10-07-2017, 13:03 | #19186 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | LG 2-3G Tool v9.40 supported models: 1523 Mode: Normal Model: LGM150AT Build version: Jan 25 201720:47:20Jan 23 201702:00:00LGM150AT SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 IMEI: 35406308203512-2 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.40) Mode: Normal Model: LGM150AT Build version: Jan 25 201720:47:20Jan 23 201702:00:00LGM150AT SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 IMEI: 35406308203512-2 BlueTooth Address: 00:00:00:00:00:00 Phone Code: Elapsed: 1 secs. --> (v9.40) Checking phone at COM68 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 Reading ESN... OK Read SPC... Unlock SPC... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Phone mode is NORMAL Switch to DOWNLOAD mode Phone detected! Read security zone... Model name: LG-M150 Software verion: M15010g Android verion: 6.0.1 Target operator: ATT Target country: US IMEI: 354063082035122 Save part1... done Save part2... done Save part3... done Sec zone saved: ..\Backup\M150_354063082035122_07102017_165012.lgs b1 Write security zone... Erase part1... done Erase part2... done Erase part3... done Reboot... Phone detected! Reading QCN file... OK Checking phone at COM68 Detected ID: 0000100C (MSM8909) SW Version: MPSS.JO.2.0.c1.2-00007-8909_GEN_PACK-1.80783.1.85287.4 Unlock SPC... OK Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Unlock done! Elapsed: 536 secs. --> (v9.40) Repair IMEI... Search LG Modem port... Detected LG Modem port at COM67 Repair done! Elapsed: 22 secs. --> (v9.40) |
10-07-2017, 13:29 | #19187 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 35
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP Selected model: SM-G610F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G610F Android version: 6.0.1 Product code: SM-G610FZKDKSA Phone version: G610FDDU1AQC2 PDA version: FA60_G610FDDU1AQC2 CSC version: CSC country code: CSC sales code: HW version: MP 0.300 Phone SN: R28J221LJ1J Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2016-08-01 RF cal date: 20170214 IMEI: 357056083664673 Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
10-07-2017, 13:31 | #19188 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.4 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.4 |
10-07-2017, 13:31 | #19189 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-G361H Software version: 29.4 Searching Samsung USB Flash interface... COM41 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done |
10-07-2017, 13:32 | #19190 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Read Codes Selected model: SM-J120A Software version: 29.4 Searching Samsung modem... detected COM11 Reading phone info... OK Model: SM-J120A AP version: J120AUCU2AQC1 CSC version: J120AATT2AQC1 CP version: J120AUCU3AQE1 Product code: SM2J120AZWCATT Phone SN: R58J61TG59F Unique number: C8G013234D56A54 Reading IMEI... OK IMEI: 357073084556709 (SIGN: OK) Checking hash file... OK Reading data from phone... OK Modem board: SHANNON308 HWID: 7F 87 62 BC CF 9C 16 C3 51 A7 3A 3B 73 F2 41 49 Reading NV data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 28396493 NET lock: 75803849 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
10-07-2017, 13:33 | #19191 (permalink) |
Member: 1433496 Status: Offline Sonork: 100.1655152 Thanks Meter: 446 | Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 29.4 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
10-07-2017, 15:32 | #19192 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Repair Selected model: GT-N7100 Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: GT-N7100 Android version: 4.1.2 Product code: GT-N7100RWDTGY Phone version: N7100XXDLK7 PDA version: N7100ZSDMF2 CSC version: N7100OZSDMF2 CSC country code: Hong Kong CSC sales code: TGY HW version: MP 1.301 Phone SN: RF1D75PCAKX Modem board: XMM6262 RF cal date: 2013.7.23 IMEI: 8xxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Writing NV Data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
10-07-2017, 15:34 | #19193 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 8. Press 'Disable Factory Mode' or 'Patch Sertificate' if needed. Operation: Patch Certificate Selected model: GT-N7100 Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: GT-N7100 Android version: 4.1.2 Product code: GT-N7100RWDTGY Phone version: N7100XXDLK7 PDA version: N7100ZSDMF2 CSC version: N7100OZSDMF2 CSC country code: Hong Kong CSC sales code: TGY HW version: MP 1.301 Phone SN: RF1D75PCAKX Modem board: XMM6262 RF cal date: 2013.7.23 IMEI: 3xxxxxxxxxxxxx Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
10-07-2017, 15:37 | #19194 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-J110H/DS Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZBDMID Phone version: J110HXXU0AOGA PDA version: J110HXXU0AOGA CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R51H1166P8J Modem board: SC7727S RF cal date: 20160116 IMEI: 300000000000000 Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing Slave IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
10-07-2017, 15:38 | #19195 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Patch Certificate Selected model: SM-J110H/DS Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-J110H Android version: 4.4.4 Product code: SM-J110HZBDMID Phone version: J110HXXU0AOGA PDA version: J110HXXU0AOGA CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: R51H1166P8J Modem board: SC7727S RF cal date: 20160116 IMEI: 300000000000000 Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
10-08-2017, 08:02 | #19196 (permalink) |
Freak Poster Join Date: Nov 2008 Age: 37
Member: 906256 Status: Offline Thanks Meter: 40 | SM-G935F Patch Certificate Done on 7.0 Network Okay Last Firmware Update Eng root not okey for Patch network.root by twrp and dm verify disable! and install SuperSU... Operation: Patch Certificate Selected model: SM-G935F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 Product code: SM-G935FZDUXSG Phone version: G935FXXU1DQE8 PDA version: G935FXXS1DQHM CSC version: G935FOJV1DQEB CSC country code: UAE CSC sales code: XSG HW version: MP 0.801 Phone SN: 00000000000 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2017-08-01 RF cal date: 20160829 IMEI: 35765807657**** Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 Great z3x box and thanks to mr blang. |
The Following User Says Thank You to artoor32 For This Useful Post: |
10-08-2017, 09:46 | #19197 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-J730F Software version: 29.4 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J730F Android version: 7.0 Product code: SM-J730FZDDAUT Phone version: J730FXXU1AQEB PDA version: J730FXXU1AQF4 CSC version: J730FAUT1AQE4 CSC country code: Switzerland CSC sales code: AUT HW version: MP 0.400 Phone SN: RF8J73F456Y Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-06-01 RF cal date: 20170802 IMEI: 357074084947351 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Rebooting phone... OK Waiting ADB device... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: ED 30 14 53 F9 B4 6F C4 43 A4 38 C8 E3 D4 81 2A Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 |
10-09-2017, 07:27 | #19198 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Samsung F480 read code done Operation: Read Codes Selected model: SGH-F480 Selected port: COM3 USB Serial Port Software version: 29.4 Reading phone info... OK Model: SGH-F480 Country code: ¿µ±¹ Cal date: 2008-10-01 Factory SW: F480XXHI1 Unique number: 60340000149512 Memory phone: KBN00700AM(F480) Phone SN: R9XQA67189 Reading IMEI... OK IMEI: 35618102444XXXX Reading SYSINFO... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:19) Freeze code: 39290475 NET lock: 00000000 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 12369874 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
10-09-2017, 13:10 | #19199 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | a310f repair done Operation: Patch Certificate Selected model: SM-A310F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-A310F Android version: 7.0 Product code: SM-A310FZDAETL Phone version: A310FXXU3CQF8 PDA version: A310FXXU3CQF5 CSC version: A310FOJV3CQF6 CSC country code: UAE CSC sales code: XSG HW version: MP 0.200 Phone SN: R58J10NZ1JM Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20170104 IMEI: 358817036122575 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
