09-05-2017, 13:33 | #19021 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700F/DS Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 Product code: SM-J700FZKDXME Phone version: J700FXXU4BQC3 PDA version: J700FXXS4BQF1 CSC version: J700FOJV4BQC6 CSC country code: UAE CSC sales code: XSG HW version: MP 0.701 Phone SN: R58H32GC6ZK Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160317 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 13:39 | #19022 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700F/DS Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-J700F Android version: 6.0.1 Product code: SM-J700FZKDXME Phone version: J700FXXU4BQC3 PDA version: J700FXXS4BQF1 CSC version: J700FOJV4BQC6 CSC country code: UAE CSC sales code: XSG HW version: MP 0.701 Phone SN: R58H32GC6ZK Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20160317 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 13:40 | #19023 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Spain Age: 41
Member: 46247 Status: Offline Thanks Meter: 8 | Operation: Read Codes via Server Selected model: SM-J510MN Selected port: COM313 SAMSUNG Mobile USB Serial Port Software version: 29.2 Checking Login and Password... Listo Ballance: 50 crd. Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-J510MN Android version: 6.0.1 Código del Producto: SM-J510MZKNCHL Versión del telefono: J510MNUBU2AQB1 PDA version: J510MNUBU2AQB2 CSC version: J510MNUWA2AQB3 Código de país CSC: Chile Código de Venta CSC: CHL HW version: MP 0.300 Phone SN: RV8J300PSFH Chip name: MSM8916 Módem: MSM8916 Security patch: 2017-02-01 RF cal date: 2017.03.10 IMEI: Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM227 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 06847507 NET lock: 69082037 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.29.2 |
09-05-2017, 14:12 | #19024 (permalink) |
Insane Poster Join Date: Sep 2011 Location: Hajigonj Chandpur Bangladesh Age: 34
Member: 1663170 Status: Offline Sonork: 100.1661551 Thanks Meter: 47 | SM-G930F 7.0 FRP Remove Done by Z3x Box Operation: Reset FRP UFS Selected model: SM-G930F Selected port: COM6 Z3X BOX Serial Port Software version: 29.2 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM6 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G930F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 16:48 | #19025 (permalink) |
Freak Poster Join Date: Oct 2008 Location: chenai,india
Member: 883886 Status: Offline Sonork: 1664059 Thanks Meter: 111 | SM-G935F FRP done (s7 edge) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM88 USB Serial Port Software version: 29.2 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM88 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.2 |
09-05-2017, 22:08 | #19026 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G920T Selected port: COM1127 SAMSUNG Mobile USB Serial Port Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 6.0.1 Product code: SM-G920TZDATMB Phone version: G920TUVU5EQC2 PDA version: G920TUVU5EQC2 CSC version: G920TTMB5EQC2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58H11WR5WT Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-03-01 RF cal date: 20161226 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: C8 02 8F F5 34 07 00 00 00 00 00 00 00 00 00 00 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-06-2017, 10:06 | #19027 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G930F Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDATTT Phone version: G930FXXU1APB4 PDA version: G930FXXU1APB4 CSC version: G930FUUB1APB4 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: MP 0.700 Phone SN: R58H31NW1DM Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-02-01 RF cal date: 20160311 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.2 |
09-06-2017, 23:33 | #19028 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G930P Software version: 29.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950U Android version: 7.0 Product code: SM-G950UZKASPR Phone version: G950USQU1AQD9 PDA version: G950USQU1AQD9 CSC version: G950UOYN1AQD9 CSC country code: USA CSC sales code: SPR HW version: REV1.0 Phone SN: R28J41RLCTJ Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.04.14 IMEI: Writing AT RIL... OK Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
09-07-2017, 07:20 | #19029 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.2 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.2 |
09-07-2017, 14:11 | #19030 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | J320F read simlock codes without root Code: Searching Samsung modem... detected COM230 Reading phone info... OK Model: SM-J320F Version: J320FXXU0AQC3/J320FDBT0APH1/J320FXXU0AQC3/J320FXXU0AQC3 Product code: SM-J320FZKDDBT Phone SN: ********* IMEI: Unique number: CQN0061824E2634 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:42) Freeze code: 58192724 NET lock: 09750846 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
09-07-2017, 14:14 | #19031 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | J7 2016(J710F)unlock done by read codes Code: Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKNROM Phone version: J710FXXU3AQD1 PDA version: J710FXXS3AQD1 CSC version: J710FOXX3AQD1 CSC country code: Romania CSC sales code: ROM HW version: MP 0.300 Phone SN: R********* Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-04-01 RF cal date: 20170119 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: B4 04 00 00 00 00 00 00 00 00 00 00 90 D1 9A 1B Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:03) Freeze code: 03146081 NET lock: 37268029 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# |
09-07-2017, 14:15 | #19032 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | G361H FRP erase done Code: Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.1 Searching Samsung USB Flash interface... COM41 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done |
09-07-2017, 14:16 | #19033 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | S7 EDGE(G935F) FRP reset done in 3 seconds Code: Operation: Reset FRP UFS Selected model: SM-G935F Selected port: COM3 USB Serial Port Software version: 29.1 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G935F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
09-07-2017, 14:18 | #19034 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | SM-N920C Note 5 FRP reset done Code: Operation: Reset FRP UFS Selected model: SM-N920C Selected port: COM3 USB Serial Port Software version: 29.1 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (N920C) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done |
09-07-2017, 15:18 | #19035 (permalink) |
Insane Poster Join Date: Sep 2012 Location: india Age: 36
Member: 1807959 Status: Offline Thanks Meter: 17 | Operation: Read Codes Selected model: SM-J120A Software version: 29.2 Searching Samsung modem... detected COM11 Reading phone info... OK Model: SM-J120A AP version: J120AUCU2AQC1 CSC version: J120AATT2AQC1 CP version: J120AUCU3AQE1 Product code: SM2J120AZWCATT Phone SN: R58J61TG59F Unique number: C8G013234D56A54 Reading IMEI... OK IMEI: 357073084556709 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON308 HWID: 7F 87 62 BC CF 9C 16 C3 51 A7 3A 3B 73 F2 41 49 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 28396493 NET lock: 75803849 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
