27/2017 7:19:00 AM ] Phone version: N920TUVU4EQG3 [ 8/27/2017 7:19:00 AM ] PDA version: N920TUVU4EQG3 [ 8/27/2017 7:19:00 AM ] CSC version: N920TTMB4EQG3 [ 8/27/2017 7:19:00 AM ] CSC country code: USA [ 8/27/2017 7:19:00 AM ] CSC sales code: TMB [ 8/27/2017 7:19:00 AM ] HW version: REV0.2 [ 8/27/2017 7:19:00 AM ] Phone SN: RF8G92LKQEY [ 8/27/2017 7:19:00 AM ] Chip name: EXYNOS7420 [ 8/27/2017 7:19:00 AM ] Modem board: SHANNON333 [ 8/27/2017 7:19:00 AM ] Security patch: 2017-07-01 [ 8/27/2017 7:19:00 AM ] RF cal date: 20150925 [ 8/27/2017 7:19:00 AM ] IMEI: [ 8/27/2017 7:19:00 AM ] Checking Super user right... true [ 8/27/2017 7:19:00 AM ] Reading NV data... OK [ 8/27/2017 7:19:00 AM ] Checking NV data... OK [ 8/27/2017 7:19:00 AM ] Initialization zTool... OK [ 8/27/2017 7:19:00 AM ] Running zTool, please wait... OK [ 8/27/2017 7:19:00 AM ] HWID: 48 AA 6E F6 F6 04 00 00 00 00 00 00 00 00 00 00 [ 8/27/2017 7:20:00 AM ] Calculating... OK [ 8/27/2017 7:20:00 AM ] Unlocking... OK [ 8/27/2017 7:20:00 AM ] Writing NV data... OK [ 8/27/2017 7:20:00 AM ] Rebooting phone... OK [ 8/27/2017 7:20:00 AM ] Unlock done thanks z3x team. |
09-05-2017, 06:34 | #19015 (permalink) |
Freak Poster Join Date: Oct 2010 Location: USA
Member: 1420095 Status: Offline Thanks Meter: 216 | Galaxy On7 FRP Success! Operation: Reset FRP Selected model: SM-G600FY Selected port: COM4 USB Serial Port Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G600FY Android version: 5.1.1 Product code: SM-G600FZDDXTC Phone version: G600FYXXU1APD5 PDA version: G600FYXXU1API3 CSC version: G600FYOLB1API3 CSC country code: PHILIPPINES CSC sales code: XTC HW version: MP 0.400 Phone SN: R28H71AY4AH Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-09-01 RF cal date: 2016.07.14 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
09-05-2017, 08:20 | #19016 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Repair Selected model: GT-I9300 Software version: 29.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: Not Active Phone version: I9300XXUGMK6 PDA version: I9300XXUGMK6 CSC version: I9300OXXGML1 CSC country code: Greece CSC sales code: CYO HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 004999010640000 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 0 Calculating... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.1 |
09-05-2017, 08:21 | #19017 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-G532F Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SM-G532F Android version: 6.0.1 Product code: SM-G532FZDDMID Phone version: G532FXXU1APJ7 PDA version: G532FXWU1APJ3 CSC version: G532FOJV1APJ6 CSC country code: Iraq CSC sales code: MID HW version: MP 0.300 Phone SN: R58HC51X68B Chip name: MT6737T Modem board: MT6737T Security patch: 2016-10-01 RF cal date: 20161224 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 |
09-05-2017, 08:22 | #19018 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Patch Certificate Selected model: GT-I9300 Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.3 Product code: Not Active Phone version: I9300XXUGMK6 PDA version: I9300XXUGMK6 CSC version: I9300OXXGML1 CSC country code: Greece CSC sales code: CYO HW version: REV__ Phone SN: 00000000000 Modem board: RF cal date: none IMEI: 355829059493521 Checking Super user right... true Reading modem OK Patching modem... OK Writing modem... OK Reading kernel... OK Patching kernel... OK Writing kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.1 |
09-05-2017, 08:28 | #19019 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920P Android version: 6.0.1 Product code: Not Active Phone version: N920PVPS3BPK1 PDA version: N920PVPS3BPK1 CSC version: N920PSPT3BPK1 CSC country code: USA CSC sales code: SPR HW version: N920P.04 Phone SN: 00000000000 Modem board: MDM9635M Security patch: 2016-11-01 RF cal date: 2015.10.14 IMEI: Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 12:04 | #19020 (permalink) |
Freak Poster Join Date: Jul 2014 Location: 149.3.27.22 Age: 38
Member: 2229851 Status: Offline Thanks Meter: 55 | Operation: Unlock Selected model: SM-G550T Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G550T Android version: 6.0.1 Product code: SM2G550TZKATMB Phone version: G550TUVU2AQC4 PDA version: G550TUVU2AQC4 CSC version: G550TTMB2AQC4 CSC country code: USA CSC sales code: TMB HW version: REV0.4 Phone SN: RV8J1019HNH Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 RF cal date: 20170104 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 34 AB 31 D5 0C CA 82 14 F2 7F C8 C0 A7 39 00 52 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
